Publish deletes read-only files [message #227552] |
Sun, 08 February 2009 19:53  |
Originally posted by: nowhere.a.com
My web app creates XML files within the WEB-INF directory
structure.This is on a Windows machine.
When I make a change to the source code, WPT updates the web app files
within the Tomcat directory structure. This includes deleting
extraneaous files. Basically a mirror is being done. This is as it
should be.
But, if I set a file as read-only after it is created, then I do want
that file to survive a publish. I want the file to be there the next
time my web app runs.
However WPT still deletes the file. It must be deliberate as the
initial delete must fail, and the file must be then set by WPT as
writeable before it is deleted.
So this is a defined behaviour. Why?
Wojtek :-)
Re: Publish deletes read-only files [message #227569 is a reply to message #227559] |
Mon, 09 February 2009 10:59  |
Larry Isaacs wrote :
> With respect to projects, its publishing's task to synchronize the published
> content with the project. If there is something in the published content
> that doesn't exist in the project, it is assumed to have been deleted from
> the project and needs to be deleted from the published content.
Ok, I can see that. Though a file marked as read only could be
considered a deliberate, user created exception to the rule.
Anyway I have a workable solution.
Wojtek :-)
FUDForum. Page generated in 0.04329 seconds
