Home » Eclipse Projects » GEF » Plugin not shown in Gef Example plugins
Plugin not shown in Gef Example plugins [message #235334] Mon, 11 June 2007 04:24 Go to next message
Originally posted by: chaitannyam.yahoo.co.uk
hi to All,
i load the schema editor and follow the process
written in it.but it is not shown in Gef Example plugins.wht will be problem
Re: Plugin not shown in Gef Example plugins [message #235463 is a reply to message #235334] Tue, 12 June 2007 11:01 Go to previous messageGo to next message
Hi Chaitannya
You are saying you tried the example from
http://www.eclipse.org/articles/Article-GEF-editor/gef-schem a-editor.html
and it did not work?
Cheers...
Anthony
"chaitannya" <chaitannyam@yahoo.co.uk> wrote in message
news:375570572.5961181550276354.JavaMail.root@cp9.dzone.com...
> hi to All,
> will be problem
Re: Plugin not shown in Gef Example plugins [message #235513 is a reply to message #235463] Wed, 13 June 2007 01:20 Go to previous messageGo to next message
hello Anthony,
yes wht u understood exact problem was same.alternatively when i make a plugin from existing project
and run it. it gives error:
1.The type org.eclipse.ui.part.EditorPart cannot be resolved. It is indirectly referenced from required .class files
2.The project was not built since its build path is incomplete. Cannot find the class file for org.eclipse.ui.part.EditorPart. Fix the build path then try building this project com.realpersist.gef.schemaeditor Unknown
Need Tip : Collapse / Expand in GEF [message #235542 is a reply to message #235334] Wed, 13 June 2007 05:33 Go to previous message
Originally posted by: hzfalcon.gmail.com
Hi Team
I will create some figures in GEF according to a pile of XML-files,
which could be a complex tree-structure ( logic layer ).. So i need to
implement following function:
On any Node, which has min. 1 sub-Node , there must be a littel icon (
+/-) , so that the user can collapse/expand here ( just like windows
explorer, or Schema editing in XML-Spy )..
please give me some tips( how should I begin .. ) if anyone knows about it..
Thanks a lot
HzFalcon
Stuttgart, DE
Previous Topic:How to use GraphicalViewer in Viewpart
Next Topic:Need Tip : Collapse / Expand in GEF
Current Time: Sun Jul 20 19:50:05 EDT 2025
Powered by FUDForum. Page generated in 0.03737 seconds
