Home » Eclipse Projects » GEF » Problem with Saving
Problem with Saving [message #221694] Thu, 17 August 2006 04:53 Go to next message
Originally posted by: dstamkokeng.gmail.com
Hi, I have a problem with saving changes I made.
I m extending the Shapes example given in GEF. Only after changes made in
the properties view and movement of the shapes figure created, can I do a
save.
Changes made to the shapes models using other methods do not allows me to
save the document.
Where do I mark the document as dirty etc? Thanks alot
Re: Problem with Saving [message #221713 is a reply to message #221694] Thu, 17 August 2006 10:09 Go to previous messageGo to next message
Originally posted by: guerreroderrick.gmail.com
What other methods do you mean? Following is the part of the shapes
example that marks the doc dirty:
in class that defines your graphical editor...
public void commandStackChanged(EventObject arg0) {
firePropertyChange(IEditorPart.PROP_DIRTY);
super.commandStackChanged(arg0);
I bet if you do the firePropertyChange thing somewhere else it should
have the same effect.
Guerrero
> in the properties view and movement of the shapes figure created, can I
> do a save.
> to save the document.
Re: Problem with Saving [message #221766 is a reply to message #221713] Thu, 17 August 2006 23:05 Go to previous messageGo to next message
Hi, what must I do to override the method in ShapesEditor?
My changes to the model does not uses a Command. Actually I have a SWING
textbox and when the user inputs something, it will be saved in the model
and reflected in the diagram.
I tried implementing the exact same thing using the properties view and
changes made in the properties view will allow me to save. However when
the change is done in the SWING textbox, it does not.
I try calling the editor's commandStackChanged(EventObject event) method
in the SWING textbox code by passing a null for the event and it does not
allows me to save.
What exactly enables a document to be savable? Sorry for the lengthy post.
Re: Problem with Saving [message #221774 is a reply to message #221766] Thu, 17 August 2006 23:37 Go to previous message
I think it is the firePropertyChange(IEditorPart.PROP_DIRTY) which makes
the document dirty and thus enables saving.
I tried calling the firePropertyChange method directly in my code after
changing the method to public, but I am unable to save. Anybody has any
idea how to do saving?? Desperate....:(
Previous Topic:Is it possible to print TreeView
Next Topic:Child drop offset problem
Current Time: Sun Jul 20 03:34:04 EDT 2025
Powered by FUDForum. Page generated in 0.06793 seconds
