Home » Language IDEs » ServerTools (WTP) » DSE SQL execution causes "Method can be called only once" error
DSE SQL execution causes "Method can be called only once" error [message #226785] Thu, 15 January 2009 16:40 Go to next message
I submit a rather simple query (see below) that generates one row of
output. After the result row is displayed, my eclipse platform goes into
a loop generating the message "Method can be called only once." until I
kill the query.
I've checked the Error log and there are no entries with further
information regarding this problem.
This message loop occurs regardless of the SQL. In all cases, the SQL
executes normally, and the result row(s) displayed followed by this
message.
Any suggestions will be welcomed.
query:
select prop_id, sum(los) from stay where prop_id = 1 group by prop_id;
result:
prop_id (sum)
1 1857
Re: DSE SQL execution causes "Method can be called only once" error [message #226791 is a reply to message #226785] Thu, 15 January 2009 16:41 Go to previous message
Sorry, I should mention that I running the Ganymede 3.4.1 Java EE version.
Previous Topic:Eclipse and Glassfish
Next Topic:Web Services Explorer for UDDI v3
Current Time: Sun Jul 20 15:20:22 EDT 2025
Powered by FUDForum. Page generated in 0.04050 seconds
