Home » Eclipse Projects » GEF » GEF @ distributed app
GEF @ distributed app [message #216430] |
Thu, 18 May 2006 07:44  |
Originally posted by: caxqueiroz.gmail.com
I am trying to extend a GEF based diagram app to work between peers. Two
users working simultaneously thru a network connection.
Anyone knows how can I capture events like, position, which figure is
selected, etc?
I am using FigureListener to capture figure moving changes, but I still
need get in which position it is, to serialise and send thru network.
Even though I am getting moving changes, for each movement I do using
mouse, I get five events, I have added FigureListener when figure is
created (inside correspondent EditPart) is it right?
are There others ways to do it?
thx,
cax
Re: GEF @ distributed app [message #216444 is a reply to message #216430] |
Thu, 18 May 2006 03:47   |
Well, I don't know if it is the best solution but, I think you can capture the
changes of your model elements in the implementation of
protected void firePropertyChange(String property, Object oldValue, Object newValue)
(in the gef diagram example, it would be ModelElement.firePropertyChange(...).
There you can notify all changes that occurs in the editor to other "users".
(very well design GEF has! congratulations to authors!)
On Thu, 18 May 2006 21:44:09 +1000
> selected, etc?
> thx,
> cax
Re: GEF @ distributed app [message #216466 is a reply to message #216444] |
Thu, 18 May 2006 10:11   |
>> selected, etc?
>> thx,
>> cax
Thx for replying, very useful info.
But I still need capture when users is moving figures or lines, is it
possible?
Using that method I only get when change is done, not when is in progress.
thx,
cax
Re: GEF @ distributed app [message #216474 is a reply to message #216466] |
Thu, 18 May 2006 06:34   |
On Fri, 19 May 2006 00:11:12 +1000
> >> selected, etc?
> >> thx,
> >> cax
> possible?
You are right. I think you can capture this events in your LayoutEditPolicy
(the layout role installed in your contents edit part). In the shapes gef
example this class is
org.eclipse.gef.examples.shapes.parts.DiagramEditPart.Shapes XYLayoutEditPolicy
in the methods createChangeConstraintCommand(...) you can obtain the new
component's position with request.getLocation()
also, you can obtain many other changes of your editor elements in
other EditPolicies
hope this will be useful.
> thx,
> cax
Current Time: Sat Jul 19 18:01:01 EDT 2025
Powered by FUDForum. Page generated in 0.03044 seconds
