Home » Eclipse Projects » GEF » Making shapes invisible & layer question
Making shapes invisible & layer question [message #234157] Sat, 12 May 2007 09:15 Go to next message
Originally posted by: sebklemperama.yahoo.de
Hi Folks,
I'm relatively new to GEF, but I've already read many howtos and docs
about it. Unfortunately, two questions remain unanswered and I hope that
someone of you can help me.
I would like to draw shapes to a layer behind other figures. To do so, I
extended FreeformGraphicalRootEditPart and override createLayers, in
which I add a layer behind the primary layer (key is a string). But
where can I direct a shape to this layer? I guess this can be done by a
EditPoliy in the RootEditPart (extended FreeformGREP), but I don't know how.
My 2nd question is, how I can set a shape invisible. Setting the figure
to null seems to be dirty as setting the size to zero. Is there a better
way?
Thanks a lot for your help!
Many greeting,
Sebastian
Re: Making shapes invisible & layer question [message #234194 is a reply to message #234157] Mon, 14 May 2007 08:56 Go to previous message
> how.
I've found another thraed dealing with a similar question. Dave answered
the question with "Then you could add figures to that layer, for example
in your EditPart's activate() method and call
getLayer(YOUR_LAYER).setVisible()."
OK, I tried this, but, unsurprisingly it's inpossible to select the
figure. Is there another solution available?
> way?
This question can I answer myself when I know a solution for the first
problem. I would 'show' invisible shapes on an invisible layer.
Thank you,
Sebastian
Previous Topic:Adding context menu for Draw2d figures
Next Topic:Chopbox anchor feedback
Current Time: Sat Jul 19 18:26:18 EDT 2025
Powered by FUDForum. Page generated in 0.03713 seconds
