Home » Language IDEs » Java Development Tools (JDT) » Using AST to parse my code with eclipse 3.2
Using AST to parse my code with eclipse 3.2 [message #235877] Wed, 13 September 2006 21:39 Go to next message
Originally posted by: diegobt.gmail.com
Hi All:
I want to use Eclipses ASTParser to parse a .java and generate an AST to
print it.
After reading this
http://www-128.ibm.com/developerworks/opensource/library/os- ast/?ca=dgr-lnxw97ASTParser
I tried to get this snippet to do it.
File file = new File("ClassA.java");
BufferedReader in = new BufferedReader(new FileReader(file));
StringBuffer buffer = new StringBuffer();
String line = null;
while (null != (line = in.readLine())) {
buffer.append("\t" + line);
buffer.append("\n");
ASTParser parser = ASTParser.newParser(AST.JLS2);
parser.setKind(ASTParser.K_COMPILATION_UNIT);
String text = buffer.toString();
parser.setSource(text.toCharArray());
CompilationUnit node = (CompilationUnit) parser.createAST(null);
ASTVisitor visitor = new ASTPrintVisitor();
node.accept(visitor);
But I get this:
Exception in thread "main" java.lang.NoClassDefFoundError:
org/eclipse/core/runtime/Plugin
at java.lang.ClassLoader.defineClass1(Native Method)
at java.lang.ClassLoader.defineClass(ClassLoader.java:620)
at
java.security.SecureClassLoader.defineClass(SecureClassLoade r.java:124)
at java.net.URLClassLoader.defineClass(URLClassLoader.java:260)
at java.net.URLClassLoader.access$100(URLClassLoader.java:56)
at java.net.URLClassLoader$1.run(URLClassLoader.java:195)
at java.net.URLClassLoader.findClass(URLClassLoader.java:188)
at java.lang.ClassLoader.loadClass(ClassLoader.java:306)
at sun.misc.Launcher$AppClassLoader.loadClass(Launcher.java:268 )
at java.lang.ClassLoader.loadClass(ClassLoader.java:251)
at java.lang.ClassLoader.loadClassInternal(ClassLoader.java:319 )
at
org.eclipse.jdt.core.dom.ASTParser.initializeDefaults(ASTPar ser.java:230)
at org.eclipse.jdt.core.dom.ASTParser.<init>(ASTParser.java:212)
at org.eclipse.jdt.core.dom.ASTParser.newParser(ASTParser.java: 112)
at ASTPrint.main(ASTPrint.java:18)
I've been debugging it but cant figure out what to do. Perhaps someone
could help me out.
Thanks in advance!
/diego
Re: Using AST to parse my code with eclipse 3.2 [message #235887 is a reply to message #235877] Thu, 14 September 2006 04:37 Go to previous messageGo to next message
This error means you are running your code outside an instance of
running Eclipse (this is why the plugin layer isn't initialized).
This being said, since 3.2M6, we allow creating DOM ASTs outside Eclipse
with some limitation (no binding). Please check
https://bugs.eclipse.org/bugs/show_bug.cgi?id=87852 and see if you
deviate from the scenario supported there.
Diego Tiscornia wrote:
> Hi All:
> print it.
> After reading this
> String line = null;
> But I get this:
> at
> at java.security.AccessController.doPrivileged(Native Method)
> at
> could help me out.
> Thanks in advance!
> /diego
Re: Using AST to parse my code with eclipse 3.2 [message #658561 is a reply to message #235877] Tue, 08 March 2011 19:58 Go to previous message
You are missing "org.eclipse.core.resources" as one of the main thread's dependency.
Previous Topic:Content Assist [Intellisense] Sending Machine to 100% CPU
Next Topic:"create project from existing source" option
Current Time: Sun Jul 20 06:26:29 EDT 2025
Powered by FUDForum. Page generated in 0.03514 seconds
