Home » Modeling » GMF (Graphical Modeling Framework) » extension point documentProviders
extension point documentProviders [message #234024] Thu, 18 June 2009 04:52 Go to next message
Hi everyone,
I'm trying to use the extension point
" org.eclipse.gmf.runtime.diagram.ui.resources.editor.document Providers "
but I don't seem to get it to work.
I guess it's just some silly mistake I make...
Here's what I do in custom plugin.xml:
<extension
point=" org.eclipse.gmf.runtime.diagram.ui.resources.editor.document Providers ">
<provider
extensions=".xxx_diagram"
class="org.xxx.CustomXxxDocumentProvider"
id="org.xxx.CustomXxxDocumentProvider">
</provider>
</extension>
The constructor of CustomXxxDocumentProvider does not get called when I
open/create a diagram file of type xxx_diagram.
extensions is "." + my diagram filename extension, also tried with model
filename extension
class org.xxx.CustomXxxDocumentProvider exists (plugin.xml validation
displays a warning otherwise).
It extends my generated XxxDocumentProvider which extens
AbstractDocumentProvider, implementing IDocumentProvider as requested.
Is there a way I can debug this, any log if there are problems with an
extension point?
Thanks in advance,
Peter
Re: extension point documentProviders [message #234072 is a reply to message #234024] Thu, 18 June 2009 07:54 Go to previous messageGo to next message
Hello Peter,
I suppose corresponding document provider is hadrcoded in generated ???DiagramEditor.getDocumentProvider(IEditorInput
input) method, so you have to modify generated code.
Alex Shatalin
Re: extension point documentProviders [message #234108 is a reply to message #234072] Thu, 18 June 2009 09:22 Go to previous messageGo to next message
Thank you, Alex,
Yes, looks like...
Does this extension point make any sense then?
Peter
Re: extension point documentProviders [message #234116 is a reply to message #234108] Thu, 18 June 2009 11:10 Go to previous messageGo to next message
Hello Peter,
If you need it (for extensibility) you can modify generated code to use it.
Alex Shatalin
Re: extension point documentProviders [message #234385 is a reply to message #234116] Mon, 22 June 2009 04:05 Go to previous messageGo to next message
Hi Alex,
Out of curiosity, could you provide an example / hint on how to do that?
Peter
Re: extension point documentProviders [message #234414 is a reply to message #234385] Mon, 22 June 2009 06:45 Go to previous messageGo to next message
Hello Peter,
You can comment out generated ???DiagramEditor.getDocumentProvider() method
so super implementation will be used (calling document provider registry).
Alex Shatalin
Re: extension point documentProviders [message #234450 is a reply to message #234414] Mon, 22 June 2009 09:18 Go to previous messageGo to next message
Hello Alex,
I tried it, but getDocumentProvider does not get called.
getDocumentProvider is not used, setDocumentProvider is called by
DiagramDocumentEditor.updateDocumentProvider.
So I changed setDocumentProvider to call
setDocumentProvider(super.getDocumentProvider(input));
in my XxxDiagramEditor.
In DocumentProviderRegistry.getDocumentProvider
editorInput.getAdapter(IFile.class) returns null, so file-extensions are
not used to find documentProvider.
Any idea what I could do?
Peter
Re: extension point documentProviders [message #234457 is a reply to message #234450] Mon, 22 June 2009 09:27 Go to previous messageGo to next message
Peter Lang wrote:
> Hello Alex,
Reason for this seems to be that URI.isPlatformResource() returns false,
since segments[0] is the first directory of my path, and not "resource".
> Peter
Re: extension point documentProviders [message #234642 is a reply to message #234457] Thu, 25 June 2009 05:35 Go to previous message
Do you know the reason for this?
Any workaround you could think of?
Peter
Previous Topic:Problems with label referencing a derived attribute
Next Topic:TargetMetaFeature
Current Time: Sun Jul 20 03:00:42 EDT 2025
Powered by FUDForum. Page generated in 0.06133 seconds
