Home » Modeling » GMF (Graphical Modeling Framework) » Context Menu entry does not work when plug-in downloaded and installed
Context Menu entry does not work when plug-in downloaded and installed [message #233088] Tue, 09 June 2009 08:58 Go to next message
I have a problem with my editor: When I provide it on an update site and
then download and install it into a new eclipse installation, the
context menu I made does not work. I added a new entry to the menu, but
it does not show up, although the plug-in that provides the menu appears
in the plug-in list. However, when I start my plug-in project from
inside of eclipse, it does work.
Does somebody know how to solve this?
Thanks in advance,
Matthias
Re: Context Menu entry does not work when plug-in downloaded and installed [message #233097 is a reply to message #233088] Tue, 09 June 2009 11:03 Go to previous messageGo to next message
How did you provide the context entry? Did you do it in code or
declarative and did you use the command framework or the old action based
approach or something low level which could explain your error?
Re: Context Menu entry does not work when plug-in downloaded and installed [message #233120 is a reply to message #233097] Tue, 09 June 2009 11:23 Go to previous message
> based approach or something low level which could explain your error?
I defined it in the plugin.xml. The code is below:
<?eclipse version="3.2"?>
<plugin>
<extension
point="org.eclipse.help.toc">
<toc
file="toc.xml">
</toc>
<toc
file="testToc.xml"
primary="true">
</toc>
</extension>
<extension point="org.eclipse.ui.commands">
<category name="Synccharts" description="Commands related to state
charts." id="org.eclipse.gmf.category.synccharts"/>
<command categoryId="org.eclipse.gmf.category.synccharts"
description="Adds a new OnEntryAction"
id=" de.cau.cs.kieler.synccharts.custom.contextMenu.addEntryActio n "
name="Add OnEntryAction">
</command>
</extension>
description="Adds a new OnInsideAction"
id=" de.cau.cs.kieler.synccharts.custom.contextMenu.addInnerActio n "
name="Add OnInsideAction">
</command>
</extension>
description="Adds a new OnExitAction"
id=" de.cau.cs.kieler.synccharts.custom.contextMenu.addExitAction "
name="Add OnExitAction">
</command>
</extension>
description="Adds a new Signal"
id="de.cau.cs.kieler.synccharts.custom.contextMenu.addSignal " name="Add
Signal">
</command>
</extension>
description="Adds a new Variable"
id="de.cau.cs.kieler.synccharts.custom.contextMenu.addVariable "
name="Add Variable">
</command>
</extension>
description="Adds a new SuspensionTrigger"
id=" de.cau.cs.kieler.synccharts.custom.contextMenu.addSuspension Trigger "
name="Add SuspensionTrigger">
</command>
</extension>
description="Adds a new Region"
id="de.cau.cs.kieler.synccharts.custom.contextMenu.addRegion " name="Add
Region">
</command>
</extension>
description="Adds a new State"
id="de.cau.cs.kieler.synccharts.custom.contextMenu.addState " name="Add
State">
</command>
</extension>
<extension point="org.eclipse.ui.popupMenus">
<objectContribution
adaptable="false"
id=" de.cau.cs.kieler.synccharts.diagram.ui.objectContribution.St ateEditPart "
objectClass=" de.cau.cs.kieler.synccharts.diagram.edit.parts.StateEditPart ">
<menu
id="ElementInsert"
label="Insert Element"
path="additions">
<separator name="group1"/>
<separator name="group2"/>
<separator name="group3"/>
<separator name="group4"/>
