Home » Language IDEs » ServerTools (WTP) » PermGem-Ganymede Drivine me crazy!
PermGem-Ganymede Drivine me crazy! [message #226837] Sun, 18 January 2009 06:41 Go to next message
I normally use Eclipse Europa but upgraded to Ganymede because I wanted to
develop web services. I downloaded WebTools plugin etc. Everything is fine
on that front however I keep getting out of memory errors.
I have a dual core laptop with 2Gs of Ram. I cant
develop anything because eclipse keeps crashing due to out of memory error
(PermGen)...pasted below.
I have edited my eclipse.ini file in attempt to overcome this but to no
avail... but I am no expert on this.. any help/ideas appreciated..my .ini
file is
pasted below the error...
T
!ENTRY org.eclipse.ui 4 0 2009-01-17 14:58:30.390
!MESSAGE Unhandled event loop exception
!STACK 0
java.lang.OutOfMemoryError: PermGen space
at java.lang.ClassLoader.defineClass1(Native Method)
at java.lang.ClassLoader.defineClass(Unknown Source)
at
org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.def ineClass(DefaultClassLoader.java:165)
at
org.eclipse.osgi.baseadaptor.loader.ClasspathManager.defineC lass(ClasspathManager.java:554)
at
org.eclipse.osgi.baseadaptor.loader.ClasspathManager.findCla ssImpl(ClasspathManager.java:524)
at
org.eclipse.osgi.baseadaptor.loader.ClasspathManager.findLoc alClassImpl(ClasspathManager.java:455)
at
org.eclipse.osgi.baseadaptor.loader.ClasspathManager.findLoc alClass_LockClassLoader(ClasspathManager.java:443)
at
org.eclipse.osgi.baseadaptor.loader.ClasspathManager.findLoc alClass(ClasspathManager.java:423)
at
org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.fin dLocalClass(DefaultClassLoader.java:193)
at
org.eclipse.osgi.framework.internal.core.BundleLoader.findLo calClass(BundleLoader.java:368)
at
org.eclipse.osgi.framework.internal.core.BundleLoader.findCl assInternal(BundleLoader.java:444)
at
org.eclipse.osgi.framework.internal.core.BundleLoader.findCl ass(BundleLoader.java:397)
at
org.eclipse.osgi.framework.internal.core.BundleLoader.findCl ass(BundleLoader.java:385)
at
org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.loa dClass(DefaultClassLoader.java:87)
at java.lang.ClassLoader.loadClassInternal(Unknown Source)
at
at
at
at
at
at
at
at
at
at
at
at
!SESSION Sat Jan 17 14:58:40 GMT 2009
!ENTRY org.eclipse.equinox.launcher 4 0 2009-01-17 14:58:40.359
!MESSAGE Exception launching the Eclipse Platform:
!STACK
eclipse.ini
-showsplash
org.eclipse.platform
--launcher.XXMaxPermSize
512M
-framework
plugins\org.eclipse.osgi_3.4.2.R34x_v20080826-1230.jar
-vmargs
-Dosgi.requiredJavaVersion=1.5
-Xms256m
-Xmx512m
Re: PermGem-Ganymede Drivine me crazy! [message #226866 is a reply to message #226837] Mon, 19 January 2009 12:16 Go to previous messageGo to next message
Here is my eclipse.ini
-startup
plugins\org.eclipse.equinox.launcher_1.0.101.R34x_v20080819. jar
--launcher.library
plugins\org.eclipse.equinox.launcher.win32.win32.x86_64_1.0. 101.R34x_v20080731
-showsplash
-vmargs
-XX:MaxPermSize=256m
-Xms128m
-Xmx712m
You should increase your PermGenSpace available by modifying this line
"-XX:MaxPermSize=256m"
Nicolas Bihan
Tori a écrit :
> fine on that front however I keep getting out of memory errors.
> .ini file is
> Thanks
> T
> !STACK 0
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at java.lang.ClassLoader.loadClass(Unknown Source)
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> !STACK
> eclipse.ini
> -showsplash
> 512M
> -framework
> -vmargs
> -Xms256m
> -Xmx512m
Re: PermGem-Ganymede Drivine me crazy! [message #226872 is a reply to message #226837] Tue, 20 January 2009 09:35 Go to previous messageGo to next message
Originally posted by: eclipse-news.rizzoweb.com
On 1/18/2009 6:41 AM, Tori wrote:
> -showsplash
> 512M
> -framework
> -vmargs
> -Xms256m
> -Xmx512m
Your ini is not specifying the JVM, so the --launcher arg may not be
applying. Without telling it, Eclipse will try to find a JVM on your
system; that means you don't really know which one it will get.
Use the -vm parameter to tell it the exact location of your JVM
executable, as described in http://wiki.eclipse.org/Eclipse.ini (pay
careful attention to the format decribed there).
Also, there should be no need to specify permgen space of 512MB; 256MB
is plenty to run Eclipse with Web Tools (and a lot more).
Hope this helps,
Eric
Re: PermGem-Ganymede Drivine me crazy! [message #226941 is a reply to message #226872] Wed, 21 January 2009 11:09 Go to previous message
Thanks guys.......
Previous Topic:jsNature causing problem markers
Next Topic:JSDT Support JS frameworks
Current Time: Sun Jul 20 19:45:40 EDT 2025
Powered by FUDForum. Page generated in 0.04089 seconds
