Home » Modeling » GMF (Graphical Modeling Framework) » Workflow Engine configuration
Workflow Engine configuration [message #236407] Fri, 17 July 2009 17:17 Go to next message
Context: I'm working through the example in GMF eclipse series book.
There is an example in the book that lists a sample Worfklow file. This
sample has:
<component class="org.eclipse.xpand2.Generator">
<metaModel id="mm"
class="org.eclipse.xtend.typesystem.emf.EmfRegistryMetaModel " />
<expand value="pmw2csv::Main FOR model" />
<outlet path="${out}" />
</component>
Since in Eclipse 3.5 we're now using QVTO, is this correct? I 'm
thinking xtend isn't used any more?
I can't find any resources with samples for Workflow Engine
configurations for GMF 2.2. Any pointers much appreciated!
Re: Workflow Engine configuration [message #236907 is a reply to message #236407] Mon, 20 July 2009 10:09 Go to previous messageGo to next message
The workflow engine was just re-incorporated into the DSL Toolkit
http://download.eclipse.org/modeling/amalgam/dsltk/downloads /drops/S20090703
-0844/index.php using Galileo bits. So, it should be possible to use the
workflow examples from the book in Galileo (though I've not tried it).
You'll have to ping the EMFT newsgroup to get updated advice on using MWE,
I'm afraid.
But yes, I'd suggest using Ant to produce workflows using QVTO and GMF's
Xtext tasks. The only examples I have are the Amalgam build scripts, e.g.
http://dev.eclipse.org/viewcvs/index.cgi/org.eclipse.amalgam /releng/org.ecli
pse.amalgam.releng/generate.xml?root=Modeling_Project&vi ew=markup
On 7/17/09 5:17 PM, in article h3qpq1$or5$1@build.eclipse.org, "RefuX"
> sample has:
> <metaModel id="mm"
> </component>
Rich
Re: Workflow Engine configuration [message #236941 is a reply to message #236907] Mon, 20 July 2009 12:18 Go to previous messageGo to next message
> I'm afraid.
Well, I'm not sold on using the MWE, ANT is fine with me :)
Now I have this whole PackageNotFoundException I mention in my other
post. Oh well, it can't all be easy :) I will be studying you Amalgam
project to figure this one out as well I guess.
Note for others following in my footsteps:
1. Interestingly enough the eclipse.org/gmf/2008/xpand:template ant task
is not included in either the 3.5 DSLTK or the 3.5 Modelling Tools
releases. I had to download the standalone gmf xpand dist just to get
that plugin (org.eclipse.gmf.xpand.ant).
2. If ANT still complains it still can't find the above task, switch
your ANT JRE to the same as the workspace.
>> sample has:
>> <metaModel id="mm"
>> </component>
Re: Workflow Engine configuration [message #236947 is a reply to message #236941] Mon, 20 July 2009 13:44 Go to previous messageGo to next message
>> MWE,
>> I'm afraid.
>> e.g.
>>> sample has:
>>> <metaModel id="mm"
>>> </component>
Just to let you know, I was in a similar position a few weeks back.
I posted a lot of my adventures on the emft group, I got the MWE method
working eventually on Amalgam after loading MWE & M2T.
Strangely, my plugin works on Amalgam, JEE, Birt, C++ versions of
Galileo after I configured them them with MWE & M2T myself.
But doesn't produce output on the Modeling version of Galileo
(ie version with pre-configured GMF, MWE, Xpand etc)
Plus if you are using OS X there are also some gotchas.
If I could just the pesky filterexpression for CNF working I would
be happy - last thing to do!
regards
Steve
Re: Workflow Engine configuration [message #236972 is a reply to message #236941] Mon, 20 July 2009 15:20 Go to previous messageGo to next message
On 7/20/09 12:18 PM, in article h425c0$j87$1@build.eclipse.org, "RefuX"
Same here.
Rich
Re: Workflow Engine configuration [message #236996 is a reply to message #236972] Mon, 20 July 2009 22:32 Go to previous messageGo to next message
> Same here.
While running my generate.xml ant script I'm getting NPE on some emf
class, when I try to debug off the Ant script it will not stop on any
breakpoints, so I can't debug it :(
Any hints on why this is the case? I've debugged code launched form Ant
a bazillion times and this is a first.
p.s. If I click on 'Run Configurations' there is no listing of any Ant
targets, they only way I can get to it is via a right click on
generate.xml? odd!
Re: Workflow Engine configuration [message #237065 is a reply to message #236996] Tue, 21 July 2009 06:24 Go to previous messageGo to next message
Try using 'External Tools Configuration' run option, and not 'Run
Configurations' to see the Ant targets.
Also, make sure under JRE tab you're using the 'Run in the same JRE as the
workspace' option.
On 7/20/09 10:32 PM, in article h439ca$uah$1@build.eclipse.org, "RefuX"
>> Same here.
> generate.xml? odd!
Rich
Re: Workflow Engine configuration [message #237167 is a reply to message #237065] Tue, 21 July 2009 23:58 Go to previous message
> workspace' option.
Course turns out you can't do that if you are wanting to debug a Ant
Task itself.
Lucky for me this is a documented issue:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=24130#c6
Comment 6 did the trick for me:
>You cannot have two Eclipse sessions working on the same workspace at
>the same time. You can import an existing project from one workspace
to > another using
> File >Import> Existing Project into Workspace.
>I would try this:
>launch a run-time workbench launch configuration on a new workspace
>target
>point it to a new workspace.
>import your project(s) as outlined above.
>Run your Ant builds and debug your Ant tasks using the host Eclipse
>session.
Previous Topic:Color transition on canvas
Next Topic:Show Preferences window in RCP
Current Time: Sat Jul 19 10:38:12 EDT 2025
Powered by FUDForum. Page generated in 0.06906 seconds
