Home » Modeling » GMF (Graphical Modeling Framework) » Affixed Parent Side VS Compartment
Affixed Parent Side VS Compartment [message #222780] Wed, 25 March 2009 15:26 Go to next message
Originally posted by: rivera.lcc.uma.es
Hi all,
I'm trying to create a diagram similar to UML activity diagrams. Then, I
have operations with input and output parameters (in a
affixed-parent-side way), and a special kind of operation
(CompositeOperation) which also contains other kind of elements (in a
single compartment).
Everythimng works well but the CompositeOperation. It does not allow me
to contain both kind of elements: in the compartment and in an
affixed-parent-side way. If I add in the mapping model only one of them
it works properly, but when I try with both it does not.
I create "affixed-parent-side" elements (parameters) by:
1. In the Parameters Node element of the gmfgraph setting this property
to NORTH for example.
2. By adding a reference child to the CompositeOperationwith compartment
undefined.
I create "compartment" elements by:
1. Creating a compartment for the CompositeOperation in the gmfgraph
2. By adding a reference child to the CompositeOperation with the
compartment referring to the created in the previous step.
Am i doing something wrong?Do I need to change some properties in one of
the model not to make GMF to confuse with both kind of containments?
Thanks In advance,
Edu
Re: Affixed Parent Side VS Compartment [message #223186 is a reply to message #222780] Mon, 30 March 2009 07:27 Go to previous messageGo to next message
Please,
Has anyone accomplished something like this? I have been trying several
things but I can not find the solution :(
Is there any special property (that i can not find) in the gmfgen that
makes these two kind of containment collapse?
Edu
Jose E. Rivera escribió:
> Hi all,
> undefined.
> Thanks In advance,
> Edu
Re: Affixed Parent Side VS Compartment [message #223210 is a reply to message #223186] Mon, 30 March 2009 08:46 Go to previous messageGo to next message
Hi Jose,
Have a look here:
http://dev.eclipse.org/newslists/news.eclipse.modeling.gmf/m sg03212.html
hth,
Freiric.
Re: Affixed Parent Side VS Compartment [message #223326 is a reply to message #223210] Mon, 30 March 2009 12:29 Go to previous message
Hi Freiric,
Thank you a lot really!I was looking in the news also but I didn't find
this post. thank you again :)
If someone is interested, I just needed to modify generated method
getContentPaneFor of my CompositeOperationEditPart as follows:
protected IFigure getContentPaneFor(IGraphicalEditPart editPart) {
if (editPart instanceof IBorderItemEditPart) {
return getBorderedFigure().getBorderItemContainer();
} else {
return getContentPane();
This was enough :)
Freiric escribió:
> Hi Jose,
> Have a look here:
> hth,
> Freiric.
Previous Topic:Collapse compartment does not work?
Next Topic:Displaying element's child attribute in property view
Current Time: Sat Jul 19 06:49:02 EDT 2025
Powered by FUDForum. Page generated in 0.03411 seconds
