Home » Modeling » GMF (Graphical Modeling Framework) » How to remove the sub menus of 'Add' Context Menu ?
How to remove the sub menus of 'Add' Context Menu ? [message #232125] Wed, 03 June 2009 06:09 Go to next message
Hi all,
On the diagram there's an 'Add' context menu that contains sub menus
'Oval', 'Triangle', 'Rectangle', etc. How to get rid of them ?
Setya
Re: How to remove the sub menus of 'Add' Context Menu ? [message #232347 is a reply to message #232125] Thu, 04 June 2009 07:56 Go to previous messageGo to next message
Setya wrote:
> Hi all,
> Regards,
> Setya
Well ?
Re: How to remove the sub menus of 'Add' Context Menu ? [message #232419 is a reply to message #232347] Thu, 04 June 2009 11:19 Go to previous messageGo to next message
Hi setya
Check for some geoshape in plugin.xml.
Govind
Re: How to remove the sub menus of 'Add' Context Menu ? [message #232515 is a reply to message #232419] Fri, 05 June 2009 03:15 Go to previous messageGo to next message
Thanks for responding.
What is this geoshape ? an ext. point ? I've tried to search this text
in the plugin.xml without result.
Setya
Re: How to remove the sub menus of 'Add' Context Menu ? [message #232757 is a reply to message #232515] Fri, 05 June 2009 10:15 Go to previous messageGo to next message
Hi Setya
If u don't find the below popcontribution add
<popupContribution
class=" org.eclipse.gmf.runtime.diagram.ui.providers.DiagramContextM enuProvider ">
<popupStructuredContributionCriteria
objectClass=" org.eclipse.gmf.runtime.diagram.ui.geoshapes.internal.editpa rts.GeoShapeEditPart ">
</popupStructuredContributionCriteria>
<popupPredefinedItem id="add" remove="true"/>
<popupPredefinedItem id="autoSizeAction" path="/formatMenu/"
remove="true">
</popupPredefinedItem>
</popupContribution>
I think it should work.
Govind.
Re: How to remove the sub menus of 'Add' Context Menu ? [message #232780 is a reply to message #232757] Fri, 05 June 2009 13:03 Go to previous messageGo to next message
> <popupContribution
> remove="true">
I've added the ext. point as follows:
<extension
point=" org.eclipse.gmf.runtime.common.ui.services.action.contributi onItemProviders ">
<contributionItemProvider
checkPluginLoaded="true"
class=" org.eclipse.gmf.runtime.diagram.ui.providers.DiagramContribu tionItemProvider ">
<Priority
name="Lowest">
</Priority>
<popupContribution
id="add"
remove="true">
id="autoSizeAction"
path="/formatMenu/"
remove="true">
</contributionItemProvider>
</extension>
The the 'Add' menu is still there.
Setya
Re: How to remove the sub menus of 'Add' Context Menu ? [message #234354 is a reply to message #232780] Sat, 20 June 2009 07:07 Go to previous message
<popupPredefinedItem id="addGroup" remove="true"/>
Previous Topic:Re: Problem opening ecore_diagram file/dynamic diagram generation
Next Topic:Hint for dynamic Model
Current Time: Sat Jul 19 19:25:09 EDT 2025
Powered by FUDForum. Page generated in 0.04330 seconds
