Group Row Number [message #217571] |
Wed, 07 February 2007 14:15  |
Originally posted by: niraj.patel.spectrum-sg.com
I am trying to get the group row number so that I can alternate the colors
at the group level. here is my heirarchy
Department - Group1
Account - Group2
Service Code - Group3
At each level there is a layout that I have created that has mulitple rows
that need alternate colors for readablitlity. I am trying to use
Total.runningSum(1,null,1)%2 = 1 to get the highlighting working. It
appears to be working for the first group but group 2 it doesn't work. I
put a field in that group row and output the value and I get the following
numbers 1,3,6,8,11,13,15,18,21....According to the postings I found
Total.runningSum(1,null,1) should work. Can someone give me the right
syntax to get the relative group number for a group? For each record set
in the group i want it to start renumbering.
Re: Group Row Number [message #217956 is a reply to message #217571] |
Thu, 08 February 2007 12:45   |
The third parameter in the Total.runningSum is the group level. You have it
set to one. Can you try removing it and set the aggregate on to the
specific group (ie Group 1, Group 2 etc)
Jason
"Niraj Patel" <niraj.patel@spectrum-sg.com> wrote in message
news:61cfaaf636d863fca0ce13c3b69b07dc$1@www.eclipse.org...
> Department - Group1
> Account - Group2
Re: Group Row Number [message #218235 is a reply to message #218063] |
Fri, 09 February 2007 14:39   |
Jason,
I got the version you sent me to work. I altered the layout a bit but
when I match the layout on the other report it doesnt work. I still get
numbering that is 1,3,6,8,11, etc...Here is the code to my current layout
report.
<!-- Written by Eclipse BIRT 2.0 -->
<report xmlns="http://www.eclipse.org/birt/2005/design" version="3.2.6"
id="1">
<property name="createdBy">Eclipse BIRT Designer Version
2.1.1.v20060922-1058 Build <20060926-0959></property>
<property name="units">in</property>
<property name="comments">Copyright (c) 2006 <<Your Company Name
here>></property>
<page-setup>
<simple-master-page name="Simple MasterPage" id="2">
<page-footer>
<text id="3">
<property name="contentType">html</property>
<text-property name="content"><![CDATA[<value-of>new
Date()</value-of>]]></text-property>
</text>
</page-footer>
</simple-master-page>
</page-setup>
<body>
<table id="104">
<property name="borderBottomColor">#E0F2FE</property>
<property name="borderBottomStyle">solid</property>
<property name="borderBottomWidth">thin</property>
<property name="borderLeftColor">#E0F2FE</property>
<property name="borderLeftStyle">solid</property>
<property name="borderLeftWidth">thin</property>
<property name="borderRightColor">#E0F2FE</property>
<property name="borderRightStyle">solid</property>
<property name="borderRightWidth">thin</property>
<property name="borderTopColor">#E0F2FE</property>
<property name="borderTopStyle">solid</property>
<property name="borderTopWidth">thin</property>
<property name="width">100%</property>
<property name="dataSet">Data Set</property>
<list-property name="visibility">
<structure>
<property name="format">all</property>
<expression name="valueExpr">params["Department"] ==
false || params["Account_No"] == false
|| params["Service_Code"] == true</expression>
</structure>
</list-property>
<list-property name="boundDataColumns">
<structure>
<property name="name">DEPARTMENT</property>
<expression
name="expression">dataSetRow["DEPARTMENT"]</expression>
<property name="dataType">decimal</property>
</structure>
<structure>
<property name="name">SERVICECODE</property>
<expression
name="expression">dataSetRow["SERVICECODE"]</expression >
</structure>
<structure>
<property name="name">Account_AMOUNT</property>
<expression
name="expression">Total.sum(dataSetRow["AMOUNT"])</expression >
<property name="aggregateOn">Account</property>
</structure>
<structure>
<property name="name">ACCTNO</property>
<expression
name="expression">dataSetRow["ACCTNO"]</expression>
</structure>
<structure>
<property name="name">AMOUNT</property>
<expression
</structure>
<structure>
<property name="name">DEPTNAME</property>
<expression
name="expression">dataSetRow["DEPTNAME"]</expression>
