Home » Eclipse Projects » GEF » setting a viewport
setting a viewport [message #220389] Mon, 31 July 2006 07:17 Go to next message
Originally posted by: osipov.appliedtech.ru
Hi, everybody!
Is there any way I can set a viewport for my gef-editor?
I know it will result in scrollbars appearing, but that is ok.
All I want to do is to make (0,0) being in the middle at the very
beginning - there I draw a small red cross. Of course I can do it by just
recalculating that shift internally and always add/subtract it, but why
bother?
thanks a lot.
Re: setting a viewport [message #220485 is a reply to message #220389] Mon, 31 July 2006 15:38 Go to previous messageGo to next message
Originally posted by: none.unknown.com
FigureCanvas has a setViewport() method, but there's probably an easier way
to do what you want.
"Peter Osipov" <osipov@appliedtech.ru> wrote in message
news:eakosr$p9l$1@utils.eclipse.org...
> Hi, everybody!
> bother?
> thanks a lot.
Re: setting a viewport [message #220499 is a reply to message #220485] Tue, 01 August 2006 01:10 Go to previous messageGo to next message
Hi, Pratik!
Thanks for your reply.
What I was trying to do is this:
FigureCanvas editor = getEditor();
Viewport viewport = editor.getViewport();
viewport.getHorizontalRangeModel().setMinimum(-2000);
viewport.getVerticalRangeModel().setMinimum(-2000);
viewport.setViewLocation(-2000, -2000);
Before that I was not using this two lines:
But all in all the viewport is not changed at all. In debug mode I see that
for RangeModel those values are changed, but nothing happens. I wander what
is going on. :-|
$qbs$1@utils.eclipse.org...
way
> > Hi, everybody!
just
> > bother?
> > thanks a lot.
Re: setting a viewport [message #220527 is a reply to message #220499] Tue, 01 August 2006 12:26 Go to previous messageGo to next message
That's too hacky. You definitely don't want to go down that route.
Instead, what you can do is have your primary layer report a different
preferred size. Assuming your primary layer is a freeform layer, it will
report its freeform extents based on any children. You could override it to
report certain minimum bounds even if there are no children. Then, it's a
simple matter of scrolling the diagram when the editor's opened (setting the
range model's initial value to be some negative coordinate instead of 0,0).
news:eamnne$lr3$1@utils.eclipse.org...
> Hi, Pratik!
> that
> what
> is going on. :-|
> way
>> > Hi, everybody!
> just
>> > bother?
>> > thanks a lot.
Re: setting a viewport [message #220548 is a reply to message #220527] Tue, 01 August 2006 23:53 Go to previous message
Hi, Pratik!
That sounds very reasonable. I was guessing that something with layer bounds
has to be done, but without your piece of advice it would have been a long
way. Let me try it.
Thanks again for your support very much.
to
the
0,0).
> > Hi, Pratik!
> > that
> > what
> > is going on. :-|
> > way
> >> > Hi, everybody!
> > just
why
> >> > bother?
> >> > thanks a lot.
Previous Topic:Connection/Bendpoint problem during first creation
Next Topic:Guides working but not visible
Current Time: Sat Jul 19 09:04:20 EDT 2025
Powered by FUDForum. Page generated in 0.04499 seconds
