Basic tutorial - source file not read [message #216810] |
Tue, 19 June 2007 16:34  |
Originally posted by: dxturner.yahoo.com
I'm getting an error message on the JUnit project from the 'Basic
Tutorial' which says:
The project was not built since the source file
/JUnit/junit/framework/TestSuite.java could not be read
however, the file is there with rw-r--r-- permissions:
<username>@<host>:~/workspace/JUnit/junit/framework$ ls -go
total 60
-rw-r--r-- 1 241 2007-06-19 15:19 AssertionFailedError.java
-rw-r--r-- 1 9794 2007-06-19 15:19 Assert.java
-rw-r--r-- 1 1798 2007-06-19 15:19 ComparisonFailure.java
-rw-r--r-- 1 270 2007-06-19 15:19 Protectable.java
-rw-r--r-- 1 5395 2007-06-19 15:19 TestCase.java
-rw-r--r-- 1 1444 2007-06-19 15:19 TestFailure.java
-rw-r--r-- 1 390 2007-06-19 15:19 Test.java
-rw-r--r-- 1 430 2007-06-19 15:19 TestListener.java
-rw-r--r-- 1 4202 2007-06-19 15:19 TestResult.java
-rw-r--r-- 1 7109 2007-06-19 15:19 TestSuite.java
Is there some environment variable something that holds the default
workspace path? I notice the error message doesn't include the full path,
so does it search from the workspace, or is this telling me it's looking
for the file starting at /?
Also, and this is just an annoyance ... If I have one of the settings
windows up in eclipse ... like the 'New Java Project' ... I can't scroll
in the help window that has the tutorial instructions which makes it hard
to read the instructions and look at the settings at the same time. Is
that just me or is it normal?
Any help appreciated.
Re: Basic tutorial - source file not read [message #216849 is a reply to message #216828] |
Tue, 19 June 2007 17:01  |
Well, I'm still not sure where the 'build path list' file is located, but
I found the problem.
When I imported the junit381src.jar into the JUnit project, it created a
subfolder named 'junit' with directories underneath that like 'framework'.
In the tutorial instructions it shows these folders in the project as
'junit.framework' ... but in my installation they were imported as 'junit'
-> 'framework'.
I'm using linux ... I wonder if the tutorial is windows specific?
I had to modify the build path by right clicking on the project, selecting
'Build Path ...' -> 'Configure Build Path' ... and adding 'junit/*' to the
included source directories.
I wonder if my setup is just screwy or if I need to report this somewhere
as a bug?
Thanks for helping me think out loud :)
FUDForum. Page generated in 0.13099 seconds
