Home » Archived » Voicetools » TTS Portuguese Characters
TTS Portuguese Characters [message #21987] Thu, 12 March 2009 19:07 Go to next message
For Portuguese Language
when I try to use a TTS prompts with this Latin characters(é,ã) ,I have a
wrong exporting WAR. When I export the Call Flow as a Web Application I
get the error: null Reason: null!!!!
How can I configure this in OpenVxml 3.0?
Re: TTS Portuguese Characters [message #22031 is a reply to message #21987] Fri, 13 March 2009 17:37 Go to previous messageGo to next message
Hi Fernando--
I believe this is an encoding issue in regards to the way the CallDesign.xml
file is being saved. We're currently working on a separate issue which may,
inadvertently, resolve this problem. I'll make an announcement on this list
if it does.
Randy Childers
OpenMethods
On 3/12/09 6:07 PM, in article
55b3ca9b8b40925d3fdf4d435d1f9c6c$1@www.eclipse.org, "Fernando Pesssoa"
Re: TTS Portuguese Characters [message #22453 is a reply to message #22031] Fri, 17 April 2009 16:41 Go to previous messageGo to next message
Hi Fernando--
This issue should be fixed; the application's XML file now handles the full
UTF-8 characterset. Update your source from the VTP repository and
recompile; if you can't do this, let me know and I'll send you a current set
of the plugins directly.
Randy
On 3/13/09 4:37 PM, in article C5E03C44.3FED%randy@openmethods.com, "Randy
Childers" <randy@openmethods.com> wrote:
> Hi Fernando--
> if it does.
> Randy Childers
> OpenMethods
>> Thanks,
Re: TTS Portuguese Characters [message #22497 is a reply to message #22453] Mon, 11 May 2009 19:04 Go to previous message
Hi Randy,
We have same issue with UTF-8 missing xml header file for Spanish TTS
engines. Would you please send me the plugins directory too?
Thanks in advance
Luis Guaman
Interlancompu.com
Quito - Ecuador
Re: TTS Portuguese Characters [message #578253 is a reply to message #21987] Fri, 13 March 2009 17:37 Go to previous message
Hi Fernando--
if it does.
Randy Childers
OpenMethods
Re: TTS Portuguese Characters [message #578431 is a reply to message #22031] Fri, 17 April 2009 16:41 Go to previous message
Hi Fernando--
Randy
> Hi Fernando--
> if it does.
> Randy Childers
> OpenMethods
>> Thanks,
Re: TTS Portuguese Characters [message #578440 is a reply to message #22453] Mon, 11 May 2009 19:04 Go to previous message
Hi Randy,
Thanks in advance
Luis Guaman
Interlancompu.com
Quito - Ecuador
Previous Topic:Custom Modules on VTP 3.0
Next Topic:Error in org.eclipse.vtp.desktop.projects.core
Current Time: Sat Jul 19 10:07:05 EDT 2025
Powered by FUDForum. Page generated in 0.03792 seconds
