Home » Eclipse Projects » GEF » Focus on newly created connection
Focus on newly created connection [message #231865] Mon, 19 March 2007 14:44 Go to next message
Originally posted by: gary.pi4tech.com
When a component is created by being dragged from a palette, it
automatically obtains the focus.
However when using the connection tool, the same does not happen for the
created connection.
Is there a simple way to get the focus on the connection, without having
to specifically locate the new edit part and invoke setFocus on the viewer?
Gary
Re: Focus on newly created connection [message #232002 is a reply to message #231865] Thu, 22 March 2007 01:21 Go to previous messageGo to next message
Originally posted by: none.unknown.com
CreationTool has a selectAddedObject() method that is invoked once the
creation command has executed. ConnectionCreationTool doesn't. You can
easily add that by subclassing CCT and setting that as the tool for your
palette entry.
"Gary Brown" <gary@pi4tech.com> wrote in message
news:etmlmu$qa6$1@utils.eclipse.org...
> created connection.
> viewer?
> Regards
> Gary
Re: Focus on newly created connection [message #232096 is a reply to message #232002] Fri, 23 March 2007 07:33 Go to previous messageGo to next message
Thanks for the suggestion, but the method you refer to is on the GMF
CreationTool. I am not using GMF, so need to find a GEF solution.
> palette entry.
>> created connection.
>> viewer?
>> Regards
>> Gary
Re: Focus on newly created connection [message #232113 is a reply to message #232096] Fri, 23 March 2007 11:00 Go to previous message
Hi Gary,
Subclass ConnectionCreationTool and override the handleCreateConnection()
method to call your selectAddedObject() method.
You can do exactly what CreationTool does, you can get the model object from
the connection request.
Cheers...
Anthony
news:4603BB12.8020208@pi4tech.com...
>> palette entry.
>>> created connection.
>>> viewer?
>>> Regards
>>> Gary
Previous Topic:Mouse events in GraphicalViewer
Next Topic:Is it possible to do zooming in a separate thread?
Current Time: Sun Jul 20 08:36:42 EDT 2025
Powered by FUDForum. Page generated in 0.03806 seconds
