BIRT report does not display charts [message #213842] |
Wed, 24 January 2007 18:20  |
Hi all,
I am using BIRT 2.2M4 build. I created a birt report with bar chart and
report details connecting to a DB2 database. The chart and data is displayed
and works perfectly within the Eclipse environment. I export the
project(EAR file) and deployed in a WebSphere 6.0 environment. When I run
the application in IE browser using the URL
http://localhost:9080/birt/frameset?__report=salesReport.rpt design
the data is displayed without any problem, but the chart is missing. The
format of the chart is JPG. I also tried with other formats PNG, SVG and
BMP but in vain.
Under the WebSphere 6.0 directory where the application is installed i see
all the necessary charting jar files like
org.eclipse.birt.chart.device.extension_2.2.0.v20061130.jar etc.
Also I don't see any error messages in the log file.
Is there any setting which I am missing ?
Any help is appretiated.
Thnx.
Z
Re: BIRT report does not display charts [message #214395 is a reply to message #214370] |
Fri, 26 January 2007 12:05  |
Originally posted by: home4slc.pacbell.net
Hi Zorro,
No, I have not logged a bug for 2.2M4.
Susan
zorro wrote:
> Hi susan,
> Thnx. I installed BIRT 2.2M2 build on XP box and it works fine with WAS
> 6.0 on XP.
> I am able to see the charts in the WAS application. So it is a bug that
> birt 2.2M4 does not work well with WAS 6.0 with regards to charts. Have
> you created a bugzilla for WAS 6.0 and birt 2.2M4 already ?
> -zorro
FUDForum. Page generated in 0.23993 seconds
