Eclipse running problem [message #217565] |
Sat, 23 June 2007 18:21  |
Originally posted by: jack.w.rae.googlemail.com
At first I was having problems with java heap memory when loading eclipse
- however now I load it with the command: ./eclipse -clean -vmargs
-XX:MaxPermSize=128M in the eclipse directory.
Now it starts to run, but then I get an error message, I am running Suse
10.2 and Konsole displays this:
Quote: | An unexpected error has been detected by HotSpot Virtual Machine:
# SIGSEGV (0xb) at pc=0xb7de96fb, pid=10175, tid=3084684160
# Java VM: Java HotSpot(TM) Client VM (1.5.0_08-b03 mixed mode)
# Problematic frame:
# C [libc.so.6+0x206fb]
and in the error report file it says this:
Quote: | !SESSION 2007-06-23 23:15:38.166
eclipse.buildId=M20060921-0945
java.version=1.5.0_08
BootLoader constants: OS=linux, ARCH=x86, WS=gtk, NL=en_GB
Command-line arguments: -os linux -ws gtk -arch x86 -clean
!ENTRY org.eclipse.update.configurator 2007-06-23 23:15:43.546
!MESSAGE Could not install bundle
plugins/org.eclipse.platform.doc.isv_3.2.1.r321_v2006030.jar null
What do I need to do to finally get eclipse on it's feet?
Re: Eclipse running problem [message #217882 is a reply to message #217865] |
Mon, 25 June 2007 11:51  |
Thank you for your advice. With the argument (in super-user mode)
/eclipse -clean -Xms[whatever] -Xmx[whatever] I always get an error
message:
Could not reserve enough space for object heap
Could not create the Java virtual machine.
if I use the opening command: ./eclipse -clean -vmargs -Xms[whatever]
-Xmx[whatever] then I get the same error as before (eclipse begins to run
first)
I have 512mb of ram (which, yes, does need to be upgraded) and I am
normally setting minimum values of 64M or 128M and maximum values of all
sorts from 512M to 128M. I always seem to get the complaint of not having
enough space for object heap however.
FUDForum. Page generated in 0.29034 seconds
