Home » Modeling » GMF (Graphical Modeling Framework) » HowTo realize something like a multiline textfield in GMF?
HowTo realize something like a multiline textfield in GMF? [message #235605] Wed, 08 July 2009 05:51 Go to next message
I would like to have a multiline textfield (preferably reziseable with
line breaks) in my GMF editor - like the notes I can attach in every GMF
editor. How can I realize something like this?
Greetings,
Ralf
Re: HowTo realize something like a multiline textfield in GMF? [message #235618 is a reply to message #235605] Wed, 08 July 2009 06:31 Go to previous messageGo to next message
i found a TextCompartmentEditPart, which your compartment should extend.
But i don't know how to get the TextCompartmentEditPart automatically
generated. Does somebody know how to do this?
Greetings
Ralf Buschermoehle schrieb:
> Hello,
> Greetings,
> Ralf
Re: HowTo realize something like a multiline textfield in GMF? [message #235624 is a reply to message #235605] Wed, 08 July 2009 07:46 Go to previous messageGo to next message
Hello Ralf,
Can you please file bugzilla request asking to add multiline labels support
to gmf code generation?
For now to make a label multiline you have to:
1. Modify code creating new WrappingLabel and call labelFigure.setTextWrap(true);
2. Modify generated label EditPart.getManager() to call
setManager(new TextDirectEditManager(this, WrapTextCellEditor.class, ???EditPartFactory.getTextCellEditorLocator(this)));
instead of generated:
setManager(new TextDirectEditManager(this, TextDirectEditManager.getTextCellEditorClass(this),
Alex Shatalin
Re: HowTo realize something like a multiline textfield in GMF? [message #235631 is a reply to message #235624] Wed, 08 July 2009 08:15 Go to previous messageGo to next message
Thanks, that helped. :)
Do your know how to enable text formating(like alignment right) in gmf?
And additionally if it is possible to color/underline/etc. parts of the
label text?
Greetings,
Joerg
Alex Shatalin schrieb:
> Hello Ralf,
> support to gmf code generation?
> Alex Shatalin
Re: HowTo realize something like a multiline textfield in GMF? [message #235638 is a reply to message #235624] Wed, 08 July 2009 08:41 Go to previous messageGo to next message
Hi Alex,
Joerg was faster ... ;)
Thanks - this works ... but the additional questions from Joerg are very
interesting, too :)
the label text?
Greetings,
Ralf
Re: HowTo realize something like a multiline textfield in GMF? [message #235714 is a reply to message #235631] Thu, 09 July 2009 05:42 Go to previous messageGo to next message
Hello Jörg,
> gmf?
There is an operation "setAlignment()" in WrappingLabel class, but is doesn't
work for my diagram.
Concerning rich text formatting in label - there is no such a control in
GEF/GMF AFAIK.
Alex Shatalin
Re: HowTo realize something like a multiline textfield in GMF? [message #235749 is a reply to message #235714] Thu, 09 July 2009 07:01 Go to previous messageGo to next message
Hi Alex,
> GEF/GMF AFAIK.
I tried using StyledText (instead of Text) in
* A cell editor that manages a text entry field.
* The cell editor's value is the text string itself.
* <p>
* This class may be instantiated; it is not intended to be subclassed.
* </p>
* @noextend This class is not intended to be subclassed by clients.
public class (now: Styled) TextCellEditor extends CellEditor {
* The text control; initially <code>null</code>.
protected StyledText text; <--
private ModifyListener modifyListener;
.... with corresponding changes is TextCellEditorEx.java and
WrapTextCellEditor.java. Unfortunately a can't edit the created
StyledTextControl.
Any Hints?
Greetings,
Ralf
Re: HowTo realize something like a multiline textfield in GMF? [message #235834 is a reply to message #235749] Thu, 09 July 2009 11:26 Go to previous message
after some additional changes I am stuck at the point where GMF takes
over control ... and tries to cast to
org.eclipse.swt.custom.StyledText cannot be cast to
org.eclipse.swt.widgets.Text at
org.eclipse.gmf.runtime.diagram.ui.tools.TextDirectEditManag er.setEditText(TextDirectEditManager.java:468)
Maybe it is a good idea to support directly StyledText instead of Text
for labels?
Greetings,
Ralf
Ralf Buschermoehle wrote:
> Hi Alex,
>> in GEF/GMF AFAIK.
> * <p>
> * </p>
> StyledTextControl.
> Any Hints?
> Greetings,
> Ralf
Previous Topic:Open diagram impractical with new WrappingLabel
Next Topic:"Invalid view - remove from diagram" on diagrams created with older GMF opened in latest G
Current Time: Sun Jul 20 03:06:38 EDT 2025
Powered by FUDForum. Page generated in 0.04136 seconds
