Home » Modeling » GMF (Graphical Modeling Framework) » save as. How can I make a copy from the model and diagram file?
save as. How can I make a copy from the model and diagram file? [message #237342] Thu, 23 July 2009 09:48 Go to next message
Hello
I try to implement the save as functionality. What I have to do now?
I would like to have the possibility to save the current diagram und model
state in a new file.
I know following: I have to override the method isSaveAsAllowed and doSaveAs
from the class DiagramDocumentEditor.
My problem is: I don't know what I have to do now.
I can not copy both files an save it under a new name, because the diagram
file have a relationship to the modelfile.
Thank you for your help
Urs
Re: save as. How can I make a copy from the model and diagram file? [message #237367 is a reply to message #237342] Fri, 24 July 2009 03:29 Go to previous messageGo to next message
Hello Urs,
See generated ???DocumentProvider.doSaveDocument() - saveAs is implemented
there (only diagram file model is copied now, so you can extend it to copy
domain model as well).
Alex Shatalin
Re: save as. How can I make a copy from the model and diagram file? [message #237433 is a reply to message #237367] Fri, 24 July 2009 10:09 Go to previous messageGo to next message
Hello Alex
Thank you for your answer
Ok, I can now copy the two files. My problem is actual the relationship
between the two files. If I only copy the files, the diagram file have the
relationship to the original modelfile. Have you a idea, how to bring the
two new files together?
Have a good weekend
Urs
"Alex Shatalin" <vano@borland.com> schrieb im Newsbeitrag
news:3c3172e62eef08cbda58514449f6@news.eclipse.org...
Re: save as. How can I make a copy from the model and diagram file? [message #237592 is a reply to message #237433] Mon, 27 July 2009 09:15 Go to previous messageGo to next message
Hello Urs,
As a simple solution you can just assign existing model content to new resource
and then save only this new resource (without saving original one model information
will not be removed from there) like:
Resource newModelResource = diagramDocument.getEditingDomain().getResourceSet().createRe source(newModelResoruceURI);
newModelResource.getContents().addAll(diagramDocument.getDia gram().getElement().eResource().getContents())
newModelResource.save(EcoreDiagramEditorUtil.getSaveOptions( ));
Alex Shatalin
Re: save as. How can I make a copy from the model and diagram file? [message #237604 is a reply to message #237592] Mon, 27 July 2009 09:55 Go to previous messageGo to next message
Hello Alex
No, that is not my problem. I can copy the model and diagram file.
The situation:
Model file origModel
Diagram file origDiag
Now I copy the two and I have now two new file:
Model file copyModel
Diagram file copyDiag
The Problem is now. The file copyDiag has a reference to origModel.
<element xmi:type="model.model:AuxVariable"
href="origModel#//@allAuxVariable.0"/>
I make the copy from the model and diagram by using the methode
EcoreUtil.copy
After that I add the EObject to a resource and the Diagram to a resource and
save it.
Now, I found no way to replace this href with the correct copyModel ref.
Have you any idea.
Thank you for your help.
Urs
Re: save as. How can I make a copy from the model and diagram file? [message #237616 is a reply to message #237604] Mon, 27 July 2009 10:05 Go to previous messageGo to next message
Hello Urs,
Right. This is because original diagram was referencing old model.. If you
MOVE domain model from original resource to new one then the all references
in loaded diagram (or even diagram copy) should be updated automatically.
Try using the code sniped I posted above before saving diagram resource copy.
Alex Shatalin
Re: save as. How can I make a copy from the model and diagram file? [message #237645 is a reply to message #237616] Mon, 27 July 2009 11:12 Go to previous message
Hello Alex
You are the best!!
Thank you
Have a good time
Urs
news:3c3172e62efd78cbdceb3fd79ac1@news.eclipse.org...
> Hello Urs,
> references in loaded diagram (or even diagram copy) should be updated
> automatically. Try using the code sniped I posted above before saving
> Alex Shatalin
Previous Topic:Fill/Font/Line styles added on View creation
Next Topic:Derived attribute without adding extra attr in metamodel
Current Time: Sat Jul 19 06:22:31 EDT 2025
Powered by FUDForum. Page generated in 9.56169 seconds
