Home » Newcomers » Newcomers » JVM error starting eclipse on Linux
JVM error starting eclipse on Linux [message #213291] Fri, 01 June 2007 09:32 Go to next message
I'm getting this error when I try to execute Eclipse
Warning: -Xms40m not understood. Ignoring.
Warning: -Xmx256m not understood. Ignoring.
Warning: -jar not understood. Ignoring.
Exception in thread "main" java.lang.NoClassDefFoundError:
usr.local.eclipse...startup.jar
at gnu.gcj.runtime.FirstThread.run() (/usr/lib/libgcj.so.5.0.0)
at _Jv_ThreadRun(java.lang.Thread) (/usr/lib/libgcj.so.5.0.0)
at _Jv_RunMain(java.lang.Class, byte const, int, byte const, boolean)
at __gcj_personality_v0 (/usr/local/eclipse/java.version=1.4.2)
at __libc_start_main (/lib/tls/libc-2.3.4.so)
at _Jv_RegisterClasses (/usr/local/eclipse/java.version=1.4.2)
Re: JVM error starting eclipse on Linux [message #213302 is a reply to message #213291] Fri, 01 June 2007 09:50 Go to previous messageGo to next message
You can not run Eclipse under the gcj JVM; you need to install and use
the Sun JDK or JVM.
Hope this helps,
Eric
Re: JVM error starting eclipse on Linux [message #213317 is a reply to message #213302] Fri, 01 June 2007 10:51 Go to previous messageGo to next message
It does. I set the JAVA_HOME to JDK 1.5 I had installed, but thought
eclipse would find the JRE under it.
At the command line I set the JAVA_HOME to the 1.5 jdk and excuted eclipse
and got the same error. I thought I'd try it this way before setting the
JAVA_HOME in my profile.
Re: JVM error starting eclipse on Linux [message #213371 is a reply to message #213317] Fri, 01 June 2007 16:53 Go to previous messageGo to next message
Originally posted by: wegener.cboenospam.com
Eclipse doesn't use JAVA_HOME to pick the vm. It uses the first VM found in
the path unless you include a path to the specific VM you want on the
command line. You specify the VM by adding a -vm
/path/to/vm/java_executable on the command line used to launch eclipse.
"James" <jlopes151@comcast.net> wrote in message
news:192f82174032ecee2bb5073c91e64b8a$1@www.eclipse.org...
Re: JVM error starting eclipse on Linux [message #213505 is a reply to message #213371] Sun, 03 June 2007 14:39 Go to previous message
Thanks for the help. Its working now.
Previous Topic:NoClassDefFoundError
Next Topic:Adding a new server to Eclipse
Current Time: Sat Jul 19 18:23:37 EDT 2025
Powered by FUDForum. Page generated in 0.08836 seconds
