Home » Eclipse Projects » GEF » Data Flow Diagram Editor
Data Flow Diagram Editor [message #233750] Tue, 01 May 2007 17:20 Go to next message
Originally posted by: coa03ysa.sheffield.ac.uk
I am currently building a data flow diagram editor using GEF. I have built
my model; I have designed the figures; and I have an editor, albeit an
empty one. I want to get the editor up and running. I have been advised to
associate a certain type of file extension with my editor, to create a
file with this extension and then to open it. However, I must admit that I
am still confused about exactly how to do this. I would appreciate any
advice on how to go about getting my editor up and running so that I can
demonstrate my work so far.
Many thanks,
Yvon Asafu-Adjaye
Re: Data Flow Diagram Editor [message #233758 is a reply to message #233750] Tue, 01 May 2007 20:19 Go to previous messageGo to next message
Hi Yvon,
You'd have to look very closely at GEF example editors. Most likely the
closest example to yours would be org.eclipse.gef.examples.flow (any other
like org.eclipse.gef.examples.logic is good too). Open up the plugin.xml
file from a GEF editor example plugin project in Eclipse, then open up
'Extensions' tab and look under org.eclipse.ui.editors extension point.
Now open up '(editor)' extension element - this is the one that defines
your editor for Eclipse. You should use the same extension in your editor
plugin to contribute it to Eclipse.
Hope this helps.
Alex
Re: Data Flow Diagram Editor [message #233806 is a reply to message #233758] Thu, 03 May 2007 07:18 Go to previous messageGo to next message
Originally posted by: coa03ysa.shef.ac.uk
Alex,
Thanks a lot for your advice. I've been ploughing through the flow diagram
example but unfortunately, I haven't managed to find the plugin.xml file
for it. I assume however, that the plugin.xml for my DFD editor would have
to extend the org.eclipse.ui.editors extension point. Please confirm if
this is correct; once again I'd be grateful for any advice you could give
to help me speed up the development. Many thanks.
Yvon
Re: Data Flow Diagram Editor [message #233876 is a reply to message #233806] Thu, 03 May 2007 22:30 Go to previous message
Hi Yvon,
Correct. You need to extend org.eclipse.ui.editors extension point in your
editor plugin to be able to associate your editor with a file extension in
Eclipse.
You can get gef example editors from CVS:
host: dev.eclipse.org
path: /cvsroot/tools
user: anonymous
password: (just blank, no need for password)
Under gef find org.eclipse.gef.examples.* plugins and check them out.
Hope this helps.
Alex
Previous Topic:GEF or GMF editor for Dynamic eCore models
Next Topic:Just a random Thank You!!! :-)
Current Time: Sat Jul 19 05:35:07 EDT 2025
Powered by FUDForum. Page generated in 0.25961 seconds
