Home » Language IDEs » ServerTools (WTP) » XML Validation via local XSD file
XML Validation via local XSD file [message #220173] Thu, 04 September 2008 16:26 Go to next message
I have a problem in my RCP application where we use the webtools xml
editor and validation. We are moving from DTD to XSD for xml validation.
We use XStream to render out our java objects to xml and need a way to
validate them using XSD. So...we now use JAXB to render out the class xsd
files. So now i have the xml and the xsd. Next, I want to be able to
click on an xml file in the rcp project navigator and click validate.
Then I want the xml to be validated with a local xsd file. When i get the
xml file to link to the xsd file, i get "cvc-elt.1: Cannot find the
declaration of element". After doing some research, it looks like i need
to enable namespace-aware(ness) and have no idea how to turn that on.
This is long and confusing..i apologize for that, but if anyone could help
me out, that would be great!
Ideally I would like to use uri for a local namespace maybe using this
extension: org.eclipse.wst.xml.core.catalogContributions but so far I
haven't found much documentation on this. Does this allow my RCP app to
register an XSD file to a local uri and then allow me to put that uri in
my xml file? Clearly i need help.
Thanks!
Re: XML Validation via local XSD file [message #220182 is a reply to message #220173] Thu, 04 September 2008 17:06 Go to previous messageGo to next message
Originally posted by: dcarver.starstandard.org
For JAXB you need to setup a NamespacePrefixMapper, so and set the
appropriate namespaces, otherwise JAXB won't write out and XML with the
appropriate namespaces. Also, be very careful with JAXB or any XML
Databinding (except possibily EMF's XML schema support, it rocks!), as
you can still write invalid XML even though it the classes were
generated from the XSD. Also becareful that xsi:types aren't being
included in your XML as it acts as substitution groups, and overrides
definitions at that level.
http://fisheye5.cenqua.com/browse/~raw,r=1.16/jaxb-architect ure-document/www/doc/com/sun/xml/bind/marshaller/NamespacePr efixMapper.html
As the cataLogContributions does allow you to register the XSD and
include it in a plugin so that it corresponds to a specific namespace.
It's handy if you know the XSD isn't going to change all the time.
A sample definition is:
<extension
point="org.eclipse.wst.xml.core.catalogContributions">
<catalogContribution>
<uri
id="org.w3c.xinclude"
name="http://www.w3.org/2001/XInclude"
uri="xslt-schemas/xinclude.xsd">
</uri>
</catalogContribution>
</extension>
This includes the xinclude.xsd stored in the xslt-schemas directory of
the plugin. and it assigns it the Xinclude namespace.
Dave
JavaJ wrote:
> Hello,
> validation. We use XStream to render out our java objects to xml and
> need a way to validate them using XSD. So...we now use JAXB to render
> out the class xsd files. So now i have the xml and the xsd. Next, I
> want to be able to click on an xml file in the rcp project navigator and
> click validate. Then I want the xml to be validated with a local xsd
> file. When i get the xml file to link to the xsd file, i get
> "cvc-elt.1: Cannot find the declaration of element". After doing some
> research, it looks like i need to enable namespace-aware(ness) and have
> no idea how to turn that on. This is long and confusing..i apologize
> for that, but if anyone could help me out, that would be great!
> Thanks!
Re: XML Validation via local XSD file [message #220191 is a reply to message #220173] Thu, 04 September 2008 17:09 Go to previous messageGo to next message
Here is how i referenced the xsd file both ways:
<Application-array xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
xsi:noNamespaceSchemaLocation="../../../conf/schemas/paf_apps.xsd ">
and
(this was trying to use xml catalog
<Application-array xmlns="http://www.<insert company here>.com/paf_apps"
xsi:schemaLocation="http://www.<insert company here>.com/paf_apps.xsd">
Again, i don't know which was is best but both give me the "cvc-elt.1:
Cannot find the declaration of element 'Application-array'." error.
Re: XML Validation via local XSD file [message #220199 is a reply to message #220182] Thu, 04 September 2008 17:22 Go to previous messageGo to next message
Thanks so much for the quick response...i have a couple more comments and
questions.
