Home » Modeling » GMF (Graphical Modeling Framework) » Disable "Delete From Diagram"
Disable "Delete From Diagram" [message #219787] Tue, 24 February 2009 02:08 Go to next message
Originally posted by: Erazerx.gmx.de
Hello all,
my Diagram Editor is synchronised to a model. The "Delete From Diagram"
Action is disabled for all elements... except for one.
I don't think i made something different on creating that element.
The only difference i see, is that the element, where the "Delete From
Diagram" Action is available, is a Association that can have an other
association as source or target.
However, is there a way to manually disable the "Delete From Diagram"
Action?
I was looking around in the corresponding Edit-Policy class, but
couldn't find a command that gets created from that class, that is
responsible for the action.
Thx in advance, Arne
Re: Disable "Delete From Diagram" [message #219905 is a reply to message #219787] Tue, 24 February 2009 11:39 Go to previous messageGo to next message
Originally posted by: jxtamarc.gmail.com
El dia Tue, 24 Feb 2009 08:08:01 +0100, en/na Arne va escriure:
Hi Arne,
go to the plugin.xml file, and then all you have to do is :
<popupPredefinedItem id="deleteFromDiagramAction" remove="true"/>
under the extension point :
<extension
point=" org.eclipse.gmf.runtime.common.ui.services.action.contributi onItemProviders ">
This is what i have for an element of my model : ActivyEditPart.
<extension
<?gmfgen generated="false"?>
<contributionItemProvider
class=" org.eclipse.gmf.runtime.diagram.ui.providers.DiagramContribu tionItemProvider "
checkPluginLoaded="false">
<Priority name="Low"/>
<popupContribution
class=" org.eclipse.gmf.runtime.diagram.ui.providers.DiagramContextM enuProvider ">
<popupStructuredContributionCriteria
objectClass=" com.isoco.iwf.designer.bpmn.diagram.edit.parts.ActivityEditP art "/
<popupPredefinedItem id="addNoteLinkAction" remove="true"/>
<popupPredefinedItem id="fileMenu" remove="true"/>
<popupPredefinedItem id="cut" path="/editMenu/copyGroup"
remove="true"/>
<popupPredefinedItem id="copy" path="/editMenu/
copyGroup" remove="true"/>
<popupPredefinedItem id="paste" path="/editMenu/
remove="true"/>
<popupPredefinedItem id="deleteFromModelAction"
remove="false"/>
<popupPredefinedItem id="formatMenu" remove="true"/>
<popupPredefinedItem id="filtersMenu" remove="true"/>
<popupPredefinedItem id="showPropertiesViewAction"
remove="true"/>
<popupPredefinedItem id="properties" remove="true"/>
</popupContribution>
hope it helps.
> Hello all,
> Action is disabled for all elements... except for one. I don't think i
> Action?
Re: Disable "Delete From Diagram" [message #220308 is a reply to message #219905] Sun, 01 March 2009 08:09 Go to previous messageGo to next message
Hi!
Yes it really helped a lot, thank you!
It is a little emberrassing, since I already worked with that extension
point and still was trying to "grey the actions out" instead of using
the extension point to remove the action completely. I was really blind
there.
Anyway, you really helped me there :)
Arne
> Hi Arne,
> <extension
> <extension
> <popupContribution
> remove="true"/>
> remove="true"/>
> remove="false"/>
> remove="true"/>
> hope it helps.
>> Hello all,
>> Action?
Re: Disable "Delete From Diagram" [message #514458 is a reply to message #219905] Mon, 15 February 2010 07:50 Go to previous message
Hey Markitus!
Does this only remove the context menu entry or really disable deleting
at all? I have the problem that the "Backspace" key is also mapped to
"delete from diagram" for single EditParts. Will this binding be removed
then, too?
BTW: Did not really get this to work. Using this extension point only
did *enable* the "delete from model" but not yet disable the "delete
from diagram". In my case I have a feature label attached to a
connection edit part that can be removed from the diagram.
Hauke
> Hi Arne,
> <extension
> <extension
> <popupContribution
> remove="true"/>
> remove="true"/>
> remove="false"/>
> remove="true"/>
> hope it helps.
>> Hello all,
>> Action?
Previous Topic:Delete From Diagram action
Next Topic:attaching and synchronizing gmf generated diagram with editor
Current Time: Sun Jul 20 18:43:28 EDT 2025
Powered by FUDForum. Page generated in 0.24081 seconds
