Home » Modeling » GMF (Graphical Modeling Framework) » How to put two labels on the same line in a rectangle ?
How to put two labels on the same line in a rectangle ? [message #235720] Thu, 09 July 2009 05:54 Go to next message
Hello all! (its my first post :p)
I have one rectangle containing different attributes and i have to put in
each line the type of the attribute and the value of the attribute. I have
tried several things but no one is working :-(
Thanks a lot for the answers ;)
Re: How to put two labels on the same line in a rectangle ? [message #235742 is a reply to message #235720] Thu, 09 July 2009 06:54 Go to previous messageGo to next message
Hello Geoffroy,
If type is just string property of this attribute then you can use labelmapping
with message format for it.
Alex Shatalin
Re: How to put two labels on the same line in a rectangle ? [message #235781 is a reply to message #235742] Thu, 09 July 2009 08:37 Go to previous messageGo to next message
yes ok i think i didn't have correctly writed my problem.
I have a figure descriptor containing a rectangle
In this rectangle I have to put 2 labels but these two labels have to be
in the same line. Currently when i put these two labels they are just one
bellow the other in the rectangle in two different line...
Re: How to put two labels on the same line in a rectangle ? [message #235855 is a reply to message #235781] Thu, 09 July 2009 12:20 Go to previous messageGo to next message
> one bellow the other in the rectangle in two different line...
Hi Geoffroy,
In your gmfgrah you must have only one Diagram Label (one Diagram Label
to one line) and in your gmfgraph your create a Feature Label Mapping
mapping your previous Diagram Label to all your EAttribute features by
using View, Edit and Editor Pattern.
Re: How to put two labels on the same line in a rectangle ? [message #235881 is a reply to message #235781] Thu, 09 July 2009 14:23 Go to previous message
Hello Geoffroy,
Try setting layout (FlowLayout, isVertical == false) for the rectangle figure
containing both labels.
Alex Shatalin
Previous Topic:"Invalid view - remove from diagram" on diagrams created with older GMF opened in latest G
Next Topic:Diagram Runtime Class must be a notation::Diagram or sub-class
Current Time: Sat Jul 19 15:03:05 EDT 2025
Powered by FUDForum. Page generated in 0.24180 seconds
