Create tag transform operation in jsf tools [message #231761] |
Thu, 21 May 2009 18:24 |
Hi for all.
Sorry for my english.
I'm using extension point pageDesignExtension to create a new
TransformOperation for my tags. But don't work, I create the class
extending AbstractTransformOperation and create in my DTI file the
reference for this operation, and make the inclusion of extesion point in
plugin.xml but dont work. IŽm forgot something?
Above the source code.
please help me.
Class
package com.mytag.test;
import org.eclipse.core.runtime.Assert;
import
org.eclipse.jst.pagedesigner.dtmanager.converter.operations. AbstractTransformOperation;
import org.w3c.dom.Element;
* ITransformOperation implementation that creates a new Element.
* <br><b>Note:</b> requires
ITransformOperation.setTagConverterContext(...) to
* have been called to provide a valid ITagConverterContext instance prior
to
* a call to the transform(...) method.
* @author Ian Trimble - Oracle
public class CreateElementOperation extends AbstractAWBTransformOperation {
private String tagName;
private String x;
* (non-Javadoc)
* @see
org.eclipse.jst.pagedesigner.dtmanager.converter.operations. internal.provisional.AbstractTransformOperation#transform(or g.w3c.dom.Element,
org.w3c.dom.Element)
public Element transform(Element srcElement, Element curElement) {
if (getParameters().length < 1) {
//getLog().error("Warning.TransformOperationFactory.TooFewParameters ",
getTransformOperationID()); //$NON-NLS-1$
return null;
tagName = getParameters()[0];
Assert.isNotNull(tagName);
Element element = null;
if (tagConverterContext != null && tagName != null && tagName.length() >
0) {
element = tagConverterContext.createElement(tagName);
return element;
Dti
<entity id="CommandButton" type="tag">
<trait id="dt-info">
<value xsi:type="dti:DTInfo">
<tag-convert-info>
<operation id="com.mytag.test.CreateElementOperation">
<parameter value="input"/>
</operation>
plugin.xml
<tagTransformOperation
class="com.mytag.test.CreateElementOperation">
</tagTransformOperation>
FUDForum. Page generated in 0.03193 seconds