</menu>
<action
class=" de.cau.cs.kieler.synccharts.custom.contextMenu.AddSuspension TriggerAction "
definitionId=" de.cau.cs.kieler.synccharts.custom.contextMenu.AddSuspension Trigger "
enablesFor="1"
id=" de.cau.cs.kieler.synccharts.custom.contextMenu.AddSuspension TriggerActionID "
label="Add SuspensionTrigger"
menubarPath="ElementInsert/group4">
</action>
<action
class=" de.cau.cs.kieler.synccharts.custom.contextMenu.AddExitAction Action "
definitionId=" de.cau.cs.kieler.synccharts.custom.contextMenu.AddExitAction "
enablesFor="1"
id=" de.cau.cs.kieler.synccharts.custom.contextMenu.AddExitAction ActionID "
label="Add OnExitAction"
menubarPath="ElementInsert/group3">
</action>
<action
class=" de.cau.cs.kieler.synccharts.custom.contextMenu.AddInnerActio nAction "
definitionId=" de.cau.cs.kieler.synccharts.custom.contextMenu.AddInnerActio n "
enablesFor="1"
id=" de.cau.cs.kieler.synccharts.custom.contextMenu.AddInnerActio nActionID "
label="Add OnInsideAction"
</action>
<action
class=" de.cau.cs.kieler.synccharts.custom.contextMenu.AddEntryActio nAction "
definitionId=" de.cau.cs.kieler.synccharts.custom.contextMenu.AddEntryActio n "
enablesFor="1"
id=" de.cau.cs.kieler.synccharts.custom.contextMenu.AddEntryActio nActionID "
label="Add OnEntryAction"
</action>
<action
class=" de.cau.cs.kieler.synccharts.custom.contextMenu.AddVariableAc tion "
definitionId="de.cau.cs.kieler.synccharts.custom.contextMenu.AddVariable "
enablesFor="1"
id=" de.cau.cs.kieler.synccharts.custom.contextMenu.AddVariableAc tionID "
label="Add Variable"
menubarPath="ElementInsert/group2">
</action>
<action
class=" de.cau.cs.kieler.synccharts.custom.contextMenu.AddSignalActi on "
definitionId="de.cau.cs.kieler.synccharts.custom.contextMenu.AddSignal "
enablesFor="1"
id=" de.cau.cs.kieler.synccharts.custom.contextMenu.AddSignalActi onID "
label="Add Signal"
</action>
<action
class=" de.cau.cs.kieler.synccharts.custom.contextMenu.AddRegionActi on "
definitionId="de.cau.cs.kieler.synccharts.custom.contextMenu.AddRegion "
enablesFor="1"
id=" de.cau.cs.kieler.synccharts.custom.contextMenu.AddRegionActi onID "
label="Add Region"
menubarPath="ElementInsert/group1">
</action>
</objectContribution>
<objectContribution
adaptable="false"
id=" de.cau.cs.kieler.synccharts.diagram.ui.objectContribution.St ate2EditPart "
objectClass=" de.cau.cs.kieler.synccharts.diagram.edit.parts.State2EditPar t ">
<menu
id="ElementInsert"
path="additions">
</menu>
<action
class=" de.cau.cs.kieler.synccharts.custom.contextMenu.AddSuspension Trigger2Action "
definitionId=" de.cau.cs.kieler.synccharts.custom.contextMenu.AddSuspension Trigger2 "
enablesFor="1"
id=" de.cau.cs.kieler.synccharts.custom.contextMenu.AddSuspension Trigger2ActionID "
</action>
<action
class=" de.cau.cs.kieler.synccharts.custom.contextMenu.AddExitAction 2Action "
definitionId=" de.cau.cs.kieler.synccharts.custom.contextMenu.AddExitAction 2 "
enablesFor="1"
id=" de.cau.cs.kieler.synccharts.custom.contextMenu.AddExitAction 2ActionID "
</action>
<action
class=" de.cau.cs.kieler.synccharts.custom.contextMenu.AddInnerActio n2Action "
definitionId=" de.cau.cs.kieler.synccharts.custom.contextMenu.AddInnerActio n2 "
enablesFor="1"
id=" de.cau.cs.kieler.synccharts.custom.contextMenu.AddInnerActio n2ActionID "
</action>
<action
class=" de.cau.cs.kieler.synccharts.custom.contextMenu.AddEntryActio n2Action "
