Home » Language IDEs » ServerTools (WTP) » Re: Ident, not Format, in XML files
Re: Ident, not Format, in XML files [message #229219] |
Thu, 19 March 2009 06:22  |
Raul,
I don't have WTP installed, but I wonder if there are formatting
preferences such that you can tell it not to break long lines... Have
you looked at the preferences for this?
It might be better to ask this question on the web tools newsgroups, so
I've added it to the "to" list of the reply.
Raul Acevedo wrote:
> Is there a way to get Eclipse to ONLY indent a line in XML files?
> Ctrl-I is bound to "Format Active Elements", and I don't see any
> commands that will simply indent the current line.
> Raul Acevedo
> http://www.cantara.com
Re: Ident, not Format, in XML files [message #229279 is a reply to message #229272] |
Thu, 19 March 2009 14:51   |
Originally posted by: dcarver.starstandard.org
Select the line you want to format, then press CTRL+SHFT+F
If you have multiple lines, you want to format, select them and do the
same thing.
Dave
Raul Acevedo wrote:
> I've tried every option, plus key bindings, to make this happen but it
> just doesn't.
> Is there a way to make the XML editor only indent without screwing up
> the entire line, or should I just file a bug for this?
> Raul Acevedo
Current Time: Sun Jul 20 10:46:25 EDT 2025
Powered by FUDForum. Page generated in 0.28322 seconds
