Home » Modeling » GMF (Graphical Modeling Framework) » Diagram Runtime Class must be a notation::Diagram or sub-class
Diagram Runtime Class must be a notation::Diagram or sub-class [message #235279] Sun, 05 July 2009 11:45 Go to next message
I developed my DSL originally using the Amalgam toolkit, latest version.
However, when I import my projects from Amalgam to Galileo and run the
genmodel I get an error straight away
Source generator model is not completely ok, would you like to proceed?
Reason
Diagnosos of Gen Editor ...
In the details there is a lot of validation fails unexpectedly for 'Gen
Diagram ..'
for every node & container.
This works in Amalgam, if I generate plugins in Amalgam and load them in
Galileo they work. I developed my UI on Galileo since I used m2t Xpand
and MWE and I couldn't install m2t xpand on amalgam. If I run the
imported projects in the Galileo runtime, no problem. Only regenerating
causes a problem. All validations are OK.
From my use of mwe & xpand I recognise notation::Diagram as something
from notation.ecore in the GMF runtime. Any idea whats wrong - config?
regards
Steve
Re: Diagram Runtime Class must be a notation::Diagram or sub-class [message #235357 is a reply to message #235279] Mon, 06 July 2009 05:51 Go to previous messageGo to next message
Hello Bill,
Looks like some meta-model(s) was referenced using incorrect URIs (platform:/plugin
instead of NSURI).
Alex Shatalin
Re: Diagram Runtime Class must be a notation::Diagram or sub-class [message #235387 is a reply to message #235357] Mon, 06 July 2009 06:20 Go to previous messageGo to next message
Thanks Alex
I did notice that the bottom of the genmodel when opened in its editor
has a ref to notation.ecore. Any idea where I might start to look to
resolve this?
regards
Steve
Alex Shatalin wrote:
> Hello Bill,
> (platform:/plugin instead of NSURI).
> Alex Shatalin
Re: Diagram Runtime Class must be a notation::Diagram or sub-class [message #235475 is a reply to message #235387] Tue, 07 July 2009 06:05 Go to previous messageGo to next message
Hello Bill,
Was it referenced as platform:/plugin? Or platform:/resource?
> resolve this?
in corresponding .gmfgen model - you have to check references to a notation.ecore
elements there.
Alex Shatalin
Re: Diagram Runtime Class must be a notation::Diagram or sub-class [message #235685 is a reply to message #235475] Wed, 08 July 2009 16:04 Go to previous messageGo to next message
I found out the problem here.
symptoms:
If I deleted the genmodel and created a new one, then deleted my gmfgen
and generated a new one. Then if I started to generate my diag code I
got this error.
Solution:
I found I had org.eclipse.core.runtime in my dsl model project.
If I deleted this and regenerated, everything worked!
I had been playing around getting the xpand code editor working in the
past few weeks and it must have got in there then?
Now working again ;-) Fortunately I had an instances of working projects
and apple time machine/capsule
regards
Steve
> Hello Bill,
>> resolve this?
> notation.ecore elements there.
> Alex Shatalin
Re: Diagram Runtime Class must be a notation::Diagram or sub-class [message #235788 is a reply to message #235475] Thu, 09 July 2009 08:51 Go to previous messageGo to next message
Hmm
I'm still getting this..., thought I fixed it.
I went back and started all the way from ecore and regenerated
everything
In the the gmfgen file which is freshly generated
href=" ../../../plugin/org.eclipse.gmf.runtime.notation/model/notat ion.genmodel#//notation/Node "/>
note NOT platform:/plugin
regards
Steve
> Hello Bill,
>> resolve this?
> Alex Shatalin
Re: Diagram Runtime Class must be a notation::Diagram or sub-class [message #235868 is a reply to message #235788] Thu, 09 July 2009 14:19 Go to previous messageGo to next message
Hello Bill,
> genmodel#//notation/Node"/>
it's relative reference from the URI of the current file to platform:/plugin...
Alex Shatalin
Re: Diagram Runtime Class must be a notation::Diagram or sub-class [message #235908 is a reply to message #235868] Fri, 10 July 2009 05:43 Go to previous message
> Hello Bill,
> platform:/plugin...
> Alex Shatalin
Thanks Alex
I think I may have found something.
I noticed that when I imported on a clean copy of amalgam everything
works fine.
But I have two projects which use the same ecore,genmodel but have
different names and ID's etc. When only one set of projects is open
everything is fine, but if I open both my editors show errors. (both
are based on the EMF-GMF joint domain). It seems if I stay on amalgam
and only keep one open then I'm OK. Presumably a config issue?
One project was the original, the other was refactored from the other
(I changed the id's etc)
regards
Steve
Previous Topic:How to put two labels on the same line in a rectangle ?
Next Topic:Compartment question
Current Time: Sun Jul 20 14:07:02 EDT 2025
Powered by FUDForum. Page generated in 0.04913 seconds
