Home » Modeling » GMF (Graphical Modeling Framework) » Why are my adapters being removed when I'm using diagram partitioning? ...and how to listen to the c
Why are my adapters being removed when I'm using diagram partitioning? ...and how to listen to the c [message #236238] Wed, 15 July 2009 14:45 Go to next message
Originally posted by: rene.boettge.gmx.net
I'm still new on GMF :-)
I'm working with galileo...
I have a GMF editor and I'm using diagram partitioning(one model for
both editors).
After a double-click opens a new editor but all my adapters I added
before to the elements in der first editor are being removed (I get a
notification "REMOVING_ADAPTERS") ... but why are they being removed? I
need them to be adapted because I have a view which listens to them...
when I accepted that they obviously have to be removed I decided to
listen to the change of the active editor. So I can add my adapter again
when certain editor (the first one) is active again... but how can
listen to this change?
I need this because my next step is to avoid a dirty editor so I want to
save the content of an editor if another is getting active.
Thanks in advance for some hints to solve my problems.
René
Re: Why are my adapters being removed when I'm using diagram partitioning? ...and how to listen to t [message #236246 is a reply to message #236238] Wed, 15 July 2009 14:56 Go to previous messageGo to next message
Hi René,
concerning your change problem an implementation of IPartListener could
be what you are searching for. Write a class which implements this
interface. Something like this.
public class MyPartListener implements IPartListener
public void partActivated(IWorkbenchPart part)
System.out.println("do something");
public void partBroughtToTop(IWorkbenchPart part)
public void partClosed(IWorkbenchPart part)
public void partDeactivated(IWorkbenchPart part)
public void partOpened(IWorkbenchPart part)
Than just add this implementation to the page which holds your editor.
This could be done in your editor's init method.
public void init(IEditorSite site, IEditorInput input) throws
PartInitException
IPartListener partListener = new MyPartListener();
site.getPage().addPartListener(partListener);
Now you can react on the event when you switch between the tabs of you
opened editors. Hope that helps.
Martin
René Böttge schrieb:
> both editors).
> René
Re: Why are my adapters being removed when I'm using diagram partitioning? ...and how to listen to t [message #236260 is a reply to message #236238] Thu, 16 July 2009 05:52 Go to previous messageGo to next message
Originally posted by: janapureddy.gmail.com
I have the same problem. This link could help you further...
https://bugs.eclipse.org/bugs/show_bug.cgi?id=249717
Ravi
> both editors).
> René
Re: Why are my adapters being removed when I'm using diagram partitioning? ...and how to listen to t [message #236438 is a reply to message #236260] Sun, 19 July 2009 15:41 Go to previous messageGo to next message
Thanks for the replies,
but this bug doesn't really cover my problem(or question) because I
don't have any problem with graphical elements...my added adapters are
being removed during opening my second editor
René
Ravi Jan schrieb:
> Ravi
>> Hi,
>> both editors).
>> I need them to be adapted because I have a view which listens to them...
>> again when certain editor (the first one) is active again... but how
>> can listen to this change?
>> to save the content of an editor if another is getting active.
>> René
Re: Why are my adapters being removed when I'm using diagram partitioning?...and how to listen to th [message #236512 is a reply to message #236238] Mon, 20 July 2009 08:41 Go to previous messageGo to next message
Hello René,
I think adapters were removed because of resetting editor input (model elements
were reloaded from file again.. Where do you attach adapters to model elements?
Alex Shatalin
Re: Why are my adapters being removed when I'm using diagram partitioning?...and how to listen to th [message #237154 is a reply to message #236512] Tue, 21 July 2009 14:20 Go to previous messageGo to next message
Hi Alex,
I'm not sure if it is the best way to solve but I add the adapter in
handleEventNotification() of my ***CanonicalEditPolicy because this is
one possibility to notice when a new element was added... or is there a
better way?
Thanks in advance.
René
Alex Shatalin schrieb:
> Hello René,
> elements were reloaded from file again.. Where do you attach adapters to
> model elements?
> Alex Shatalin
Re: Why are my adapters being removed when I'm using diagram partitioning?...andhow to listen to the [message #237190 is a reply to message #237154] Wed, 22 July 2009 05:28 Go to previous message
Hello René,
I doubt this method will be called on starting the editor for each diagram
element..
I think you have to initially traverse the model attaching corresponding
adapters in one of ???DocumentProvider + handle appropriate notifications.
Alex Shatalin
Previous Topic:Show Preferences window in RCP
Next Topic:Created a tutorial on using Xpand and QVT to transform model to text file.
Current Time: Sat Jul 19 11:46:17 EDT 2025
Powered by FUDForum. Page generated in 0.04696 seconds
