setting a viewport [message #220389] |
Mon, 31 July 2006 07:17  |
Originally posted by: osipov.appliedtech.ru
Hi, everybody!
Is there any way I can set a viewport for my gef-editor?
I know it will result in scrollbars appearing, but that is ok.
All I want to do is to make (0,0) being in the middle at the very
beginning - there I draw a small red cross. Of course I can do it by just
recalculating that shift internally and always add/subtract it, but why
bother?
thanks a lot.
Re: setting a viewport [message #220527 is a reply to message #220499] |
Tue, 01 August 2006 12:26   |
Originally posted by: none.unknown.com
That's too hacky. You definitely don't want to go down that route.
Instead, what you can do is have your primary layer report a different
preferred size. Assuming your primary layer is a freeform layer, it will
report its freeform extents based on any children. You could override it to
report certain minimum bounds even if there are no children. Then, it's a
simple matter of scrolling the diagram when the editor's opened (setting the
range model's initial value to be some negative coordinate instead of 0,0).
"Peter Osipov" <osipov@appliedtech.ru> wrote in message
news:eamnne$lr3$1@utils.eclipse.org...
> Hi, Pratik!
> Thanks for your reply.
> What I was trying to do is this:
> FigureCanvas editor = getEditor();
> Viewport viewport = editor.getViewport();
> viewport.getHorizontalRangeModel().setMinimum(-2000);
> viewport.getVerticalRangeModel().setMinimum(-2000);
> viewport.setViewLocation(-2000, -2000);
> Before that I was not using this two lines:
> But all in all the viewport is not changed at all. In debug mode I see
> that
> for RangeModel those values are changed, but nothing happens. I wander
> what
> is going on. :-|
> $qbs$1@utils.eclipse.org...
>> FigureCanvas has a setViewport() method, but there's probably an easier
> way
>> to do what you want.
>> news:eakosr$p9l$1@utils.eclipse.org...
>> > Hi, everybody!
> just
>> > bother?
>> > thanks a lot.
Re: setting a viewport [message #220548 is a reply to message #220527] |
Tue, 01 August 2006 23:53  |
Hi, Pratik!
That sounds very reasonable. I was guessing that something with layer bounds
has to be done, but without your piece of advice it would have been a long
way. Let me try it.
Thanks again for your support very much.
to
the
0,0).
> > Hi, Pratik!
> > that
> > what
> > is going on. :-|
> > way
> >> > Hi, everybody!
> > just
why
> >> > bother?
> >> > thanks a lot.
FUDForum. Page generated in 0.05389 seconds
