Home » Modeling » GMF (Graphical Modeling Framework) » genmodel template
genmodel template [message #232617] Fri, 05 June 2009 07:23 Go to next message
is there a template for the *.genmodel file, which is generated out of the
*.gmfmap file? I don't want to setup everything again for every new
diagram.
Michael
Re: genmodel template [message #232630 is a reply to message #232617] Fri, 05 June 2009 07:25 Go to previous messageGo to next message
Hello Michael,
This is a m2m transformation.
Alex Shatalin
Re: genmodel template [message #232669 is a reply to message #232630] Fri, 05 June 2009 07:36 Go to previous messageGo to next message
Hi Alex,
thanks for your reply . So can I change the predefined settings (e.g. that
the "use dynamic template option" is true by default)?
Re: genmodel template [message #232738 is a reply to message #232669] Fri, 05 June 2009 09:17 Go to previous messageGo to next message
Hello Michael,
> that the "use dynamic template option" is true by default)?
You can change this option in .gmfgen file directly. Next time you perform
gmfmap->gmfgen transformation the value of this option will be saved.
Alex Shatalin
Re: genmodel template [message #233360 is a reply to message #232738] Wed, 10 June 2009 15:42 Go to previous messageGo to next message
Hi Alex,
but everytime I create a new diagram, I have to specify the settings
again. Even if it's only necessary at the first time, I would like to have
predefined settings in the *.gmfgen file.
Do you have an idea?
Michael
Re: genmodel template [message #233446 is a reply to message #233360] Thu, 11 June 2009 07:24 Go to previous message
Hello Michael,
Then you probably can use recently added "Extra in-place gmfgen transformation
after reconcile step" option inside "Create Generator model" wizard.
http://wiki.eclipse.org/GMF_New_and_Noteworthy#M2M_.28QVTO.2 9_transformations
Alex Shatalin
Previous Topic:BorderedItem on Link
Next Topic:Error on RCP product export, when OCL validation is used
Current Time: Sat Jul 19 09:32:16 EDT 2025
Powered by FUDForum. Page generated in 0.03405 seconds
