Home » Modeling » GMF (Graphical Modeling Framework) » add .xpt template
add .xpt template [message #233305] Wed, 10 June 2009 10:37 Go to next message
Originally posted by: aurelien.pupier.esial.net
I want to add some template to generate custom files.
I can modify existing, I mean : I modify an existing .xpt, so the
generated class is correctly modified
But when I create a new .xpt file in order to generate a class... it
seems that the .xpt is not used...
The new .xpt files are in the same folder of existing templates.
The most strange is that at the first "generate diagram code", there was
a trace in the log which indicates errors but now there is no more trace
in the log at the "generate diagram code" invocation.
Is there something to do to consider the new .xpt files?
Thanks for any help
One of my new .xpt file(PropertySourceExtended.xpt) :
«IMPORT "http://www.eclipse.org/gmf/2008/GenModel
«IMPORT "http://www.eclipse.org/emf/2002/Ecore
«DEFINE Class FOR gmfgen::GenCustomPropertyTab»
«EXPAND xpt::Common::copyright FOR sheet.editorGen-»
package «sheet.packageName»;
«EXPAND xpt::Common::generatedClassComment»
public class PropertySourceExtended extends
org.eclipse.emf.edit.ui.provider.PropertySource implements
org.eclipse.ui.views.properties.IPropertySource{
«EXPAND createPropertyDescriptorMethod»
«ENDDEFINE»
«DEFINE createPropertyDescriptorMethod FOR gmfgen::GenCustomPropertyTab-»
«EXPAND xpt::Common::generatedMemberComment»
protected IPropertyDescriptor
createPropertyDescriptor(org.eclipse.emf.edit.provider.IItem PropertyDescriptor
itemPropertyDescriptor) {
return new PropertyDescriptorExtended(object,
itemPropertyDescriptor);
«ENDDEFINE»
Re: add .xpt template [message #233322 is a reply to message #233305] Wed, 10 June 2009 11:42 Go to previous messageGo to next message
Hello Aurelien,
You can override/aspect exisitng GMF templates, but if you created a new
one you have to either call it from any other existing (customized) GMf templates
- to inject corresponding code into GMf-generated files or call separate
generate code process (e.g. using ANT task) executing this template.
Alex Shatalin
Re: add .xpt template [message #233400 is a reply to message #233322] Thu, 11 June 2009 03:31 Go to previous messageGo to next message
Alex Shatalin a écrit :
> Hello Aurelien,
> templates - to inject corresponding code into GMf-generated files or
> call separate generate code process (e.g. using ANT task) executing this
> template.
> Alex Shatalin
OK, thanks.
So... some more question.
I think that I will call it from existing GMF templates... but need help
for that too
I looked there
http://www.openarchitectureware.org/pub/documentation/4.1/r2 0_xPandReference.pdf
and find that we can call an other definition in an other template file
if we specified the name of the template...
«EXPAND my::templates::TemplateFile::definitionName
FOR myModelElement»
So I try various things and I have some questions :
Where do I start the path? (my??)
What is the myModelElement? (gmfgen::GenCustomPropertyTab??)
info :
templates
-xpt
-propsheet
- existingTemplate.xpt where I put the EXPAND instruction [1]
- newTemplate.xpt with [2]
I thought it is something like that but it's seems not...
[1]
«EXPAND xpt::propsheet::newTemplate::Class
[2]
//what i want to generate
«ENDDEFINE»
Re: add .xpt template [message #233415 is a reply to message #233400] Thu, 11 June 2009 07:09 Go to previous messageGo to next message
Hello Aurelien,
In .gmfgen model there are two properties:
- GenEditorGenerator.Dynamic Templates (boolean)
- GenEditorGenerator.Template Directory (string) - see http://wiki.eclipse.org/GMF_GenModel_Hints#GenEditorGenerato r
So, you can:
- create new template in a file: /project1/customTemplates/folder1/TemplateFile.xpt
- set Template Directory to "/project1/customTemplates"
- use «EXPAND folder1::TemplateFile::definitionName FOR myModelElement» to
execute definition "definitionName" from this file.
myModelElement is a name of variable or reference/attribute. It's type can
be gmfgen::GenCustomPropertyTab. Here is an example from GMF templates:
public class «className» extends «EXPAND extendsList» «EXPAND implementsClause»{
«ENDDEFINE»
«EXPAND extendsList» is a way to call another definition with name "extendsList"
(defined in this file). This call is equivalent to: «EXPAND extendsList FOR
self» where "self" is a contextual parameter name (instanceof gmfgen::GenCustomPropertyTab).
