Home » Language IDEs » ServerTools (WTP) » Tomcat 6 web app is not started because of "java.io.IOException: invalid header"
Tomcat 6 web app is not started because of "java.io.IOException: invalid header" [message #219962] Tue, 02 September 2008 19:24 Go to next message
I have an Eclipse project which is running OK on JDK 1.5, Tomcat 6 from
Eclipse 3.4 on a Linux box. The whole project is checked in to a source
code repository. Then I checked this project out from a Windows box,
Eclipse Europa, also using JDK 1.5, Tomcat 6. When I deployed the project
and started the Tomcat server. I got the error:
SEVERE: Error in dependencyCheck
java.io.IOException: invalid header field
at java.util.jar.Attributes.read(Unknown Source)
at java.util.jar.Manifest.read(Unknown Source)
at java.util.jar.Manifest.<init>(Unknown Source)
at
org.apache.catalina.util.ExtensionValidator.validateApplicat ion(ExtensionValidator.java:149)
at
org.apache.catalina.core.StandardContext.start(StandardConte xt.java:4167)
at org.apache.catalina.core.ContainerBase.start(ContainerBase.j ava:1045)
at org.apache.catalina.core.StandardHost.start(StandardHost.jav a:719)
at org.apache.catalina.core.StandardEngine.start(StandardEngine .java:443)
at
org.apache.catalina.core.StandardService.start(StandardServi ce.java:516)
at org.apache.catalina.core.StandardServer.start(StandardServer .java:710)
at org.apache.catalina.startup.Catalina.start(Catalina.java:578 )
at org.apache.catalina.startup.Bootstrap.start(Bootstrap.java:2 88)
at org.apache.catalina.startup.Bootstrap.main(Bootstrap.java:41 3)
Sep 2, 2008 3:50:14 PM org.apache.catalina.core.StandardContext start
SEVERE: Error getConfigured
SEVERE: Context [/XXXXPOC] startup failed due to previous errors
According to the post:
http://dev.eclipse.org/newslists/news.eclipse.webtools/msg11 055.html, I
created a new project at this Windows box, then copied all the source
codes and web folder to the new project. The new project is at the same
workspace as the previous error project and has the identical content. And
it is running just FINE! The question is why the project I checked out
directly from the repository didn't work? Also I copied the new project's
settings folder to the error project. But the previous error project
still didn't work. So what else is different between the error project and
new project?
Please help! I would like to know whether it relates to Windows vs. Linux.
Is there way to fix it so that it works at all the environments.
Thank you very much.
Re: Tomcat 6 web app is not started because of "java.io.IOException: invalid header" [message #219994 is a reply to message #219962] Wed, 03 September 2008 10:52 Go to previous messageGo to next message
Inspecting source code, the "ExtensionValidator.java:149" suggests that
Tomcat is attempting to read the MANIFEST.MF file in the META-INF folder
of the webapp. The "invalid header field" comes from
java.util.jar.Attributes when a line, continuations included, doesn't
contain a colon, or the colon isn't followed by the required space.
Check the "WebContent\META-INF\MANIFEST.MF" file in your checked out
project and see what it contains. Creating a new project would have
created a new one. I assume when you copied the source, this new
MANIFEST.MF wasn't overwritten.
Larry
Jan Yan wrote:
> Hello,
> project and started the Tomcat server. I got the error:
> at
> at
> at
> at
> at
> at
> at
> And it is running just FINE! The question is why the project I checked
> out directly from the repository didn't work? Also I copied the new
> project's settings folder to the error project. But the previous error
> project still didn't work. So what else is different between the error
> project and new project?
> Linux. Is there way to fix it so that it works at all the environments.
Re: Tomcat 6 web app is not started because of "java.io.IOException: invalid header" [message #220099 is a reply to message #219994] Wed, 03 September 2008 12:59 Go to previous messageGo to next message
Yes, this is exactly the problem. I replaced the MANIFEST.MF with the new
project's. And it works at Windows. Then I checked in the new MANIFEST.MF
file and tried it at Linux box. It gave me the same error
"java.io.IOException: invalid header field". Do we have to have two
different MANIFEST.MF files, one for Windows and one for Linux?
Also I diff these two MANIFEST.MF files.
The one has problem at Windows, but works at Linux is:
Manifest-Version: 1.0^M
Class-Path: ^M
^M
The one works at Windows, but doesn't work at Linux is:
Manifest-Version: 1.0^M^M
Class-Path: ^M^M
^M^M
I created the project as Dynamic Web Project and didn't change the default
MANIFEST.MF at all. Does it suggest that a bug in Eclipse side that a web
project created at Linux is not compatible at Windows?
Anyway, thank you so much for the help.
> Check the "WebContentMETA-INFMANIFEST.MF" file in your checked out
> Cheers,
> Larry
> Jan Yan wrote:
>> Hello,
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
Re: Tomcat 6 web app is not started because of "java.io.IOException: invalid header" [message #220115 is a reply to message #220099] Wed, 03 September 2008 14:30 Go to previous messageGo to next message
Again by inspection, Attributes appears to handle line endings of LF and
CRLF, either of which should work on both Linux and Windows.
If I can assume '^M' is a CR, then your problem is likely that the
MANIFEST.MF committed to CVS from Linux contained CRLFs instead of LFs.
When checked out of CVS to Windows using OS dependent line endings, an
extra CR is being inserted prior to the LFs, resulting in CRCRLF at the
end of each line. After ignoring the trailing CRLF, the last line is
failing the colon test since it contains just CR. If this is the
problem, just ensure that what is in CVS contains just LFs, then any
file checked out to Linux or Windows should work regardless of the use
of OS dependent line endings.
Larry
> new project's. And it works at Windows. Then I checked in the new
> MANIFEST.MF file and tried it at Linux box. It gave me the same error
> Class-Path: ^M
> ^M
> Class-Path: ^M^M
> ^M^M
> default MANIFEST.MF at all. Does it suggest that a bug in Eclipse side
> that a web project created at Linux is not compatible at Windows?
>> that Tomcat is attempting to read the MANIFEST.MF file in the META-INF
>> folder of the webapp. The "invalid header field" comes from
>> Cheers,
>> Larry
>> Jan Yan wrote:
>>> Hello,
>>> from Eclipse 3.4 on a Linux box. The whole project is checked in to a
>>> source code repository. Then I checked this project out from a
>>> Windows box, Eclipse Europa, also using JDK 1.5, Tomcat 6. When I
>>> deployed the project and started the Tomcat server. I got the error:
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> I created a new project at this Windows box, then copied all the
>>> source codes and web folder to the new project. The new project is at
>>> the same workspace as the previous error project and has the
>>> identical content. And it is running just FINE! The question is why
>>> the project I checked out directly from the repository didn't work?
>>> Also I copied the new project's settings folder to the error project.
>>> But the previous error project still didn't work. So what else is
>>> different between the error project and new project?
Re: Tomcat 6 web app is not started because of "java.io.IOException: invalid header" [message #220133 is a reply to message #220115] Wed, 03 September 2008 18:47 Go to previous message
Yes, it fixed the problem. Thank you very much.
Best,
Jan
> Cheers,
> Larry
>> Class-Path: ^M
>> ^M
>> Class-Path: ^M^M
>> ^M^M
>>> Cheers,
>>> Larry
>>> Jan Yan wrote:
>>>> Hello,
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
Previous Topic:Hot Code Replace
Next Topic:How do I change "WebContent" folder in web project?
Current Time: Sat Jul 19 14:15:22 EDT 2025
Powered by FUDForum. Page generated in 0.04541 seconds