<property name="dataType">string</property>
</structure>
<structure>
<property name="name">group1</property>
<expression
name="expression">Total.runningCount()</expression>
<property name="dataType">integer</property>
<property name="aggregateOn">Department</property>
</structure>
<structure>
<property name="name">group2</property>
<expression
</structure>
<structure>
<property name="name">data item</property>
<expression
name="expression">row["group1"]</expression>
</structure>
</list-property>
<column id="117">
<property name="width">1.1354166667in</property>
</column>
<column id="118">
<property name="width">0.96875in</property>
</column>
<column id="119"/>
<header>
<row id="1867">
<property name="style">border</property>
<property name="fontFamily">"Verdana"</property>
<property name="fontWeight">bold</property>
<cell id="1868">
<property name="colSpan">3</property>
<property name="rowSpan">1</property>
<property
name="borderBottomColor">#000000</property>
<property
name="borderBottomWidth">medium</property>
<label id="1871">
<property name="textAlign">center</property>
<text-property name="text">Financial Impact of
Errors</text-property>
</label>
</cell>
</row>
<row id="105">
<property name="style">columntitles</property>
<property name="fontSize">10px</property>
<property name="textUnderline">underline</property>
<cell id="106">
<label id="1762">
<property
<text-property name="text">DEPT</text-property>
</label>
</cell>
<cell id="107">
<label id="127">
<text-property
name="text">ACCTNO</text-property>
</label>
</cell>
<cell id="108">
<label id="125">
<text-property
name="text">AMOUNT</text-property>
</label>
</cell>
</row>
</header>
<group id="129">
<property name="groupName">Department</property>
<property name="interval">none</property>
<property name="sortDirection">asc</property>
<expression name="keyExpr">row["DEPARTMENT"]</expression>
<property name="repeatHeader">true</property>
<property name="hideDetail">false</property>
<property name="pageBreakAfter">auto</property>
<property name="pageBreakBefore">auto</property>
<header>
<row id="130">
<property name="backgroundColor">#0080C0</property>
<property name="fontSize">12px</property>
<property name="color">#FFFFFF</property>
<cell id="131">
<data id="2062">
<property
name="resultSetColumn">DEPTNAME</property>
</data>
</cell>
<cell id="132"/>
<cell id="133"/>
</row>
</header>
<footer>
<row id="134">
<cell id="135"/>
<cell id="136"/>
<cell id="137"/>
</row>
</footer>
</group>
<group id="139">
<property name="groupName">Account</property>
<expression name="keyExpr">row["ACCTNO"]</expression>
<header>
<row id="140">
<property name="style">fielddata</property>
<list-property name="highlightRules">
<structure>
<property name="operator">eq</property>
<property
name="backgroundColor">#E0F2FE</property>
<expression
name="testExpr">Total.runningSum(1,null, "AMOUNT") %2</expression>
<expression name="value1">1</expression>
</structure>
</list-property>
<cell id="141">
<data id="2083">
<property name="resultSetColumn">data
item</property>
</data>
</cell>
<cell id="142">
<data id="148">
<property
name="resultSetColumn">ACCTNO</property>
</data>
</cell>
<cell id="143">
<data id="126">
<structure name="numberFormat">
<property
name="category">Currency</property>
<property
name="pattern">$#,##0</property>
</structure>
<property
<property
name="resultSetColumn">Account_AMOUNT</property>
</data>
</cell>
</row>
</header>
<footer>
<row id="144">
<cell id="145"/>
<cell id="146"/>
<cell id="147"/>
</row>
</footer>
</group>
<detail>
<row id="109">
<cell id="110"/>
<cell id="111"/>
<cell id="112"/>
</row>
</detail>
<footer>
<row id="113">
<cell id="114">
<label id="1797">
<property
name="borderTopColor">#000000</property>
<property
<property
name="borderTopWidth">medium</property>
<text-property
name="text">Total</text-property>
</label>
</cell>
<cell id="115"/>
<cell id="116">
<data id="150">
<property
<property
<property
<property
<property
<property name="pattern">$#,##0</property>
</structure>
<property
name="resultSetColumn">AMOUNT</property>
</data>
</cell>
</row>
</footer>
</table>
</body>
</report>
And here is the code to yours that I altered.
