Home » Modeling » GMF (Graphical Modeling Framework) » Retrieve EditPart by EObject and Diagram
Retrieve EditPart by EObject and Diagram [message #225796] Tue, 14 April 2009 08:31 Go to next message
Originally posted by: ralph.schreder.gmx.de
Hi All!
Is there a possiblity to retrieve the EditPart that "represents" an EObject
in a diagram from the EObject itself?
I haven't found a solution for that problem! Any help appreciated!!!
protected EContentsEList.FeatureIterator<EObject>
getCrossReferences(EObject eObject)
EContentsEList.FeatureIterator<EObject> iter =
(EContentsEList.FeatureIterator<EObject>)
((InternalEList<EObject>)eObject.eCrossReferences()).basicIterator();
return iter;
I found an answer (2008), but I can´t understand it. I get null elements
for
CrossReferencer-Iterator.
The answer to the question in the email:
(Use CrossReferencer or traverse Notation model manually to find
corresponding notation model element. Then using
EditPartViewer.getEditPartRegistry() you can get EditPart associated
with this View.)
Thanks in advance,
Ralph
Re: Retrieve EditPart by EObject and Diagram [message #225825 is a reply to message #225796] Tue, 14 April 2009 08:52 Go to previous message
Hi Ralph,
In GMF, the ecore model used is agnostic of GMF API, if you want fetch
corresponding EditPart you must get RootEditPart corresponding to you
root model element and iterate through childs (perhaps with
getChildBySemanticHint() ) and check with getHostObject() if the current
EditPart correspond to your EObject.
Ralph a écrit :
> Hi All!
> return iter;
> for
> with this View.)
> Thanks in advance,
> Ralph
Previous Topic:How to get the figures and their acions in the GMF editor?
Next Topic:how can i make a figure inmobile
Current Time: Sun Jul 20 11:33:27 EDT 2025
Powered by FUDForum. Page generated in 0.04065 seconds
