Home » Language IDEs » ServerTools (WTP) » Extending palette Web Page Editor
Extending palette Web Page Editor [message #231276] Wed, 13 May 2009 07:26 Go to next message
Hi everybody,
I'm trying to improve my Web Page Editor with additional librairies of
tags.
I find some solution on the web but they are not working.
The first solution I have found is to use the extension point
org.eclipse.jst.jsf.common.standardMetaDataFiles. I create my XML file
similary to the existing one in the plugin standarttag used in Eclipse.
This solution don't work for me.
The second solution is to use the extension point
org.eclipse.jst.pagedesigner.pageDesignerExtension. I success in modifying
the palette but it is now empty.
I think the first solution is the solution I need, but I don't unterstand
why it is not working for me.
Thank you
Thomas
Re: Extending palette Web Page Editor [message #231308 is a reply to message #231276] Thu, 14 May 2009 04:22 Go to previous messageGo to next message
Hi Thomas,
I'am a french student.
I'am doing what you are trying to do and it works fine for me.
If you need some help and precise questions tell me.
Look at the uri's you defined. Are they the same in the extension point
and in the file ?
Re: Extending palette Web Page Editor [message #231315 is a reply to message #231308] Thu, 14 May 2009 04:42 Go to previous messageGo to next message
yes I have the same URI.
This is my xml file, it is just a simple new tag added in a new category
in the palette :
<md:metadatamodel
xmlns:ecore="http://www.eclipse.org/emf/2002/Ecore"
xmlns:md="http://org.eclipse.jst.jsf.common.metadata/metadata.ecore"
xmlns:mdt=" http://org.eclipse.jst.jsf.common.metadata/metadataTraitType s.ecore"
xmlns:pi="http://org.eclipse.jsf.pagedesigner/paletteInfos.ecore"
id="newtag"
type="tagFile">
<entity id="form" type="tag">
<trait id="display-label">
<value>Form</value>
</trait>
</entity>
</md:metadatamodel>
This is my extension point :
<?eclipse version="3.2"?>
<plugin>
<extension
point="org.eclipse.jst.jsf.common.standardMetaDataFiles">
<standardMetaDataFile
location="metadata/html-edf.xml"
uri="newtag">
</standardMetaDataFile>
</extension>
</plugin>
Perhaps there are other things to do in order to make the plugin works.
Thank you.
Thomas
PS: if you want to speak in French, perhaps we cant have a mail
conversation , clavier.thomas@gmail.com or clavierthomas@hotmail.fr
Re: Extending palette Web Page Editor [message #231321 is a reply to message #231315] Thu, 14 May 2009 05:02 Go to previous messageGo to next message
clavier.thomas is a gmail adress
thomasclavier is a hotmail.fr adress
Thank you
Thomas
Re: Extending palette Web Page Editor [message #539237 is a reply to message #231321] Thu, 10 June 2010 02:57 Go to previous messageGo to next message
Hi thomes i m also trying to add some new tags support to web page editor's pallet.
Please let me know the approach to do the same.
Thanx
Love Khanna
Re: Extending palette Web Page Editor [message #545031 is a reply to message #539237] Tue, 06 July 2010 09:20 Go to previous messageGo to next message
Hi All,
It would be highly appreciated if you could share details of the correct implementation for adding custom items to the wpe palette.
I made the configuration of metadata files, associated with plugin manifest, but couldn't find the proper way to set these as Palette items.
Could someone who already figured it out help?
Not much progress so far...
Thanks in advance and kind regards,
Victor Vieira
[Updated on: Tue, 06 July 2010 09:22] by Moderator
Re: Extending palette Web Page Editor [message #630818 is a reply to message #231276] Tue, 05 October 2010 03:49 Go to previous message
No Message Body
[Updated on: Tue, 05 October 2010 03:51] by Moderator
Previous Topic:StructuredTextEditor for Java Script
Next Topic:Problem to build Java source from wsdl
Current Time: Sat Jul 19 07:01:44 EDT 2025
Powered by FUDForum. Page generated in 0.03995 seconds
