Home » Language IDEs » C / C++ IDE (CDT) » regular expression error parser
regular expression error parser [message #227315] Thu, 27 November 2008 04:27 Go to next message
I've implemented a general error parser, which reads regular expressions
from a text file. This way you don't have to write a plug-in for your
tools, but only edit the regular expressions. It is licensed under EPL,
so you can also use sources.
http://www.isystem.com/5653/Develop._Software/Products/Eclip se.html/
The document "How to convert a winIDEA project to an Eclipse project?"
linked on the same site has a section, which describes how to configure
the Cygwin toolchain to cross compile for ARM - I think this was also a
question on this list some time ago. It is not a clean solution, but it
works.
Marko
Re: regular expression error parser [message #227373 is a reply to message #227315] Thu, 27 November 2008 14:07 Go to previous message
I think that an error parser like that would greatly facilitate using CDT
for other languages. Do you plan contributing it to CDT?
The problem view would also display not only errors and warnings but also
infos. You could add this to your parser.
> works.
Andrew
Previous Topic:problem with debugging dll.
Next Topic:Changing the type of folder
Current Time: Sat Jul 19 14:35:24 EDT 2025
Powered by FUDForum. Page generated in 0.25208 seconds