As for the JAXB thing, let me be a little more clear and maybe it will
make more sense. In our application, we use XStream to take a jave object
and put it to/from xml for simple serialization. It writes out both the
attributes and the data parts of the data. For example, if i had a Person
class defined as:
public class Person {
int age;
String name;
//etc
It would render:
<Person>
<age>28</age>
<name>Joe Smith</name>
</Person>
We don't use JAXB to create that class, i typically develop it by hand
then XStream will take care of rest to get to/from xml.
The problem I'm trying to solve, i might be way out in left field, is to
create an XSD document off of that Person class and then link the XSD into
the Person XML so we can validate using the RCP. Make sense?
So final XML would be:
<Person xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
xsi:noNamespaceSchemaLocation="../../../conf/schemas/person.xsd ">
<age>28</age>
</Person>
I can get the extra xsd stuff in the xml when XStream is writing out the
XML, but i'm getting that "cvc-elt.1: Cannot find the declaration of
element" error. So are you saying a NamespacePrefixMapper will fix this
problem?
As for the xml catalog, can you give me an example of how to reference
that xsd in a xml file? Using your example, would it be referenced in my
rcp app like this?
<node xmlns="http://http://www.w3.org/2001/XInclude"
xsi:schemaLocation="http://www.w3.org/2001/XInclude/xinclude.xsd">
Thanks so much!
JavaJ
> <extension
> <uri
> </uri>
> </extension>
> Dave
> JavaJ wrote:
>> Hello,
>> Thanks!
Re: XML Validation via local XSD file [message #220205 is a reply to message #220199] Thu, 04 September 2008 17:50 Go to previous messageGo to next message
In order to use the XML Catalog you will need to make your XML and XSD
use namespaces. The XML that you are outputing now doesn't include a
namespace, so the XML Catalog isn't going to help you out.
> It would render:
> <Person>
> <age>28</age>
> </Person>
> into the Person XML so we can validate using the RCP. Make sense?
> <age>28</age>
> </Person>
> problem?
What does your XSD look like. When you click on that XSD, and select
Generate->XML
Does it generate an equivalent example XML as what you are generating.
In your XSD you will need to have a global element, called Person in
order for it to know how to validate it. The XSD is saying that you
don't have a Person element defined.
> my rcp app like this?
In your case, you would need the following:
<Person xmlns="http://www.person.com/person.xsd">
</Person>
And your catalog entry would be setup so that the namespace
http://www.person.com/person.xsd referenced your person.xsd file.
I'd check the generation of the xml from your XSD to make sure that it
is setup the way you think it is.
Dave
Re: XML Validation via local XSD file [message #220213 is a reply to message #220191] Thu, 04 September 2008 17:51 Go to previous messageGo to next message
Make sure your XSD has a global element defined for the root elements.
Dave
> and
Re: XML Validation via local XSD file [message #220220 is a reply to message #220205] Thu, 04 September 2008 18:08 Go to previous messageGo to next message
Thanks for your help...I'll give it a whirl.
Re: XML Validation via local XSD file [message #221117 is a reply to message #220205] Tue, 09 September 2008 12:46 Go to previous messageGo to next message
Dave,
I'm getting closer. I was out for a couple of days so I just started
digging in this again. I can get my rcp app to use the xml catalog to
match my person.xml to my person.xsd as you said. It looks something like
this:
uri for xml catalog: http://www.person.com/person.xsd points to
schemas/person.xsd
<?xml version="1.0" encoding="UTF-8" standalone="yes"?>
<xs:schema version="1.0" xmlns:xs="http://www.w3.org/2001/XMLSchema">
<xs:complexType name="person">
<xs:sequence>
<xs:element name="age" type="xs:int"/>
<xs:element name="name" type="xs:string" minOccurs="0"/>
</xs:sequence>
</xs:complexType>
</xs:schema>
xml is as such:
<person xmlns="http://www.person.com/person.xsd">
<name>jason</name>
<age>28</age>
</person>
but I'm still getting validation errors:
1. Referenced file contains errors (talking about my person.xsd file)
2. cvc-elt.1: Cannot find the declarion of element 'person'
Any ideas?
