Home » Eclipse Projects » GEF » anyone use SnapToGrid?
anyone use SnapToGrid? [message #234593] Thu, 24 May 2007 10:59 Go to next message
Originally posted by: bservice.comcast.net.nospam
I have a Graphical editor part that uses a GridLayer. On this GridLayer are
various draw2d rectangles. The user can drag these rectangles around on the
GridLayer.
I would like to use the SnapToGrid class to properly snap the rectangle onto
the grid squares when the user is done dragging. Any good example code out
there for implementing this behavior?
Re: anyone use SnapToGrid? [message #234607 is a reply to message #234593] Thu, 24 May 2007 16:57 Go to previous messageGo to next message
Hi Brian,
The GEF Logic Example demonstrates snap to grid support. Check out the View
main menu to turn on the Grid and Snap to Geometry.
Cheers...
Anthony
"Brian Service" <bservice@comcast.net>@nospam> wrote in message
news:f3498i$4eo$1@build.eclipse.org...
>are various draw2d rectangles. The user can drag these rectangles around
>on the GridLayer.
> onto the grid squares when the user is done dragging. Any good example
> code out there for implementing this behavior?
Re: anyone use SnapToGrid? [message #234620 is a reply to message #234607] Fri, 25 May 2007 08:37 Go to previous messageGo to next message
Anthony,
I must have an older version of the GEF logic example. There is no
snapToGrid functionality in the GEF logic example I had downloaded. I
noticed the source files have 2002 dates on them. Could you tell me where I
might get an updated version of the logic example?
Thanks, Brian
"Anthony Hunter" <anthonyh@ca.ibm.com> wrote in message
news:f34u84$jp6$1@build.eclipse.org...
> Hi Brian,
> View main menu to turn on the Grid and Snap to Geometry.
> Cheers...
> Anthony
>>on the GridLayer.
Re: anyone use SnapToGrid? [message #234627 is a reply to message #234620] Fri, 25 May 2007 10:22 Go to previous message
Nevermind. I downloaded the latest GEF 3.3RC1 and I can see the SnapToGrid
examples in the latest Logic example. Thanks again.
news:f36lap$vjn$1@build.eclipse.org...
> Anthony,
> I might get an updated version of the logic example?
> Thanks, Brian
>> Hi Brian,
>> Cheers...
>> Anthony
>>>on the GridLayer.
Previous Topic:Animation under OS X
Next Topic:Print GEF Diagrams present on both sides of the SPLITTER in a SashForm
Current Time: Sat Jul 19 12:57:38 EDT 2025
Powered by FUDForum. Page generated in 0.03039 seconds
