doPost doGet not generated [message #221232] |
Thu, 11 September 2008 03:14  |
I created a Web/Servlet class, and checked doPost() and doGet() but the
stub methods and imports were not generated.
All I got was a blank file.
Re: doPost doGet not generated [message #221561 is a reply to message #221521] |
Thu, 18 September 2008 07:26  |
Hi Yaroslav,
It seems you have found a bug. It will be very much appreciated if you open
a bug in Eclipse Bugzilla:
https://bugs.eclipse.org/bugs/enter_bug.cgi?product=WTP%20Ja va%20EE%20Tools
If possible, please attach in the bug an example workspace which the problem
can be reproduced with.
Greetings, Kaloyan
"Yaroslav " <yarosla@gmail.com> wrote in message
news:dee99d47fcdb4e7cc07b144aae25ea46$1@www.eclipse.org...
> Hi Kaloyan!
> Your solution helped. Thank you very much!
> Before upgrading to 3.0.1 I had 3.0.0 (I installed brand new Ganymede
> release and imported my projects into it). And servlet generation worked
> in it (I made many servlets in Ganymede before upgrading to 3.0.1).
> Regards,
> Yaroslav
> Kaloyan Raev wrote:
>> Yaroslav,
>> What was the WTP version before upgrading to 3.0.1?
>> It seems that you had the .JETEmitter already available before the
>> upgrade and after the upgrade it still refers to some old jars...
>> The workaround is to delete the .JETEmitter project from your workspace.
>> Next time you generate a Servlet, it will be recreated and everything
>> should be fine.
>> Greetings,
>> Kaloyan
>> news:6ef6ae02fc704bf8fec23d242d1b23d9$1@www.eclipse.org...
>>>I have the same problem. But the workaround presented in bug report did
>>>not help. I had compiler compliance level 1.6. Switching to 1.5 did not
>>>help.
>>> As I made .JETEmitters project visible I can see many errors in its
>>> source code:
>>> The method removeFlags(int) is undefined for the type
>>> CreateServletTemplateModel ServletTemplate.java
>>> .JETEmitters/src/org/eclipse/jst/j2ee/web line 89 Java Problem
>>> and lots of similar errors for other methods of the same class.
>>> It worth mentioning that I did not have any problems with servlet code
>>> generation until I updated to 3.0.1 version of JST, WTP, etc.
FUDForum. Page generated in 0.05943 seconds
