Home » Modeling » GMF (Graphical Modeling Framework) » Accessing the GenModel nsUri
Accessing the GenModel nsUri [message #236379] Fri, 17 July 2009 10:10 Go to next message
I've come across a really strange issue with the Galileo release of GMF.
I have a plugin that has the following code:
import org.eclipse.gmf.codegen.gmfgen.GMFGenPackage;
System.err.println(GMFGenPackage.eNS_URI);
When I export my plugin from 3.4, install it and run it in 3.5 I get
http://www.eclipse.org/gmf/2008/GenModel
Now when I move my plugin source to 3.5 and run it there I get
http://www.eclipse.org/gmf/2009/GenModel (2009 instead of 2008)
I'm experiencing this in a clean Galileo Eclipse Modeling package
obtained here:
http://www.eclipse.org/downloads/download.php?file=/technolo gy/epp/downloads/release/galileo/R/eclipse-modeling-galileo- incubation-win32.zip
Strangely enough, substituting the offending line with
System.err.println(GMFGenPackage.eINSTANCE.getNsURI());
prints (the expected)
in both cases.
Any thoughts on this would be appreciated...
Dimitris
Re: Accessing the GenModel nsUri [message #236894 is a reply to message #236379] Mon, 20 July 2009 09:54 Go to previous messageGo to next message
Hello Dimitris,
In GMF 2.2 we've changed GMFGenPackage NS URI to http://www.eclipse.org/gmf/2009/GenModel.
If you compile plugin with previouse version of GMF then constants will be
inlined by Java compiler, so
call will be represented as:
System.err.println("http://www.eclipse.org/gmf/2008/GenModel");
in bytecode. This is a reqson why you can see http://www.eclipse.org/gmf/2008/GenModel
line printed with Gallileo 3.5 by System.err.println(GMFGenPackage.eNS_URI);
compiled in 3.4
Be careful using static constants wich can be changed with plugin version...
Alex Shatalin
Re: Accessing the GenModel nsUri [message #237041 is a reply to message #236894] Tue, 21 July 2009 05:12 Go to previous message
Hi Alex,
Many thanks for your response. That's what I originally thought but when
I decompiled the .class from the jar, the value wasn't inlined in the
decompiled source. Then I thought that perhaps the compiler inlines it
but also maintains some metadata in the .class file which the decompiler
then uses to recover the name of the constant.
I've also confirmed that this is not the case with plain vanilla command
line javac so this must be an (unfortunate) optimization of the Eclipse
Java compiler. I'll look into this a bit more and let you know how it goes.
Dimitris
Alex Shatalin wrote:
> Hello Dimitris,
> be inlined by Java compiler, so
> http://www.eclipse.org/gmf/2008/GenModel line printed with Gallileo 3.5
> by System.err.println(GMFGenPackage.eNS_URI); compiled in 3.4
> version...
> Alex Shatalin
Previous Topic:Generating diagram code in build process
Next Topic:Problem with Affixed Parent Side
Current Time: Sun Jul 20 07:49:15 EDT 2025
Powered by FUDForum. Page generated in 0.03085 seconds