If you need to call a definition using any feature of contextual parameter
you can use constructions like:
«EXPAND myDefinition FOR self.className»
the the following definition will be called:
«DEFINE myDefinition FOR String»
«ENDDEFINE»
where "String" is a type of gmfgen::GenCustomPropertyTab::className attribute
in the model. Instead of shortname of a definition located in same file you
can use full name like: myFolder::MyTemplate::myDefinition
> [1]
It should be something like:
«EXPAND xpt::propsheet::newTemplate::Class FOR self.customPropertyTab»
Alex Shatalin
Re: add .xpt template [message #233468 is a reply to message #233415] Thu, 11 June 2009 09:03 Go to previous messageGo to next message
> Hello Aurelien,
> So, you can:
I create here :
\org.ow2.jasmine.design.gmf.codegen\templates\xpt\propsheet\ PropertySourceExtended.xpt
set to : /org.ow2.jasmine.design.gmf.codegen/templates
> to execute definition "definitionName" from this file.
in
«ENDDEFINE»
and in
org.ow2.jasmine.design.gmf.codegen\templates\xpt\propsheet\P ropertySection.xpt
(which already exists) :
«EXPAND xpt::propsheet::PropertySourceExtended::Class FOR
self.customPropertyTab» [1]
implementsClause»{
«EXPAND getPropertySourceMethod»
«IF sheet.readOnly»
«EXPAND createReadonlyControlsMethod»
«ENDIF»
«EXPAND getPropertySourceProviderMethod»
«EXPAND transfromSelectionMethod»
«EXPAND setInputMethod»
«EXPAND getAdapterFactoryMethod»
«EXPAND additions»
«ENDDEFINE»
[...]the definition of EXPANDs
> can be gmfgen::GenCustomPropertyTab. Here is an example from GMF templates:
> implementsClause»{
> «ENDDEFINE»
> "extendsList" (defined in this file). This call is equivalent to:
> «EXPAND extendsList FOR self» where "self" is a contextual parameter
> name (instanceof gmfgen::GenCustomPropertyTab). If you need to call a
> definition using any feature of contextual parameter you can use
> constructions like:
> «ENDDEFINE»
> attribute in the model. Instead of shortname of a definition located in
> same file you can use full name like: myFolder::MyTemplate::myDefinition
>> [1]
I've got this error :
Unknown GenCustomPropertyTab property, variable, type or enumeration
literal 'self' on line [1]
> Alex Shatalin
Re: add .xpt template [message #233477 is a reply to message #233468] Thu, 11 June 2009 09:08 Go to previous messageGo to next message
Hello Aurelien,
> and in
> tion.xpt
Try «EXPAND xpt::propsheet::PropertySourceExtended::Class» instead
Alex Shatalin
Re: add .xpt template [message #233500 is a reply to message #233477] Thu, 11 June 2009 10:25 Go to previous messageGo to next message
> Hello Aurelien,
>> and in
>> tion.xpt
OMG
> Alex Shatalin
thanks a lot!!