J
>> It would render:
>> <Person>
>> <age>28</age>
>> </Person>
>> <age>28</age>
>> </Person>
>> problem?
> Generate->XML
> </Person>
> Dave
Re: XML Validation via local XSD file [message #221145 is a reply to message #221117] Tue, 09 September 2008 16:01 Go to previous messageGo to next message
Anyone?
JavaJ wrote:
> Dave,
> this:
> schemas/person.xsd
> <xs:sequence>
> </xs:sequence>
> </xs:complexType>
> </xs:schema>
> xml is as such:
> <name>jason</name>
> <age>28</age>
> </person>
> Any ideas?
> J
>>> It would render:
>>> <Person>
>>> <age>28</age>
>>> </Person>
>>> <age>28</age>
>>> </Person>
>>> problem?
>> Generate->XML
>> </Person>
>> Dave
Re: XML Validation via local XSD file [message #221169 is a reply to message #221117] Tue, 09 September 2008 20:25 Go to previous messageGo to next message
JavaJ wrote:
> Dave,
> like this:
> schemas/person.xsd
> <xs:sequence>
> </xs:sequence>
> </xs:complexType>
> </xs:schema>
You need to specify a targetNamespace like
<xs:schema version="1.0: targetNamespace="http://www.person.com/person"
elementFormDefault="qualified">
That will set the schema up for the namespace, and make the elements
have to be in that namespace if they are defined int he schema.
Dave
Re: XML Validation via local XSD file [message #221198 is a reply to message #221169] Wed, 10 September 2008 10:12 Go to previous messageGo to next message
Dave,
I really appreciate you helping me out. Well..I'm one step closer now.
With this xsd...
<xs:schema version="1.0" targetNamespace="http://www.person.com/person"
<xs:sequence>
</xs:sequence>
</xs:complexType>
</xs:schema>
...my person xml won't validate with the "Referenced file contains errors"
referring to my xsd file.
With this xsd (kept the xmlns + target namespace)...
<xs:sequence>
</xs:sequence>
</xs:complexType>
</xs:schema>
...i get the "cvc-elt.1: Cannot find the declaration of element 'person'".
Any idea why? When i try to generate the xml from the xsd as you
suggested before I get error "No root elements exists since the schema
provider has no global elements."
Here is xml again:
<person xmlns="http://www.person.com/person" >
<name>jason</name>
<age>28</age>
</person>
Jason
David Carver wrote:
> JavaJ wrote:
>> Dave,
>> like this:
>> schemas/person.xsd
>> <xs:sequence>
>> </xs:sequence>
>> </xs:complexType>
>> </xs:schema>
> Dave
Re: XML Validation via local XSD file [message #221206 is a reply to message #221198] Wed, 10 September 2008 10:36 Go to previous messageGo to next message
I got it working. Thanks Dave for all your help!!! Here's what my final
xsd looked like:
xmlns="http://www.person.com/person" elementFormDefault="qualified">
<xs:element name="person">
<xs:complexType>
<xs:sequence>
</xs:sequence>
</xs:complexType>
</xs:element>
</xs:schema>
Re: XML Validation via local XSD file [message #221224 is a reply to message #221198] Wed, 10 September 2008 20:19 Go to previous message
Add the following to your schema:
<xs:element name="person" type="person"/>
That should get you going.
> <xs:sequence>
> </xs:sequence>
> </xs:complexType>
> </xs:schema>
> Here is xml again:
> <person xmlns="http://www.person.com/person" > <name>jason</name>
> <age>28</age>
> </person>
> Jason
> David Carver wrote:
>> JavaJ wrote:
>>> Dave,
>>> started digging in this again. I can get my rcp app to use the xml
>>> catalog to match my person.xml to my person.xsd as you said. It
>>> looks something like this:
>>> schemas/person.xsd
>>> <xs:sequence>
>>> </xs:sequence>
>>> </xs:complexType>
>>> </xs:schema>
>> Dave
Previous Topic:Problem running application under Tomcat in Eclipse
Next Topic:JSDT element v node?
Current Time: Sat Jul 19 20:24:13 EDT 2025
Powered by FUDForum. Page generated in 0.04754 seconds
