.html files always Shift_JIS regardless of preferences or content [message #227305] |
Tue, 27 January 2009 01:44  |
Originally posted on eclipse.platform and was advised to post here.
Eclipse 3.4 on Linux (was also true in 3.3):
If I create a new *empty* .html file, it is always created with a file
encoding of Shift_JIS, "determined from content". It doesn't matter how
I create the file... I can create an empty, 0 byte file outside of
Eclipse and Eclipse still sets the encoding to Shift_JIS "determined
from content".
If I copy an existing file, containing an html snippet (no headers),
which has UTF-8 content, for which I have manually set the encoding to
UTF-8, to another location, the encoding is reset to Shift_JIS on the copy.
An annoying side note is that when I do reset the encoding type (in
Navigator/Properties), Eclipse tells me UTF-8 conflicts with the content
type *even if the file is empty or contains UTF-8 content*.
This is a major headache for me (apart from the need to manually reset
the content type on every such file) because editing and saving a file
with UTF-8 content, that Eclipse thinks is Shift_JIS, results in
permanently corrupted Japanese text.
Related issue: Somehow in the last few days all of the files (hundreds)
I had painstakingly set to UTF-8 have reverted to Shift_JIS. Don't know
how this happened, but maybe when I was messing with preferences. Is
there any way I can reset the encoding on all the files, rather than
one-by-one?
settings:
env var LANG = ja_JP.utf8
parent folder text file encoding set to UTF-8
preferences:web:html files encoding set to UTF-8
preferences:general:content types:text:html default encoding for all
file associations set to UTF-8
In <project>/.settings/org.eclipse.core.resources.prefs ALL the file
encodings show as UTF-8..... nevertheless, in Navigator/Properties they
show as Shift_JIS.
Am I missing something somewhere? Is this a bug? (Ain't no feature in my
book :) )
Any help much appreciated.
Ed
Re: .html files always Shift_JIS regardless of preferences or content [message #227386 is a reply to message #227305] |
Tue, 27 January 2009 14:39   |
Hi Ed,
This may be related to https://bugs.eclipse.org/bugs/show_bug.cgi?id=237567.
Ed Wright wrote:
> from content".
> one-by-one?
> settings:
> show as Shift_JIS.
> book :) )
> Ed
FUDForum. Page generated in 0.05036 seconds
