Re: No authentication service [message #23647 is a reply to message #23604] |
Wed, 25 March 2009 03:39   |
Hi Carsten,
The cause of this exception is that the RemoteLoginProxy is missing an
implementation of the IAuthenticationService service. A default
implementation is provided within the plugin
org.eclipse.riena.security.services. Maybe this is missing in your
sample app?
Documentation is available here:
- http://wiki.eclipse.org/Riena_Getting_started_security
- http://wiki.eclipse.org/Riena_Login_support
and of course:
- http://www.eclipse.org/equinox/incubator/security/
HTH
Tschüß,
Stefan
Carsten Spieker wrote:
> BTW: I have switched to Riena 1.1.0M6 now.
> "Carsten Spieker" <carsten.spieker@d-velop.de> schrieb im Newsbeitrag
> news:gqckib$1sj$1@build.eclipse.org...
>> Hey Frank,
>> the VM-argument you mentioned was existing in the app server launch
>> configuration...but the specified plugin
>> "org.eclipse.riena.security.simpleservice" not. After importing it into
>> workspace it works fine.
>> But when I take the login mechanism over to my own little sample
>> application I still get the following error when ILoginContext.login() is
>> performed:
>> javax.security.auth.login.LoginException: no authentication service
>> at
>> org.eclipse.riena.security.common.authentication.RemoteLogin Proxy.login(RemoteLoginProxy.java:79)
>> at
>> com.pa.eai.spieker.client.authentication.RemoteLoginModule.l ogin(RemoteLoginModule.java:96)
>> at
>> org.eclipse.equinox.security.auth.module.ExtensionLoginModul e.login(ExtensionLoginModule.java:61)
>> at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
>> at sun.reflect.NativeMethodAccessorImpl.invoke(Unknown Source)
>> at sun.reflect.DelegatingMethodAccessorImpl.invoke(Unknown Source)
>> at java.lang.reflect.Method.invoke(Unknown Source)
>> at javax.security.auth.login.LoginContext.invoke(Unknown Source)
>> at javax.security.auth.login.LoginContext.access$000(Unknown Source)
>> at javax.security.auth.login.LoginContext$4.run(Unknown Source)
>> at java.security.AccessController.doPrivileged(Native Method)
>> at javax.security.auth.login.LoginContext.invokePriv(Unknown Source)
>> at javax.security.auth.login.LoginContext.login(Unknown Source)
>> at
>> org.eclipse.equinox.internal.security.auth.SecureContext.log in(SecureContext.java:50)
>> at
>> com.pa.eai.spieker.client.views.LoginDialogController.checkL ogin(LoginDialogController.java:142)
>> at
>> com.pa.eai.spieker.client.views.LoginDialogController.access $0(LoginDialogController.java:125)
>> at
>> com.pa.eai.spieker.client.views.LoginDialogController$1.call back(LoginDialogController.java:78)
>> at
>> org.eclipse.riena.internal.ui.ridgets.swt.ActionObserver.fir eAction(ActionObserver.java:63)
>> at
>> org.eclipse.riena.internal.ui.ridgets.swt.ActionObserver.wid getSelected(ActionObserver.java:34)
>> at
>> org.eclipse.swt.widgets.TypedListener.handleEvent(TypedListe ner.java:228)
>> at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java :84)
>> at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1003)
>> at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.ja va:3880)
>> at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :3473)
>> at
>> org.eclipse.riena.navigation.ui.swt.splashHandlers.AbstractL oginSplashHandler.doEventLoop(AbstractLoginSplashHandler.jav a:88)
>> at
>> org.eclipse.riena.navigation.ui.swt.splashHandlers.AbstractL oginSplashHandler.init(AbstractLoginSplashHandler.java:67)
>> at org.eclipse.ui.internal.Workbench$6.run(Workbench.java:605)
>> at org.eclipse.core.runtime.SafeRunner.run(SafeRunner.java:37)
>> at
>> org.eclipse.ui.internal.Workbench.createSplashWrapper(Workbe nch.java:621)
>> at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2238)
>> at org.eclipse.ui.internal.Workbench.access$4(Workbench.java:22 09)
>> at org.eclipse.ui.internal.Workbench$5.run(Workbench.java:499)
>> at
>> org.eclipse.core.databinding.observable.Realm.runWithDefault (Realm.java:332)
>> at
>> org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:492)
>> at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.j ava:149)
>> at
>> org.eclipse.riena.navigation.ui.swt.application.SwtApplicati on.createView(SwtApplication.java:62)
>> at
>> org.eclipse.riena.navigation.ui.application.AbstractApplicat ion.start(AbstractApplication.java:66)
>> at
>> org.eclipse.equinox.internal.app.EclipseAppHandle.run(Eclips eAppHandle.java:194)
>> at
>> org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .runApplication(EclipseAppLauncher.java:110)
>> at
>> org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .start(EclipseAppLauncher.java:79)
>> at
>> org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:368)
>> at
>> org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:179)
>> at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java: 556)
>> at org.eclipse.equinox.launcher.Main.basicRun(Main.java:511)
>> at org.eclipse.equinox.launcher.Main.run(Main.java:1284)
>> at org.eclipse.equinox.launcher.Main.main(Main.java:1260)
>> Are there any documents or tutorials or something like that which can be
>> used to understand the whole Login mechanism with all the involved
>> components?
