Home » Language IDEs » ServerTools (WTP) » Where are bracket insertion and code folding?
Where are bracket insertion and code folding? [message #225969] Tue, 06 January 2009 08:31 Go to next message
Hi all,
Where are bracket insertion (i.e. you press "(" and JSDT inserts ")",
places your cursor in between the parens, allows you to edit, waiting for
you to press ")" or tab, then places the cursor outside the ")") and code
folding in the JSDT source code? I cannot find them.
Thanks!
Bret
Re: Where are bracket insertion and code folding? [message #225977 is a reply to message #225969] Tue, 06 January 2009 10:49 Go to previous messageGo to next message
Originally posted by: dcarver.starstandard.org
Check your Preferences. Windows->Preferences->JavaScript->Editor->Folding
Will get you the code folding options. The other options are probably
under Editor->Content Assist in the preference page.
Dave
Bret Schuhmacher wrote:
> Hi all,
> for you to press ")" or tab, then places the cursor outside the ")") and
> code folding in the JSDT source code? I cannot find them.
> Thanks!
> Bret
Re: Where are bracket insertion and code folding? [message #225983 is a reply to message #225977] Tue, 06 January 2009 10:52 Go to previous messageGo to next message
Rats - I wasn't explicit enough. Sorry, I'm not talking about *using* the
JSDT, I'm talking about from the Java coding and extending side of things.
Which *.java source module encapsulates those two features? I need to
see how it's done so I can use/duplicate those functionalities in plugin
I'm developing.
Thanks!
Bret
Re: Where are bracket insertion and code folding? [message #225990 is a reply to message #225969] Tue, 06 January 2009 11:02 Go to previous messageGo to next message
> Hi all,
> Thanks!
> Bret
Bret,
As far as bracket insertion, check out the inner class BracketInserter
that's part of the CompilationUnitEditor in org.eclipse.wst.jsdt.ui.
I think the folding code you're looking for is in
DefaultJavaFoldingStructureProvider#computeFoldingStructure in plugin
Nick
Re: Where are bracket insertion and code folding? [message #226146 is a reply to message #225990] Wed, 07 January 2009 10:49 Go to previous message
Thanks, Nick. Yep, that would explain why I couldn't find it - I seem to
have an incomplete source code dist for some reason. I'm missing the "ui"
directory you mentioned.
Thanks!
Bret
Previous Topic:WYSIWYG editor for html
Next Topic:Eclipse and Glassfish
Current Time: Sat Jul 19 23:41:47 EDT 2025
Powered by FUDForum. Page generated in 0.04545 seconds