Now the code is well-generated but... in the same file that it is
called. or I want to generate a new file
I tried to create a new file with :
«FILE 'templates/xpt/propsheet/PropertySourceExtended.java'»
«ENDFILE»
//also tried with TO_SRC
But I catch this error while generating :
java.lang.UnsupportedOperationException: OPEN FILE
('templates/xpt/propsheet/PropertySourceExtended.java', null)
at
org.eclipse.gmf.internal.xpand.BufferOutput.openFile(BufferO utput.java:44)
at
org.eclipse.gmf.internal.xpand.ast.FileStatement.evaluateInt ernal(FileStatement.java:81)
at org.eclipse.gmf.internal.xpand.ast.Statement.evaluate(Statem ent.java:30)
at
org.eclipse.gmf.internal.xpand.ast.AbstractDefinition.evalua te(AbstractDefinition.java:94)
at
org.eclipse.gmf.internal.xpand.ast.ExpandStatement.invokeDef inition(ExpandStatement.java:190)
at
org.eclipse.gmf.internal.xpand.ast.ExpandStatement.evaluateI nternal(ExpandStatement.java:161)
at
at org.eclipse.gmf.internal.xpand.XpandFacade.evaluate(XpandFac ade.java:60)
at
org.eclipse.gmf.internal.common.codegen.XpandTextEmitter.gen erate(XpandTextEmitter.java:64)
at
org.eclipse.gmf.internal.common.codegen.GeneratorBase.doGene rateJavaClass(GeneratorBase.java:335)
at
org.eclipse.gmf.codegen.util.Generator.internalGenerateJavaC lass(Generator.java:1006)
at
org.eclipse.gmf.codegen.util.Generator.internalGenerateJavaC lass(Generator.java:1010)
at
org.eclipse.gmf.codegen.util.Generator.generatePropertySheet Sections(Generator.java:857)
at org.eclipse.gmf.codegen.util.Generator.customRun(Generator.j ava:259)
at
org.eclipse.gmf.internal.common.codegen.GeneratorBase$1.run( GeneratorBase.java:474)
at org.eclipse.core.internal.resources.Workspace.run(Workspace. java:1800)
at org.eclipse.core.internal.resources.Workspace.run(Workspace. java:1782)
at
org.eclipse.gmf.internal.common.codegen.GeneratorBase.doRun( GeneratorBase.java:471)
at
org.eclipse.gmf.internal.common.codegen.GeneratorBase.run(Ge neratorBase.java:90)
at
org.eclipse.gmf.internal.codegen.popup.actions.ExecuteTempla tesOperation.run(ExecuteTemplatesOperation.java:182)
at
org.eclipse.jface.operation.ModalContext$ModalContextThread. run(ModalContext.java:121)
Re: add .xpt template [message #233509 is a reply to message #233500] Thu, 11 June 2009 11:10 Go to previous messageGo to next message
Hello Aurelien,
Rigth. FILE directive is not supported in GMF xpand.
This is why I said you in the very first letted that you probably have to
use ANT task for it.
Another option is to extend org.eclipse.gmf.codegen.util.Generator, create
custom popup menu action using this class for code generation, deploy everything
to currently running platform and use this action for diagram code generation.
Alex Shatalin
Re: add .xpt template [message #233517 is a reply to message #233509] Thu, 11 June 2009 11:33 Go to previous messageGo to next message
> Hello Aurelien,
Will it be supported with the new version of GMF which use QvTo?
> to use ANT task for it.
if you have an example ant task to generate it...
Say me if I'm right.
I can generate all diagram code using an ant task? or is there
limitations? which?
> create custom popup menu action using this class for code generation,
> deploy everything to currently running platform and use this action for
calling a doGenerateJavaClass I suppose at first sight?
> Alex Shatalin
Re: add .xpt template [message #233525 is a reply to message #233517] Thu, 11 June 2009 12:29 Go to previous messageGo to next message
Hello Aurelien,
No, it's not planned.
Here it is (build.xml from org.eclipse.gmf.graphdef.editor plugin):
<project name="graphdef.editor" default="main" xmlns:xpt="eclipse.org/gmf/2008/xpand">
<property name="graphdef.plugin" value="platform:/resource/org.eclipse.gmf.graphdef.editor"/ >
<property name="formtk.plugin" value="platform:/resource/org.eclipse.gmf.formtk"/>
<target name="main">
<antcall target="generateSection">
<param name="section" value="Size"/>
</antcall>
<param name="section" value="Layout"/>
</antcall>
<param name="section" value="LayoutData"/>
</antcall>
<param name="section" value="Figure"/>
</antcall>
</target>
<target name="generateSection">
<xpt:template
name="PropSheet::Main"
inputURI="${graphdef.plugin}/models/${section}Section.xmi#/ "
templateroot=" ${graphdef.plugin}/templates-context,${graphdef.plugin}/temp lates-propsheet,${formtk.plugin}/templates-propsheet,${formt k.plugin}/templates-formpage,${formtk.plugin}/templates-cont ext,${formtk.plugin}/templates-widget "
outfile=" ${basedir}/src-extra/org/eclipse/gmf/graphdef/editor/sheet/$ {section}Section.java "/>
</target>
</project>
> limitations? which?
