Home » Eclipse Projects » GEF » How to print diagram name in header or footer?
How to print diagram name in header or footer? [message #226473] Tue, 14 November 2006 03:43 Go to next message
Originally posted by: shruthi.cn.in.bosch.com
Hello everybody,
I have a ScrollingGraphicalViewer viewer which displays some GEF diagrams.
I want to print the diagram name in either header or footer.
This is the code that i use for printing.
PrintDialog dialog = new PrintDialog(shell, SWT.NULL);
PrinterData data = dialog.open();
if (data != null) {
PrintGraphicalViewerOperation op = new PrintGraphicalViewerOperation(
new Printer(data), baseViewer);
op.setPrintMode(PrintFigureOperation.FIT_PAGE);
op.run("test");
In the above code, baseViewer is of type ScrollingGraphicalViewer.
How can i print the diagram name in header or footer.
Please help me.
Thank you,
Best Regards
Shruthi
Re: How to print diagram name in header or footer? [message #226506 is a reply to message #226473] Tue, 14 November 2006 16:27 Go to previous messageGo to next message
Hi Shruthi,
GEF does not provide a way to print headers and footers on diagram
printouts.
If you are interested in printing a header and footer you'll have to
extend GEF's printing support which will involve some SWT work.
You could implement your own print operation class (perhaps something
like PrintGraphicalViewerWithHeaderOperation) that extends
PrintGraphicalViewerOperation. This class would have a constructor that
accepts a string describing the header.
You would also need to override the printPages() method and provide your
own implementation. This is where you'll print the header and/or
footer. I'd suggest taking the code from
PrintFigureOperation#printPages, pasting it into your new method and
modifying it to print the header and/or footer.
For some ideas on how to output text to a printer and how to position
it, you can have a look at the code snippet in the description of
http://bugs.eclipse.org/bugs/show_bug.cgi?id=96674. It is basically the
SWT hello world example modified to output to a printer.
David
shruthi wrote:
> Hello everybody,
> diagrams. I want to print the diagram name in either header or footer.
> if (data != null) {
> op.run("test");
> Please help me.
> Thank you,
> Best Regards
> Shruthi
Re: How to print diagram name in header or footer? [message #237772 is a reply to message #226506] Wed, 08 August 2007 11:00 Go to previous message
Hi shruti,
I've got a very similar problem. I want to print the graphic of my
GEF-Editor with a footer on each page.
Unfortunately I haven't been able to print my footer yet, although I
tried the hints mentioned below. I wrote my own PrintAction which starts
my own PrintGraphicalViewerWithFooterOperation.
In the Operation I tried modifying the code of the printPages()-method
but with no effect except that I got quite more pages than the graphic
originally needed (needes 3 pages I got 89!!)
I tried the code of the Bug mentioned below but all I got was some
errors while instantiating the GC (graphicsContext) with the printer I used.
So this code hasn't been much use.
Have you been able to print a header/footer yet?
If so, could you provide some code-snippets for me?
Thanks in advance
Alex Haag
David Cummings schrieb:
> Hi Shruthi,
> printouts.
> David
> shruthi wrote:
>> Hello everybody,
>> if (data != null) {
>> op.run("test");
>> Please help me.
>> Thank you,
>> Best Regards
>> Shruthi
Previous Topic:MultiPageEditorActionBarContributor delete action
Next Topic:isDirty
Current Time: Sat Jul 19 23:46:17 EDT 2025
Powered by FUDForum. Page generated in 0.03995 seconds
