Home » Eclipse Projects » GEF » graphical artefacts on a windows xp Professional system
graphical artefacts on a windows xp Professional system [message #233143] Wed, 18 April 2007 02:12 Go to next message
Originally posted by: unidad.gmx.net
Hi!
I created a RCP-Standalone-App with an simple GEF-editor.
On my system everything works fine.
On the system of a friend sometimes fat black bars appear on the
GEF-editor. (Can't be reproduced.)
(I suppose they look like some other guys problem. See posting
<ev55hu$ecs$1@build.eclipse.org>. Maybe just not so fat)
Both systems should be the same (Windows XP Professional).
Any idea, what can be different on my friends system, that causes
the graphical artefacts?
Which JRE or JDK is used to execute the application?
The one defined by JAVA_HOME and PATH?
Regards, Ralf
Re: graphical artefacts on a windows xp Professional system [message #233166 is a reply to message #233143] Wed, 18 April 2007 08:26 Go to previous messageGo to next message
Originally posted by: alexandre.magillem.com
I don't know if it's related but I had this kind of artifact using
Attachmate Reflection X with the Logic Editor example.
To remove the problem, I had to remove the router switching animation,
in particular the following line :
if ((getViewer().getControl().getStyle() & SWT.MIRRORED ) == 0)
cLayer.setAntialias(SWT.ON);
and all the animation code.
in org.eclipse.gef.examples.logicdesigner.edit.LogicDiagramEdit Part.java
BTW, How do I find this posting ?
Regards.
Christophe Alexandre
Ralf Maurer a écrit :
> Hi!
> Regards, Ralf
Re: graphical artefacts on a windows xp Professional system [message #233174 is a reply to message #233166] Wed, 18 April 2007 08:29 Go to previous messageGo to next message
Hi again,
I just understood that <ev55hu$ecs$1@build.eclipse.org> was my own
posting....
Christophe
Christophe Alexandre a écrit :
> Regards.
>> Hi!
>> Regards, Ralf
Re: graphical artefacts on a windows xp Professional system [message #233245 is a reply to message #233166] Thu, 19 April 2007 04:39 Go to previous messageGo to next message
Hi!
Christophe Alexandre schrieb:
Thanks for your answer!
As far as I overview it, I have no animation-code in my setup.
Regards, Ralf
Re: graphical artefacts on a windows xp Professional system [message #233275 is a reply to message #233245] Fri, 20 April 2007 09:30 Go to previous messageGo to next message
My guess is that my problem was coming from :
Maybe you don't have any routing animation in your code but this kind of
manipulation on one of your graphical layers.
Regards.
> Hi!
>> Hi,
> Regards, Ralf
Re: graphical artefacts on a windows xp Professional system [message #233361 is a reply to message #233275] Mon, 23 April 2007 04:06 Go to previous message
Hi Christophe!
Thanks for your hint.
I made a fulltext-search for a ".setAntialias()"-call, but none is used.
Regards, Ralf
Previous Topic:draw2d - PolylineConnection NOT from center to center
Next Topic:Re: Scrolling a graphical view
Current Time: Sat Jul 19 11:33:23 EDT 2025
Powered by FUDForum. Page generated in 0.24369 seconds