No, it's not supported now. You can generate diagram code using UI action
only and you can generate additional classes using modified UI action or
using ant file.
Right you can call doGenerateJavaClass() from GeNeratorExt class.
Alex Shatalin
Re: add .xpt template [message #233619 is a reply to message #233525] Mon, 15 June 2009 04:08 Go to previous messageGo to next message
> Hello Aurelien,
> </antcall>
> </antcall>
> </antcall>
> </antcall>
> </target>
> <xpt:template name="PropSheet::Main"
> </target>
> </project>
>> limitations? which?
> action only and you can generate additional classes using modified UI
> action or using ant file.
I tried this.
I created a custom popup menu which launch :
a CustomExecuteTemplatesAction extends ExecuteTemplatesAction, overriden
the createOperation Method by return CustomExecuteTemplatesOperation
CustomExecuteTemplatesOperation extends ExecuteTemplatesOperation,
overriden the createGenerator which return a CustomGenerator
CustomGenerator extends Generator, here I'm calling the dogenerateClass
I tried with argument :
myEmittersCustom.getPropertySourceEmitter()/*newXpandEmitter ( "xpt::propsheet::PropertySource::Class")*/,
"org.ow2.jasmine.design.model.jonas.diagram.sheet",
"PropertySourceExtended",
myDiagram);
This exception is thrown by Eclipse while generating :
Problems while generating code
Exception (No Definition xpt::propsheet::PropertySource::Class for
GenDiagram could be found!) while generating code
No Definition xpt::propsheet::PropertySource::Class for GenDiagram
could be found!
The stack trace in the log is:
!SUBENTRY 1 org.eclipse.gmf.common 4 0 2009-06-15 09:59:40.503
!MESSAGE Exception (No Definition xpt::propsheet::PropertySource::Class
for GenDiagram could be found!) while generating code
!STACK 0
org.eclipse.gmf.internal.xpand.expression.EvaluationExceptio n: No
Definition xpt::propsheet::PropertySource::Class for GenDiagram could be
found!
at org.eclipse.gmf.internal.xpand.XpandFacade.evaluate(XpandFac ade.java:50)
at
at
at
org.ow2.jasmine.design.gmf.codegen.generator.popup.actions.C ustomGenerator.generateCustomDialogCellEditorPropertySheet(C ustomGenerator.java:83)
at
org.ow2.jasmine.design.gmf.codegen.generator.popup.actions.C ustomGenerator.generatePropertySheetSections(CustomGenerator .java:57)
at
at
at
at
at
It may be other thing to do but what? Do I declare the path to the
template? isn't already declare in the XPandEmitter constructor?
> Alex Shatalin
Re: add .xpt template [message #233650 is a reply to message #233619] Mon, 15 June 2009 06:16 Go to previous messageGo to next message
Hello Aurelien,
Looks like specified template was not found by code generation process.
You've used xpt::propsheet::PropertySource::Class template for GenDiagram
input.
This means there should be xpt/propsheet/PropertySource.xpt file with appropriate
definition in one of the template roots.
By default GMF generator load all the templates from GMF plugins (you probably
can not add your template there) + customized templates from the "template
directory" (specified by corresponding property of GenEditorGenerator) if
GenEditorGenerator.Dynamic template property was set to true.
So, can you please check that:
- GenEditorGenerator.template directory = "/<projectName>/<templateDirectoryName>"
- GenEditorGenerator.dynamic template = "true"
- xpt/propsheet/PropertySource.xpt is available in /<projectName>/<templateDirectoryName>
folder.
- there is corresponding definition inside this template file.
Alex Shatalin
Re: add .xpt template [message #233682 is a reply to message #233650] Mon, 15 June 2009 07:39 Go to previous messageGo to next message
> Hello Aurelien,
> GenDiagram input.
> appropriate definition in one of the template roots.
