Home » Newcomers » Newcomers » How can I display non-english characters in view and editor parts
How can I display non-english characters in view and editor parts [message #234972] |
Thu, 27 September 2007 10:33  |
Originally posted by: wjfang.gmail.com
I know there is a language package to translate all menus, actions, etc. to
non-english, such as chinese. That is not what I want. I want to simply
display chinese in view part or editor part. How can I achieve it? Thanks a
lot!
Weijian
Re: How can I display non-english characters in view and editor parts [message #235001 is a reply to message #234989] |
Thu, 27 September 2007 11:06   |
Hi Ed,
> Java support full unicode so given that your OS has the available fonts to
> display the Chinese characters that you tell Eclipse to display, this
> should just work.
This was what i thought. But it seems does not work like this.
I created (not using eclipse) a chinese.txt that contains chinese charaters.
I can use notepad to open it and read its chinese. But when i used eclispe
to open it, I can not read the chinese.
When I create a text file containing chinese using eclipse, it does display
chinese. But when I try to save it, I saw a message dialog saying "save
could not be completed. some characters cannot be mapped using "Cp1252"
character encoding. "
Any idea? Thanks!
Weijian
> Weijian wrote:
>> Hi,
>> to non-english, such as chinese. That is not what I want. I want to
>> simply display chinese in view part or editor part. How can I achieve it?
>> Thanks a lot!
>> Cheers,
>> Weijian
Re: How can I display non-english characters in view and editor parts [message #235016 is a reply to message #235001] |
Thu, 27 September 2007 11:24   |
I see I need to set text file encoding to UTF-8 instead of using the default
cp1252.
How do i programmatically set the text file encoding?
Thanks.
"Weijian" <wjfang@gmail.com> wrote in message
news:fdggtm$nkf$1@build.eclipse.org...
> Hi Ed,
>> to display the Chinese characters that you tell Eclipse to display, this
>> should just work.
> charaters. I can use notepad to open it and read its chinese. But when i
> used eclispe to open it, I can not read the chinese.
> display chinese. But when I try to save it, I saw a message dialog saying
> "save could not be completed. some characters cannot be mapped using
> "Cp1252" character encoding. "
> Any idea? Thanks!
> Cheers,
> Weijian
>> Weijian wrote:
>>> Hi,
>>> it? Thanks a lot!
>>> Cheers,
>>> Weijian
Re: How can I display non-english characters in view and editor parts [message #235022 is a reply to message #235016] |
Thu, 27 September 2007 11:36  |
--------------080709090404010208010404
Weijian,
You can use IFile.setCharset. Note that you can use
Window->Preferences->General->Workspace to change the default encoding
for all text files. Folders and projects also support setting a default
encoding for the contained text files (which can be done
programmatically using IContainer.setDefaultCharset).
> cp1252.
> Thanks.
>> Hi Ed,
>>> should just work.
>> Any idea? Thanks!
>> Cheers,
>> Weijian
>>> Weijian wrote:
>>>> Hi,
>>>> it? Thanks a lot!
>>>> Cheers,
>>>> Weijian
Content-Type: text/html; charset=ISO-8859-1
<html>
<head>
</head>
Weijian,<br>
<br>
encoding for all text files. Folders and projects also support setting
a default encoding for the contained text files (which can be done
programmatically using IContainer.setDefaultCharset).<br>
<br>
<br>
Weijian wrote:
<blockquote cite="mid:fdghup$qgh$1@build.eclipse.org" type="cite">
<pre wrap="">I see I need to set text file encoding to UTF-8 instead of using the default
cp1252.
Thanks.
"Weijian" <a class="moz-txt-link-rfc2396E" href="mailto:wjfang@gmail.com"><wjfang@gmail.com></a> wrote in message
<a class="moz-txt-link-freetext" href="news:fdggtm$nkf$1@build.eclipse.org">news:fdggtm$nkf$1@build.eclipse.org</a>...
</pre>
<blockquote type="cite">
<pre wrap="">Hi Ed,
</pre>
<pre wrap="">Java support full unicode so given that your OS has the available fonts
should just work.
</pre>
</blockquote>
<pre wrap="">This was what i thought. But it seems does not work like this.
Any idea? Thanks!
Weijian
</pre>
<pre wrap="">Weijian wrote:
</pre>
<pre wrap="">Hi,
it? Thanks a lot!
Weijian
</pre>
</blockquote>
</blockquote>
<pre wrap="">
</pre>
</blockquote>
<pre wrap=""><!---->
</pre>
</blockquote>
<br>
</body>
</html>
--------------080709090404010208010404--
Current Time: Sun Jul 20 02:58:33 EDT 2025
Powered by FUDForum. Page generated in 0.08312 seconds
