Home » Modeling » GMF (Graphical Modeling Framework) » ports
ports [message #221327] Thu, 12 March 2009 12:48 Go to next message
I'm new to GMF, and absolutely know nothing about GEF. My question is: How
to make a shape with some connection points. I mean something similar as
in "logic example" but that is in GEF. I want to have a shape with ports
to which a connection can be added. I want to make target ports occupied
if there is a connection and more connection to be able from source ports.
But in EMF model I want to store it as a collection of connections (so in
EMF I don't care to which port exactly is the connection connected). Is it
possible, with use of GMF?
Fero
Re: ports [message #221370 is a reply to message #221327] Fri, 13 March 2009 08:37 Go to previous messageGo to next message
Hello Frantisek,
It is possible to generate code placing child element from the domain model
onto the border of it's parent. To do that you have to set AffixedParentSide
property in .gmfgraph model.
If you need to create these port only on a diagram without any connection
with domain model elements then you probably have to code it manually.
Alex Shatalin
Re: ports [message #221406 is a reply to message #221370] Fri, 13 March 2009 12:46 Go to previous messageGo to next message
Hi Alex, thanks for advice I will look at it. But I think you suggest that
port would be in a model as a child of a node. That's not what I want (I
want only connections to be many attribute in my model). It should only be
in graphics representation.
Or maybe I won't use the ports. Is it possible to make a node that all
incoming connections will be routed to the left side and all outgoing
leaving from right side?
Thanks for answers
Fero
Re: ports [message #221414 is a reply to message #221406] Fri, 13 March 2009 13:05 Go to previous messageGo to next message
Hello Frantisek,
I think it should be possible by using/implementing appropriate ConnectionAnchor.
See org.eclipse.gmf.runtime.gef.ui.figures.NodeFigure.getConnect ionAnchor()/getConnectionAnchorTerminal()
+ try searching in this neasgroup for the related postings.
Alex Shatalin
Re: ports [message #221440 is a reply to message #221414] Fri, 13 March 2009 17:45 Go to previous message
Thanks Alex, I will search and post a solution if I find it.
Previous Topic:[Announce] GMF 2.2.0 I200903131142 is available
Next Topic:Capture mouse events on GMF canvas/palette
Current Time: Sun Jul 20 08:46:56 EDT 2025
Powered by FUDForum. Page generated in 0.24875 seconds
