Home » Archived » BIRT » Using the graphing engine "off-line"
Using the graphing engine "off-line" [message #218548] Mon, 12 February 2007 13:10 Go to next message
Originally posted by: Elliot.Katz.moodys.com
Is there any way to use the BIRT graphing library to create a chart
"off-line" - i.e. not in the context of a report, and save it as an svg
file?
Something like:
class chartGenerator
public static void createGraphFile(String fileName, ...)
Graph graph = createNewGraph();
this.addDataSeriesToMyGraph(graph);
this.setOptionsForMyGraph(graph);
this.serializeGraphToSVGFile(graph, fileName);
Re: Using the graphing engine "off-line" [message #218648 is a reply to message #218548] Tue, 13 February 2007 05:24 Go to previous messageGo to next message
Yes. you can look at the examples, there is a chart.examples plugin.
David
> svg
> file?
> Something like:
Re: Using the graphing engine "off-line" [message #218697 is a reply to message #218648] Tue, 13 February 2007 11:29 Go to previous message
Works like a charm!
Thanks a bunch.
Previous Topic:Problem with MSSQL Server - No Tables viewed!
Next Topic:Total.sum, or using JS Global funcitons - WRONG TOTAL AMOUNT
Current Time: Sun Jul 20 09:10:49 EDT 2025
Powered by FUDForum. Page generated in 0.04129 seconds