> probably can not add your template there) + customized templates from
> the "template directory" (specified by corresponding property of
> GenEditorGenerator) if GenEditorGenerator.Dynamic template property was
> set to true.
done for this 2 things (and i'm sure it works because an existing and
changed templates is used)
> /<projectName>/<templateDirectoryName> folder.
right too
the definiton :
«EXPAND PropertySourceExtendedConstructor»
«ENDDEFINE»
I use GMF SDK 2.1.3, not supported in this version?
> Alex Shatalin
Re: add .xpt template [message #233688 is a reply to message #233682] Mon, 15 June 2009 08:15 Go to previous messageGo to next message
Hello Aurelien,
> the definiton :
This definition is not one you are calling (there should be «DEFINE Class
FOR gmfgen::GenDiagram» to satisfy used parameters).
You have to either create «DEFINE Class FOR gmfgen::GenDiagram» or call doGenerateJavaClass
for gmfgen::GenCustomPropertyTab (use different input object as a last parameter
in doGenerateJavaClass method call).
Instead of:
doGenerateJavaClass(myEmittersCustom.getPropertySourceEmitte r(), "org.ow2.jasmine.design.model.jonas.diagram.sheet",
"PropertySourceExtended", myDiagram);
You have to use:
"PropertySourceExtended", selectCustomPropertyTabs(myDiagram.getEditorGen().getPropert ySheet().getTabs()));
Alex Shatalin
Re: add .xpt template [message #233693 is a reply to message #233688] Mon, 15 June 2009 08:29 Go to previous messageGo to next message
> Hello Aurelien,
>> the definiton :
> Class FOR gmfgen::GenDiagram» to satisfy used parameters).
I've tried to use a different input object :
«ENDDEFINE»
with error :
or call
> doGenerateJavaClass for gmfgen::GenCustomPropertyTab (use different
> input object as a last parameter in doGenerateJavaClass method call).
> Instead of:
> You have to use:
I also tried something like that :
private Object selectCustomPropertyTabs(EList<GenPropertyTab> tabs) {
for (GenPropertyTab tab :tabs) {
if(tab instanceof GenCustomPropertyTab) {
return tab;
return null;
with :
«ENDDEFINE»
with error :
GenCustomPropertyTab could be found!) while generating code
> Alex Shatalin
Re: add .xpt template [message #233701 is a reply to message #233693] Mon, 15 June 2009 08:34 Go to previous messageGo to next message
Hello Aurelien,
Do you have org.eclipse.gmf.codegen plugin (with gmfgen.ecore model inside)
in your workspace? If yes - try closing this plugin + restarting eclipse
+ executing generate code action again.
Alex Shatalin
[SOLVED]Re: add .xpt template [message #233707 is a reply to message #233701] Mon, 15 June 2009 09:09 Go to previous messageGo to next message
> Hello Aurelien,
> inside) in your workspace? If yes - try closing this plugin + restarting
> eclipse + executing generate code action again.
> Alex Shatalin
Ok It was that.
Alex, Thanks a LOT for all your help!!!
Re: [SOLVED]Re: add .xpt template [message #233728 is a reply to message #233707] Mon, 15 June 2009 10:41 Go to previous message
Hello Aurelien,
> Ok It was that.
:-) Nice to see it's solved.
Few words about this problem - it's rather frequent with current state of
EMF meta-model handling. We are trying to load EMF meta-model (gmfgen.emf)
from the workspace-located file to get latest state from there and use it
in xpand, but sometimes same meta-model can be loaded from the platform and
used by EMF then you load model file (yourmodel.gmfgen) in this case same
meta-classes (gmfgen::Diagram) will be loaded twice and will not be properly
matched in an engine.
As I said, this is not so frequent problem and you usually suffer from it
then you are doing some “advanced” GMF development… So, for now the workaround
is to deploy meta-model to the platform, remove it from the workspace and
let it work as you did.
Alex Shatalin
Previous Topic:How can I add Items to a compartment dynamic per Java code
Next Topic:Custom layout at diagram creation
Current Time: Sat Jul 19 23:13:05 EDT 2025
Powered by FUDForum. Page generated in 0.27207 seconds
