Home » Modeling » GMF (Graphical Modeling Framework) » Adding attribute for relationship between entities
Adding attribute for relationship between entities [message #231046] Fri, 22 May 2009 05:54 Go to next message
What I am trying to do is to have a gmf model with two entity e1 and e2
with a relationship and one attribute for the relationship. I do not want
to have an intermediate entity as relationship on my gmf diagram.
Best,
Alireza
Re: Adding attribute for relationship between entities [message #231062 is a reply to message #231046] Fri, 22 May 2009 06:05 Go to previous messageGo to next message
Hello Alireza,
Just use LinkMapping with only linkMetaFeature specified.
Alex Shatalin
Re: Adding attribute for relationship between entities [message #231071 is a reply to message #231062] Fri, 22 May 2009 06:09 Go to previous messageGo to next message
Well, I did not get it really! This attribute is like a real attribute,
not just a runtime annotation or note.
I checked the link mapping and I did not find linkmetafeature, where is
it? and what is it?
Re: Adding attribute for relationship between entities [message #231095 is a reply to message #231071] Fri, 22 May 2009 07:16 Go to previous messageGo to next message
Hello Alireza,
> mapping and I did not find linkmetafeature, where is it? and what is
> it?
Sorry, it called "Target feature" in UI.
Alex Shatalin
Re: Adding attribute for relationship between entities [message #231101 is a reply to message #231095] Fri, 22 May 2009 08:09 Go to previous messageGo to next message
It seems that this target feature determines the end direction of the
link, is it right?
Suppose that we have two entity: customer and items and the link between
them shows the customer buys the item. This relationship has a attribute
name quantity (how many of the item is bought by the customer), I want to
have it as a label for the link. This attribute first should be defined
somewhere in the ecore model, but where? and then how it can be added to
the gmf diagram, maybe as a label for link mapping or ...?
Re: Adding attribute for relationship between entities [message #231132 is a reply to message #231101] Fri, 22 May 2009 09:40 Go to previous messageGo to next message
Hello Alireza,
Ok. then you have to set following properties for the link mapping:
- Containment Feature = Customer.links
- Element = Link (EClass representing relationship and having "quantity"
attribute)
- TargetFeature = Link.items
Then in accordance with GMF tutorial you can add label for this link representing
quantity attribute.
As an example you can use Ecore diagram editor - diagram editor generated
by GMF. In this editor EReference links are representing this type of links.
Alex Shatalin
Re: Adding attribute for relationship between entities [message #231159 is a reply to message #231132] Sun, 24 May 2009 12:59 Go to previous messageGo to next message
To tell the truth, I could not figure out what you sent me in last post :(
Could you please give more explanation or ...?
Re: Adding attribute for relationship between entities [message #231178 is a reply to message #231159] Mon, 25 May 2009 06:27 Go to previous messageGo to next message
Hello Alireza,
> post :( Could you please give more explanation or ...?
I suggest you to read all parts of GMF tutorial (http://wiki.eclipse.org/index.php/GMF_Tutorial)
- your use case should be covered there.
Alex Shatalin
Re: Adding attribute for relationship between entities [message #231215 is a reply to message #231178] Mon, 25 May 2009 08:18 Go to previous messageGo to next message
Dear Alex Shatalin,
I have reviewed the gmf tutorials again, in tutorial three there is a part
that seems to be related to my problem, but it is not. It try to create 3
relationships based on relationship type attribute, wheres the attribute
of the relationship in my case can be arbitrary number.
Could you please help me to handle this? I have already spent a lot of
time for it ... :(
Re: Adding attribute for relationship between entities [message #231222 is a reply to message #231215] Mon, 25 May 2009 10:24 Go to previous message
Dear Alex Shatalin,
Finally I did it :) Thank you very much.
Best,
Ali
Previous Topic:Multiple labels/Parser
Next Topic:Labels broken?
Current Time: Sat Jul 19 16:53:39 EDT 2025
Powered by FUDForum. Page generated in 0.05042 seconds