>> BTW: I´m working on Win32.
>> Greetz and Thanks!
>> Carsten
>> "Frank Schepp" <Frank.Schepp@compeople.de> schrieb im Newsbeitrag
>> news:gq87hj$ps2$1@build.eclipse.org...
>>> Hi Carsten,
>>> sorry, the launcher i wanted to mentioned is also in
>>> org.eclipse.riena.example.client and is named SWT
>>> ExampleApplication.product.launch. Please can you check/make sure that
>>> also the following VM
>>> argument -Djava.security.auth.login.config==${workspace_loc}\org.ecli pse.riena.security.simpleservices\config\sample_jaas.config
>>> is present in the launch configuration of Riena Sample App Server (the
>>> exception indicates that information provided by this file is missing)?!
>>> By the way on which OS platform you are on?
>>> regards, Frank
>>>> Hi Frank,
>>>> I use the product "example_product" defined in plugin
>>>> "org.eclipse.riena.example.client".
>>>> I cannot find the launcher you mentioned. Where can I find it?
>>>> Here the stacktrace the Sample App Server gives:
>>>> WARNUNG:
>>>> org.eclipse.riena.security.common.authentication.Authenticat ionFailure:
>>>> AuthenticationService login failed
>>>> at
>>>> org.eclipse.riena.internal.security.authenticationservice.Au thenticationService.login(AuthenticationService.java:146)
>>>> at
>>>> sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAcce ssorImpl.java:39)
>>>> at
>>>> sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMe thodAccessorImpl.java:25)
>>>> at java.lang.reflect.Method.invoke(Method.java:597)
>>>> at
>>>> org.eclipse.riena.communication.core.hooks.AbstractHooksProx y.invoke(AbstractHooksProxy.java:69)
>>>> at
>>>> org.eclipse.riena.communication.core.hooks.AbstractHooksProx y.invoke(AbstractHooksProxy.java:38)
>>>> at
>>>> org.eclipse.riena.internal.communication.publisher.ServiceHo oksProxy.invoke(ServiceHooksProxy.java:70)
>>>> at $Proxy13.login(Unknown Source)
>>>> at
>>>> at
>>>> at
>>>> com.caucho.hessian.server.HessianSkeleton.invoke(HessianSkel eton.java:155)
>>>> at
>>>> org.eclipse.riena.communication.publisher.hessian.RienaHessi anDispatcherServlet.service(RienaHessianDispatcherServlet.ja va:147)
>>>> at
>>>> org.eclipse.equinox.http.registry.internal.ServletManager$Se rvletWrapper.service(ServletManager.java:180)
>>>> at
>>>> org.eclipse.equinox.http.servlet.internal.ServletRegistratio n.handleRequest(ServletRegistration.java:90)
>>>> at
>>>> org.eclipse.equinox.http.servlet.internal.ProxyServlet.proce ssAlias(ProxyServlet.java:111)
>>>> at
>>>> org.eclipse.equinox.http.servlet.internal.ProxyServlet.servi ce(ProxyServlet.java:67)
>>>> at javax.servlet.http.HttpServlet.service(HttpServlet.java:689)
>>>> at
>>>> org.eclipse.equinox.http.jetty.internal.HttpServerManager$In ternalHttpServiceServlet.service(HttpServerManager.java:269)
>>>> at
>>>> org.mortbay.jetty.servlet.ServletHolder.handle(ServletHolder .java:428)
>>>> at
>>>> org.mortbay.jetty.servlet.ServletHandler.dispatch(ServletHan dler.java:677)
>>>> at
>>>> org.mortbay.jetty.servlet.ServletHandler.handle(ServletHandl er.java:568)
>>>> at org.mortbay.http.HttpContext.handle(HttpContext.java:1530)
>>>> at org.mortbay.http.HttpContext.handle(HttpContext.java:1482)
>>>> at org.mortbay.http.HttpServer.service(HttpServer.java:909)
>>>> at org.mortbay.http.HttpConnection.service(HttpConnection.java: 820)
>>>> at org.mortbay.http.HttpConnection.handleNext(HttpConnection.ja va:986)
>>>> at org.mortbay.http.HttpConnection.handle(HttpConnection.java:8 37)
>>>> at
>>>> org.mortbay.http.SocketListener.handleConnection(SocketListe ner.java:245)
>>>> at org.mortbay.util.ThreadedServer.handle(ThreadedServer.java:3 57)
>>>> at org.mortbay.util.ThreadPool$PoolThread.run(ThreadPool.java:5 34)
>>>> Caused by: javax.security.auth.login.LoginException: Für CentralSecurity
>>>> sind keine Anmeldemodule konfiguriert.