id="1">
here>></property>
<data-sources>
<oda-data-source
extensionID="org.eclipse.birt.report.data.oda.jdbc" name="Data Source"
id="4">
<property
name="odaDriverClass">org.eclipse.birt.report.data.oda.sampledb.Driver </property>
<property name="odaURL">jdbc:classicmodels:sampledb</property>
<property name="odaUser">ClassicModels</property>
</oda-data-source>
</data-sources>
<data-sets>
<oda-data-set
extensionID="org.eclipse.birt.report.data.oda.jdbc.JdbcSelectDataSet "
name="Data Set" id="5">
<structure name="cachedMetaData">
<list-property name="resultSet">
<structure>
<property name="position">1</property>
<property name="name">CUSTOMERNUMBER</property>
</structure>
<structure>
<property name="position">2</property>
<property name="name">CUSTOMERNAME</property>
</structure>
<structure>
<property name="position">3</property>
<property name="name">CONTACTLASTNAME</property>
</structure>
<structure>
<property name="position">4</property>
<property name="name">CONTACTFIRSTNAME</property>
</structure>
<structure>
<property name="position">5</property>
<property name="name">PHONE</property>
</structure>
<structure>
<property name="position">6</property>
<property name="name">ADDRESSLINE1</property>
</structure>
<structure>
<property name="position">7</property>
<property name="name">ADDRESSLINE2</property>
</structure>
<structure>
<property name="position">8</property>
<property name="name">CITY</property>
</structure>
<structure>
<property name="position">9</property>
<property name="name">STATE</property>
</structure>
<structure>
<property name="position">10</property>
<property name="name">POSTALCODE</property>
</structure>
<structure>
<property name="position">11</property>
<property name="name">COUNTRY</property>
</structure>
<structure>
<property name="position">12</property>
<property
name="name">SALESREPEMPLOYEENUMBER</property>
</structure>
<structure>
<property name="position">13</property>
<property name="name">CREDITLIMIT</property>
<property name="dataType">float</property>
</structure>
</list-property>
</structure>
<property name="dataSource">Data Source</property>
<structure>
<property name="nativeName">CUSTOMERNUMBER</property>
<property name="nativeDataType">4</property>
</structure>
<structure>
<property name="nativeName">CUSTOMERNAME</property>
<property name="nativeDataType">12</property>
</structure>
<structure>
<property name="nativeName">CONTACTLASTNAME</property>
</structure>
<structure>
<property name="nativeName">CONTACTFIRSTNAME</property>
</structure>
<structure>
<property name="nativeName">PHONE</property>
</structure>
<structure>
<property name="nativeName">ADDRESSLINE1</property>
</structure>
<structure>
<property name="nativeName">ADDRESSLINE2</property>
</structure>
<structure>
<property name="nativeName">CITY</property>
</structure>
<structure>
<property name="nativeName">STATE</property>
</structure>
<structure>
<property name="nativeName">POSTALCODE</property>
</structure>
<structure>
<property name="nativeName">COUNTRY</property>
</structure>
<structure>
<property name="name">SALESREPEMPLOYEENUMBER</property>
<property
name="nativeName">SALESREPEMPLOYEENUMBER</property>
</structure>
<structure>
<property name="nativeName">CREDITLIMIT</property>
<property name="nativeDataType">8</property>
</structure>
</list-property>
<property name="queryText">select *
from Customers</property>
<xml-property name="designerValues"><![CDATA[<?xml
version="1.0"
encoding="UTF-8"?>
<model:DesignValues
xmlns:design="http://www.eclipse.org/datatools/connectivity/oda/design"
xmlns:model="http://www.eclipse.org/birt/report/model/adapter/odaModel">
<Version>1.0</Version>
<design:ResultSets derivedMetaData="true">
<design:resultSetDefinitions>
<design:resultSetColumns>
<design:resultColumnDefinitions>
<design:attributes>
<design:name>CUSTOMERNUMBER</design:name>
<design:position>1</design:position>
<design:nativeDataTypeCode>4</design:nativeDataTypeCode>
<design:precision>10</design:precision>
<design:scale>0</design:scale>
<design:nullability>Nullable</design:nullability>
</design:attributes>
<design:usageHints>
<design:label>CUSTOMERNUMBER</design:label>
<design:formattingHints>
<design:displaySize>11</design:displaySize>
</design:formattingHints>
</design:usageHints>
</design:resultColumnDefinitions>
<design:attributes>
<design:name>CUSTOMERNAME</design:name>
<design:position>2</design:position>
<design:nativeDataTypeCode>12</design:nativeDataTypeCode>
<design:precision>50</design:precision>
<design:usageHints>
<design:label>CUSTOMERNAME</design:label>
<design:displaySize>50</design:displaySize>
<design:attributes>
<design:name>CONTACTLASTNAME</design:name>
<design:position>3</design:position>
<design:usageHints>
<design:label>CONTACTLASTNAME</design:label>
<design:attributes>
<design:name>CONTACTFIRSTNAME</design:name>
<design:position>4</design:position>
<design:usageHints>
<design:label>CONTACTFIRSTNAME</design:label>