definitionId=" de.cau.cs.kieler.synccharts.custom.contextMenu.AddEntryActio n2 "
enablesFor="1"
id=" de.cau.cs.kieler.synccharts.custom.contextMenu.AddEntryActio n2ActionID "
</action>
<action
class=" de.cau.cs.kieler.synccharts.custom.contextMenu.AddVariable2A ction "
definitionId="de.cau.cs.kieler.synccharts.custom.contextMenu.AddVariable2 "
enablesFor="1"
id=" de.cau.cs.kieler.synccharts.custom.contextMenu.AddVariabl2eA ctionID "
</action>
<action
class=" de.cau.cs.kieler.synccharts.custom.contextMenu.AddSignal2Act ion "
definitionId="de.cau.cs.kieler.synccharts.custom.contextMenu.AddSignal2 "
enablesFor="1"
id=" de.cau.cs.kieler.synccharts.custom.contextMenu.AddSignal2Act ionID "
label="Add Signal"
</action>
<action
class=" de.cau.cs.kieler.synccharts.custom.contextMenu.AddRegion2Act ion "
definitionId="de.cau.cs.kieler.synccharts.custom.contextMenu.AddRegion2 "
enablesFor="1"
id=" de.cau.cs.kieler.synccharts.custom.contextMenu.AddRegion2Act ionID "
label="Add Region"
</action>
<objectContribution
adaptable="false"
id=" de.cau.cs.kieler.synccharts.diagram.ui.objectContribution.Re gionEditPart "
objectClass=" de.cau.cs.kieler.synccharts.diagram.edit.parts.RegionEditPar t ">
<menu
id="ElementInsert"
path="additions">
</menu>
<action
class=" de.cau.cs.kieler.synccharts.custom.contextMenu.AddStateActio n "
definitionId="de.cau.cs.kieler.synccharts.custom.contextMenu.AddState "
enablesFor="1"
id=" de.cau.cs.kieler.synccharts.custom.contextMenu.AddStateActio nID "
label="Add State"
</action>
<objectContribution
adaptable="false"
id=" de.cau.cs.kieler.synccharts.diagram.ui.objectContribution.Re gion2EditPart "
objectClass=" de.cau.cs.kieler.synccharts.diagram.edit.parts.Region2EditPa rt ">
<menu
id="ElementInsert"
path="additions">
</menu>
<action
class=" de.cau.cs.kieler.synccharts.custom.contextMenu.AddState2Acti on "
definitionId="de.cau.cs.kieler.synccharts.custom.contextMenu.AddState2 "
enablesFor="1"
id=" de.cau.cs.kieler.synccharts.custom.contextMenu.AddState2Acti onID "
label="Add State"
</action>
</extension>
<!-- <extension
point="org.eclipse.ui.menus">
<menuContribution
locationURI="menu:org.eclipse.ui.main.menu?after=additions" >
<menu
id=" de.cau.cs.kieler.synccharts.custom.contextMenu.ui.menu.syncc harts "
label="Syncchart"
mnemonic="S">
</menu>
</menuContribution>
<menuContribution
locationURI="popup:org.eclipse.ui.popup.any?after=additions ">
<menu
label="Syncchart">
<command
commandId=" de.cau.cs.kieler.synccharts.custom.contextMenu.addEntryActio n "
style="push">
</command>
</menu>
</menuContribution>
<menuContribution
locationURI="toolbar:org.eclipse.ui.main.toolbar?after=additions ">
<toolbar
id=" de.cau.cs.kieler.synccharts.custom.contextMenu.ui.toolbar.ma in ">
<command
style="push">
</command>
</toolbar>
</menuContribution>
</extension>
<extension
<command
description="Add new OnEntryAction to selected state"
</command>
</extension>
<extension
point="org.eclipse.ui.handlers">
<handler
class=" de.cau.cs.kieler.synccharts.custom.contextMenu.AddEntryActio nHandler "
commandId=" de.cau.cs.kieler.synccharts.custom.contextMenu.addEntryActio n ">
</handler>
</extension> -->
</plugin>
Previous Topic:CompartmentChildCreateCommand & RepositionEObjectCommand
Next Topic:How to make a Compartment become invisible when it is empty?
Current Time: Sun Jul 20 08:33:51 EDT 2025
Powered by FUDForum. Page generated in 0.03375 seconds