>>>> at javax.security.auth.login.LoginContext.init(LoginContext.jav a:256)
>>>> at javax.security.auth.login.LoginContext.<init>(LoginContext.java:403)
>>>> at
>>>> org.eclipse.equinox.internal.security.auth.SecureContext.get LoginContext(SecureContext.java:98)
>>>> at
>>>> org.eclipse.equinox.internal.security.auth.SecureContext.log in(SecureContext.java:46)
>>>> at
>>>> org.eclipse.riena.internal.security.authenticationservice.Au thenticationService.login(AuthenticationService.java:125)
>>>> ... 32 more
>>>> Greetz
>>>> Carsten
>>>> news:gq7n3l$b90$1@build.eclipse.org...
>>>>> Hi Carsten,
>>>>> which example are you using? Did you try launcher SWT SCP
>>>>> ExampleApplication.product (client) and Riena Sample App Server? Which
>>>>> riena version are you using? Could you please provide a stacktrace?
>>>>> Regards, Frank
>>>>>> Hi,
>>>>>> I´m playing around with the Riena sample applications.
>>>>>> When I try to learn more about the riena login support I´m reaching my
>>>>>> limits quite early.
>>>>>> I always get the message "Log-in failed" which is caused by an
>>>>>> LoginException "No authentication service".
>>>>>> I´m quite new to riena and Java Security. Can anyone help me
>>>>>> understanding or simply using the login support?
>>>>>> Thanks and greetz
>>>>>> Carsten
Re: No authentication service [message #581370 is a reply to message #23154] |
Mon, 23 March 2009 05:57  |
Hi Carsten,
Regards, Frank
> limits quite early.
> I´m quite new to riena and Java Security. Can anyone help me understanding
> Thanks and greetz
> Carsten
Re: No authentication service [message #581389 is a reply to message #23193] |
Mon, 23 March 2009 06:24  |
Hi Frank,
WARNUNG:
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at org.mortbay.jetty.servlet.ServletHolder.handle(ServletHolder .java:428)
at
at org.mortbay.jetty.servlet.ServletHandler.handle(ServletHandl er.java:568)
at
Re: No authentication service [message #581436 is a reply to message #23307] |
Mon, 23 March 2009 10:37  |
Hi Carsten,
also the following VM argument
regards, Frank
> Hi Frank,
> WARNUNG:
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> ... 32 more
> Greetz
> Carsten
>> Hi Carsten,
>> Regards, Frank
>>> Hi,
>>> limits quite early.
>>> Thanks and greetz
>>> Carsten
Re: No authentication service [message #581481 is a reply to message #23394] |
Wed, 25 March 2009 02:56  |
Hey Frank,
But when I take the login mechanism over to my own little sample application
I still get the following error when ILoginContext.login() is performed:
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
components?
BTW: I
Re: No authentication service [message #581489 is a reply to message #23561] |
Wed, 25 March 2009 03:06  |
> Hey Frank,
> performed:
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> components?
> BTW: I
Re: No authentication service [message #581497 is a reply to message #23604] |
Hi Carsten,
sample app?
and of course:
HTH
Tschüß,
Stefan
>> Hey Frank,
>> performed:
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> components?
>> Greetz and Thanks!
>> Carsten
>>> Hi Carsten,
>>> regards, Frank
>>>> Hi Frank,
>>>> WARNUNG:
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> ... 32 more
>>>> Greetz
>>>> Carsten
>>>>> Hi Carsten,
>>>>> Regards, Frank
>>>>>> Hi,
>>>>>> limits quite early.
>>>>>> Thanks and greetz
>>>>>> Carsten
Re: No authentication service [message #581507 is a reply to message #23604] |
Wed, 25 March 2009 03:46  |
Well, after having an additional look at the
org.eclipse.riena.example.client bundle I have found my last error.
I did not register a remote proxy for the IAuthenticationService interface
in my own bundle. This caused the problem that my bundle could not find an
authentication service since no local service was available!
Thank you Fred for your patient help!
Greetz
Carsten
news:gqcl5e$epd$1@build.eclipse.org...
>> Hey Frank,
>> performed:
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> components?
>> BTW: I
FUDForum. Page generated in 0.28649 seconds