<design:attributes>
<design:name>PHONE</design:name>
<design:position>5</design:position>
<design:usageHints>
<design:label>PHONE</design:label>
<design:attributes>
<design:name>ADDRESSLINE1</design:name>
<design:position>6</design:position>
<design:usageHints>
<design:label>ADDRESSLINE1</design:label>
<design:attributes>
<design:name>ADDRESSLINE2</design:name>
<design:position>7</design:position>
<design:usageHints>
<design:label>ADDRESSLINE2</design:label>
<design:attributes>
<design:name>CITY</design:name>
<design:position>8</design:position>
<design:usageHints>
<design:label>CITY</design:label>
<design:attributes>
<design:name>STATE</design:name>
<design:position>9</design:position>
<design:usageHints>
<design:label>STATE</design:label>
<design:attributes>
<design:name>POSTALCODE</design:name>
<design:position>10</design:position>
<design:precision>15</design:precision>
<design:usageHints>
<design:label>POSTALCODE</design:label>
<design:displaySize>15</design:displaySize>
<design:attributes>
<design:name>COUNTRY</design:name>
<design:position>11</design:position>
<design:usageHints>
<design:label>COUNTRY</design:label>
<design:attributes>
<design:name>SALESREPEMPLOYEENUMBER</design:name>
<design:position>12</design:position>
<design:usageHints>
<design:label>SALESREPEMPLOYEENUMBER</design:label>
<design:attributes>
<design:name>CREDITLIMIT</design:name>
<design:position>13</design:position>
<design:nativeDataTypeCode>8</design:nativeDataTypeCode>
<design:usageHints>
<design:label>CREDITLIMIT</design:label>
<design:displaySize>22</design:displaySize>
</design:resultSetColumns>
</design:resultSetDefinitions>
<design:attributes>
<design:attributes>
<design:attributes>
<design:attributes>
<design:attributes>
<design:attributes>
<design:attributes>
<design:attributes>
<design:attributes>
<design:attributes>
<design:attributes>
<design:attributes>
<design:attributes>
</design:ResultSets>
</model:DesignValues>]]></xml-property>
</oda-data-set>
</data-sets>
<page-setup>
<page-footer>
<text id="3">
</text>
</page-footer>
</page-setup>
<body>
<table id="37">
<structure>
<expression
name="expression">dataSetRow["CUSTOMERNUMBER"]</expression >
</structure>
<structure>
<expression
name="expression">dataSetRow["CUSTOMERNAME"]</expression >
</structure>
<structure>
<expression
name="expression">dataSetRow["CONTACTLASTNAME"]</expression >
</structure>
<structure>
<expression
name="expression">dataSetRow["CONTACTFIRSTNAME"]</expression >
</structure>
<structure>
<expression
name="expression">dataSetRow["PHONE"]</expression>
</structure>
<structure>
<expression
name="expression">dataSetRow["ADDRESSLINE1"]</expression >
</structure>
<structure>
<expression
name="expression">dataSetRow["ADDRESSLINE2"]</expression >
</structure>
<structure>
<expression
name="expression">dataSetRow["CITY"]</expression>
</structure>
<structure>
<expression
name="expression">dataSetRow["STATE"]</expression>
</structure>
<structure>
<expression
name="expression">dataSetRow["POSTALCODE"]</expression>
</structure>
<structure>
<expression
name="expression">dataSetRow["COUNTRY"]</expression>
</structure>
<structure>
<expression
name="expression">dataSetRow["SALESREPEMPLOYEENUMBER"]</expression >
</structure>
<structure>
<expression
name="expression">dataSetRow["CREDITLIMIT"]</expression >
</structure>
<structure>
<expression
<property name="dataType">any</property>
<property name="aggregateOn">NewTableGroup2</property>
</structure>
<structure>
<expression
name="expression">row["group2"]</expression>
</structure>
<structure>
<expression
<property name="aggregateOn">NewTableGroup1</property>
</structure>
<structure>
<property name="name">data item_1</property>
<expression
</structure>
</list-property>
<column id="154"/>
<column id="146"/>
<column id="106"/>
<column id="107"/>
<column id="118"/>
<header>
<row id="38">
<cell id="147"/>
<cell id="139"/>
<cell id="39">
<label id="40">
<text-property
name="text">CUSTOMERNUMBER</text-property>
</label>
</cell>
<cell id="41">
<label id="42">
<text-property
name="text">CUSTOMERNAME</text-property>
</label>
</cell>
<cell id="63">
<label id="64">
<text-property
name="text">CREDITLIMIT</text-property>
</label>
</cell>
</row>
</header>
<group id="119">
<property name="groupName">NewTableGroup1</property>
<expression name="keyExpr">row["COUNTRY"]</expression>
<header>
<row id="120">
<cell id="148">
<data id="128">
<property
name="resultSetColumn">COUNTRY</property>
</data>
</cell>
<cell id="140"/>
<cell id="121"/>
<cell id="122"/>
<cell id="123"/>
</row>
</header>
<footer>
<row id="124">
<cell id="152"/>
<cell id="144"/>
<cell id="125"/>
<cell id="126"/>
<cell id="127"/>
</row>
</footer>
</group>
<group id="129">
<property name="groupName">NewTableGroup2</property>
<expression name="keyExpr">row["CITY"]</expression>
<header>
<row id="130">
<structure>
FUDForum. Page generated in 0.06885 seconds
